FRFFT: Series Two
    FRFFT: Series Two
    Ill enter then
    Skink/Little Flipper 3
    Complete Control/Bad Attitude
    Nitro-Gene 5.0/Harraz (These are both on ZED in the Team Insanity section)
    Toro/Shrederator Supreme
      FRFFT: Series Two
      Sigh...realies...
      Dunno if Im gonna enter this one.
        FRFFT: Series Two
        Thanks, Paul. I need info on Little Flipper 3, but I think Shrederator Supreme is the superheavyweight version of Revolutionist from Extreme Warriors? Sorry, but you cant enter Toro because Samuel has entered it.
        Entries so far
        Featherweights:
        Skink/Little Flipper 3 (Paul C)
        Arrgh/Little Hitter (Samuel P)
        Beauty 2/Micrompression (Lewis M)
        Satanix/Isolation (Joey McC)
        Middleweights:
        Complete Control/Bad Attitude (Paul C)
        T-Minus/Hazard (Samuel P)
        El Diablo/Hyper-Ventilate (Lewis M)
        Doom/Hard Cheese (Joey McC)
        Heavyweights:
        Nitro-Gene 5.0/Harraz (Paul C)
        Armoured Wedgie/Compression (Lewis M)
        The Hurting/Quaester III (Joey McC)
        Mad Dash/Blue Hurricane (Samuel P)
        Superheavyweights:
        ???/Shrederator Supreme (Paul C)
        Ziggy/Toro (Samuel P)
        Drive/Kick Robut (Joey McC)
        Disector/Vertigo (Lewis M)
        Notices
        Lewis: I need info on Beauty 2. If you cant get any, youll have to enter another robot
        Paul: I need you to replace Toro
        Thats all. Steven McG, Christopher M, Daniel S? Do you want in?
          FRFFT: Series Two
          OK then. The Judge shall replace Toro
            FRFFT: Series Two
            Sorry if this isnt worth it, but can you pick a country to represent. The real robots have to represent where they come from in real life
              FRFFT: Series Two
              All mine represent England, as do all the realies.
                FRFFT: Series Two
                Il represent England, except for the realies from America
                • #23
                  FRFFT: Series Two
                  Thought about it, and Ive decided gonna enter (quiet, Joey, I know I sense some sarcastic comment coming from you :P). Youll have to wait a bit for most bots though (theyll be denoted with a *)
                  Featherweights
                  Micro Gore Evo*
                  Heretic*
                  Middleweights
                  Xianghua III*
                  Perseus
                  Heavyweights
                  Wedgin8or
                  Intriguous*
                  Superheavyweights
                  Fulcrum*
                  The System Of Doctor Tarr & Professor Fether
                  Ill be representing Canada, by the way.
                  • #24
                    FRFFT: Series Two
                    http://www.roamingrobots.co.uk/?pages=robot&id=1029http://www.roamingrobots.co.uk/?pages=robot&id=1029
                    Ill represent the UK except of course for the american robots Ive entered
                    (Message edited by Supersporty on January 02, 2009)
                    • #25
                      FRFFT: Series Two
                      I will enter ELLIOT, but next time I advise you on a different tournament setup, because otherweiht vapours are not very popular and omly a few people have more than one for each category.
                      Featherweights
                      Robot Name: Apocalypto
                      Weight: 13.6kg
                      Shape: Bulldog Breed-style wedge with rounded sides
                      Length: 25cm
                      Width: 25cm
                      Height: 25cm
                      Motivation: 6 x internal vulcanised wheels
                      Power: 2 x 12v cordless drill motors at 19.6v
                      Armour: 3mm titanium on top, front, sides and rear, 4mm HDPE on base
                      Weaponry:
                      1)Rear hinged front flipper, powered by a 60mm x 40mm ram at 250psi from a 600g co2 bottle
                      Top Speed: 12mph
                      Ground Clearance: 0 at front due to wedge, 5mm elsewhere
                      Turning Circle: 0
                      Srimech: The flipper springs the robot back onto its wheels
                      Colour: Red flipper, dark blue everywhere else
                      Strengths: Powerful flipper
                      Weaknesses: No damaging weaponry
                      Notes: A mini-Apocalypse
                      Robot Name: Werewolf
                      Weight: 13.6kg
                      Shape: Lox box with interchangeable front pieces
                      Length: 40cm
                      Width: 45cm
                      Height: 12cm
                      Motivation: 6 x invertible but internal from the side wheels, the hubs are HDPE and the tyres are polyurethane rubber. They 134mm in diameter
                      Drive: 2 x Dewalt Power Drives @ 24v
                      Batteries: 2 x 12v 2400mAh NiCads in series for 24v
                      Armour: 3.2mm hardox
                      Weaponry: The robot is a good pusher and can bash opponents around with top speeds of 22mph, but in the centre there is a Bio-Hazard style lifting arm powered by a 35w Bosch linear actuator that runs for the full length of the robot. At the front of the lifter there is a 1cm titanium scoop, 5cm wide. Also at the front there are the previously mentioned interchangeable fronts:
                      1) An extra 5mm hardox panel just to beef it up and defend from spinners
                      2) A wedge angled at 42*, made of 5mm hardox
                      3) A wedge angled at 30*, made of 5mm hardox
                      4) A pair of Wedge of Doom-style scoops, but rigid and made of 5mm hardox. The robot cant run inverted with these
                      Speed: Can reach 22mph when I want to really slam opponents into walls or hazards, but for driving it will mostly be kept to about 15mph
                      Turning Circle: 0
                      Ground Clearance: 0 at front with setups 1,2 and 3, 7mm at sides and rear and at the front with setup 1
                      Srimech: Runs inverted with all setups except no.4, but the lifter can always right the robot
                      Colour: Polished, like Trident
                      Strengths: Good pusher
                      Middleweights
                      Robot Name: El Media Diablo
                      Weight: 50kg
                      Shape: Chaos 2
                      Length: 45cm
                      Width: 30cm
                      Height: 25cm
                      Motivation: 2 x front go-kart wheels and 2 x rear casters, all internal
                      Power: 2 x S28-150 magmotors at 24v
                      Armour: 5mm titanium on top, front, rear and sides, 3mm 7075 aluminium base
                      Weaponry:
                      1)Rear hinged flipper, powered by 2 x 85mm co2 rams at 500psi each. A 2kg bottle provide the power, giving it about 12-14 flips per fight
                      Top Speed: 15mph
                      Ground Clearance: 8mm at sides, 4mm at rear and 0 at front due to flipper
                      Turning Circle: 0
                      Colour: Black
                      Strengths: Powerful weaponry
                      Weaknesses: High ground clearance at sides and rear
                      Robot Name: Zero
                      Shape: Cylinder, ala Daisy Chopper
                      Weight: 50kg
                      Length: (including disc) 65cm
                      Width: 70cm
                      Height: (including disc) 35cm (without disc) 10cm
                      Motivation: 6 x 3.2mm hardox wheels at either end, 12cm in diameter, external and invertible, exposed but protected by two tungsten carbide bars at either end. There are 6 wheels because they are mounted in a triangle like Trident from RW3
                      Drive: 2 x S28-150s @ 24v
                      Batteries: 2 x NiCad battlepacks @ 24v
                      Armour: 3.5mm titanium body and disc supports, tungsten carbide wheels protectors, titanium disc
                      Weaponry: A 25cm diameter vertical spinning disc 5cm away from the main body, supported by 4 x 4mm titanium arms, which have swivel castors on the top and bottom for easy manouevrability. The disc itself is made of titanium and has two 5mm hardox tunsgten tipped serrated blades which are part of the disc to avoid them being ripped off. These baldes are just 1mm from the ground, and when spinning at maximum speed of 2000rpm from the LEM-130 @ 36v that powers it can deliver 35.4Kj per hit as well as flipping opponents as it spins upwards. The direction can be reversed when the robot is flipped by the chain driven system
                      Speed: 15mph
                      Turning Circle: 0
                      Ground Clearance: The disc is 1mm from the ground, the rest of the robot is 10mm
                      Srimech: Invertible
                      Colour: The disc is blue with gold stripes and red blades, the body is mostly pewter and grey with some dark blue
                      Strengths: Powerful weaponry, flipping it does just about nothing
                      Weaknesses: Not the toughest armour
                      Heavyweights
                      Robot Name: System Shock V: Hex
                      Shape: Box wedge with sloped sides, the front wedge is angled at 60* to flip opponents and the sides are angled at 42* to deflect spinners, the front wedge has a 3cm long extension with a Firestorm-style blade, this extension is angled at 30* to get right in underneath opponents, then ram them so they get flipped by the main 60* wedge, it also has a Tornado style angled rear
                      Weight: Depends on setup, can gain a 10kg bonus because of the tracks in some setups
                      Length: 65cm
                      Width: 85cm
                      Height: 15cm
                      Motivation: 4 x CNC Aluminium internal, but invertible wheels, they have a v-belt groove in the treads and a v-belt between the wheels so they count as tracks, but if they break the robot is not affected at all and the robot simply becomes a wheeled robot, leaving the tracks behind. For certain opponents the tracks can be removed leaving it with just wheels, but if the tracks are removed the decision can be taken to add vulcanised go-kart tyres
                      Drive: 2 x LEM-200 lynch motors running @ 60v, providing over 100HP!
                      Batteries: 250 C-Cell NiCad batteries
                      Armour: 4mm hardox monocoque, with 6mm in key areas
                      Weaponry: As before the robot is primarily a rammer, but again it has some interchangeable weaponry;
                      - 50cm diameter titanium horizontal spinning disc, with 10cm long hooked blades that are part of the disc itself so they can€™t be ripped off from their own impacts. When attached this is situated on top of the robot itself, and the blades reach just over the top of the front wedge and the rear, but it will do the most damage if an opponent goes up the wedge. The tracks/wheels are higher than the disc, so it can still run inverted with this setup. The disc is spun by a LEM-130 lynch motor at 48v, and weighs 15kg, so can reach top speeds of 3000rpm in just 2.5 seconds. Kj count to come. This disc also feeds kinetic energy to the drive via a clutch, so the kinetic energy stored in the disc can be used for 45mph slams against other robots, which with the robot€™s front wedge is enough to throw robots out of the arena Storm II-style.
                      - A Tornado style cage can be fitted around the robot to keep crushers and axes at bay. Each of the 4 bars (one from each corner of the robot) is 70cm long and the bars are joined up by a square on the outside. Very few axes and no crushers will be able to reach the robot with this protection. The cage is made from tungsten carbide bars, so is essentially unbreakable by other robots. On the front of the cage will always be fitted the horizontal disc from setup 1, like Tornado had the spinning blade.
                      - The drum is back! Now spanning a massive 75cm in width and being made of titanium with its own teeth it spins upwards to 3000rpm in 2.5 seconds courtesy of a LEM-130 lynch motor running at 48v. It is connected to the wedge, so the robot still has 0 ground clearance at the front with this setup. It weighs 15kg and is chain driven, so can reversed if the robot is inverted
                      - A concave scoop made from 10mm hardox, perfect for stopping horizontal spinners or full body spinners. It is also lifted by 2 powerful linear actuators to lift opponent€™s wheels from the floor
                      - The €œclassic€ setup. The front wedge is thickened by 6mm hardox and actuated by an S28-150 magmotor at 24v, so it can work both ways up. Not including the cage with disc this is the only setup that works identically both ways up, as even the drum has to be reversed.
                      Speed: Can be pushed to 28mph, but mostly kept lower for more control (about 17mph). With kinetic energy boost it reaches 45mph very quickly. The motors are geared towards acceleration so it can reach top speeds very quickly.
                      Turning Circle: 0
                      Ground Clearance: 0 at the front, 10mm the rest of the way around, but that is protected by 5mm titanium hinged skirts at the sides and rear that flop over when the robot is inverted
                      Srimech: Invertible
                      Colour: Grey, with yellow eyes and the name written in yellow on top. See the image for colours of the different setups.
                      Strengths: Speed and Power
                      Weaknesses: Some people will be cheesed off by this clear exploitation of the weight advantage given to tracks
                      Robot Name: The R.O.C (Revenge of Collateral)
                      Shape: Box with wedges on all sides, the front wedge has a Firestorm-style blade for zero ground clearance
                      Weight: 100kg
                      Length: 90cm
                      Width: 95cm
                      Height: 15cm
                      Motivation: 4 x internal vulcanised wheels, mounted like those of Tazbot for extra manoeuvrability
                      Drive: 2 x PERM 080s @ 24v
                      Armour: 6-8mm grade 2 titanium for the most part, with 4mm hardox in key areas and 10mm HDPE on the base, with 4mm grade 2 titanium additional protection in key areas
                      Weaponry: This robot has an interesting weapon synergy onvolving;
                      1) A rear hinged lifting arm, hinged at the centre of the robots length and width. It is powered by an S28-400 at 24v for quick lifting, and it can raise to 2 levels- 75 degrees when lifting and 270 degrees when it needs to self-right/reset the flipper. The arm raises in about half a second
                      2) An upside down U-shaped front hinged flipper. The lifting arm is hinged in between the hinges of this weapon. It is powered by a 2 x 1.1kg co2 bottles and 2 x 85mm non-attached rams at 750psi, meaning it gets about 10 flips. Normally the rams wouldnt work when non-attached because of the way it is hinged, but the lifter will already be raised when the flipper is raised and so can quickly move back the rest of the way to reset the flipper
                      The way the weapon synergy works is this- the lifter lifts the opponent to 75 degrees, then uses the flipper to throw them about 7 feet up and across because of the placing of flipper and lifter. Then the lifter resets the flipper.
                      Speed: 15mph
                      Turning Circle: 0
                      Ground Clearance: 0 at the front, 7mm at sides and rear
                      Srimech: The flipper can right the robot, but the lifter will be used to conserve gas (unless for some reason it cant be
                      Strengths: Weapon Synergy, good armour
                      Superheavyweights
                      Robot Name: SLAM!
                      Shape: Box wedge, ala Storm II. The front wedge is angled at 42* to deflect spinner attacks and the rear is angled like Tornado
                      Weight: 200kg
                      Dimensions: 200 x 150 x 20
                      Motivation: 4 x internal, invertible wheels
                      Drive: 8 x LEM-200 at 60v, providing over 400HP!
                      Armour: 6mm hardox all over
                      Weaponry:
                      1)Firestorm-style blade on the wedge to give it 0 GC
                      2)Pushing Power/ Full Body Hammer
                      3) Bio-Hazard style lfiting arm, powered by pneumatics at 550psi, the gas is stored in a 2.5kg bottle, it has bars on top to aid in self-righting
                      4) On either side of the angled rear there is a tungsten tipped spike
                      Top Speed: 40mph, but it will be kept down to 17mph for pushing and only pushed to full for the hammer attack
                      Ground Clearance: 0 at front due to wedge, effectively 0 at sides and rear due to 7mm titanium skirts
                      Turning Circle: 0
                      Srimech: The arm, but it is invertible anyway
                      Colour: Black, with the name painted in white on top
                      Strengths: Immense pushing power
                      Weaknesses: Exposed wheels from top and bottom
                      & Son of Whyachi
                      Your weight limits are old-fashioned too ELLIOT, its annoying having to edit robots to get them in weight.
                      • #26
                        FRFFT: Series Two
                        Liam: Thanks for entering. Changes will be made in the next series, if there is one
                        Kody: Thanks for entering
                        Paul: I still need info about Little Flipper 3
                        Lewis: Thanks for the info on Beauty 2
                        Here is the current list
                        Featherweights
                        Werewolf/Apocalypto (Liam E)
                        Micrompression/Beauty 2 (Lewis M)
                        Micro Gore Evo/Heretic (Kody K)
                        Middleweights
                        El Media Diablo/Zero (Liam E)
                        Xianghua III/Perseus (Kody K)
                        Bad Attitude/Complete Control (Paul C)
                        Heavyweights
                        System Shock V: Hex/ROC (Liam E)
                        Wedgin8or/Intrigous (Kody K)
                        Superheavyweights
                        SLAM/Son of Whyachi (Liam E)
                        The Judge/Shredator Supreme (Paul C)
                        Vertigo/Disector (Lewis M)
                        Fulcrum/TSDTPF (Kody K)
                        And just to clarify
                        Joey McC (UK)
                        Lewis M (UK)
                        Liam E (Wales?)
                        Kody K (Canada)
                        Samuel P (England)
                        Paul C (UK)
                        Two places left.
                        • #27
                          FRFFT: Series Two
                          Yes, Wales, which like England is in the UK :P
                          • #28
                            FRFFT: Series Two
                            Team ?¿?
                            Featherweights: http://strickenone.proboards99.com/i...d=344OverDrive
                            • #29
                              FRFFT: Series Two
                              Yeah Ill enter. I just need some time to get some designs sorted.
                              • #30
                                FRFFT: Series Two
                                Thanks, AJ and Daniel. Paul, I went on the Roaming Robots website and found out about Little Flipper 3
                                All spaces are closed. Soon the party can begin.
