FRFFT: Series Two
  • FRFFT: Series Two
    Yes, I know. Its only been a few months in between series one and EVO but I cant think of any other way to celebrate the new year with the return of FRFFT: Series Two!
    RULES:
    This time, Im looking for eight people to enter two featherweights, middleweights, heavyweights and superheavyweights. This time, you all get to pick your favourite weight class!
    Featherweight: 1kg to 13kg
    Middleweight: 13kg to 25kg
    Heavyweight: 50kg to 100kg
    Superheavyweight: 100kg to 200kg
    Vapourbots and real robots are allowed. Still no house robots, but the arena is still RWS7.
    This will be the last major tournament I do in a while. The World Championships will be coming soon. But believe me, thisll be the entrance to the New Year even Craig Charles will expect!
    See you later, then!
    FRFFT: Series Two
    *reserves*
    Can you clarify the entry rules again? I thought a middleweight was 50kgs...
      FRFFT: Series Two
      Ill enter Micrompression, Hyper-Ventilate, Armoured Wedgie and Vertigo, stats on ZED
        FRFFT: Series Two
        Sorry Joey, I got it mixed up the last time. Normal RW rules apply!
        Lewis, you need to enter one more of each weight
        Also, what is ZED and how can I get to it without too much trouble?
        Spaces:
        1: Joey
        2: Lewis
          FRFFT: Series Two
          ZED is http://strickenone.proboards99.com/index.cgihttp://strickenone.proboards99.com/index.cgi and can be accessed by most good web browsers, and some really bad ones too.
          My entries will be...I dont know if I can get more than one of any weight class together in the time I have, so can I just enter two heavies?
            FRFFT: Series Two
            Joey: Thanks for the ZED. You can just enter real robots for the rest. I dont mind. I need your heavyweight robots, though. Also, I didnt know you like Bottom?
            Lewis: I need another heavy, feather, middle and superheavy from you
            I need six more people, please
              FRFFT: Series Two
              I do, yep, only recently discovered it but it appeals to me in a very childish way :P
              I shall enter:
              Drive (on ZED) and Kick Robut (RW series 2) for the superheavies
              The Hurting and Quaestor III for the heavies
              Doom (RW Extreme 1) and Hard Cheese (same) for the middles
              and Isolation (stats up shortly on ZED) and Satanix (see Roaming Robots site or http://thedavidleague.tripod.com/teamhell/http://thedavidleague.tripod.com/teamhell/ for details) for the feathers.
              Hope those are alright.
                FRFFT: Series Two
                Ill take Compression (see ZED) for my other heavyweight and for the rest:
                FW ~ Beauty 2
                MW ~ El Diablo
                SHW ~ Diesector
                  FRFFT: Series Two
                  Thanks, guys.
                  Entries
                  Joey McC
                  Featherweights: Isolation/Satanix
                  Middleweighs: Doom/Hard Cheese
                  Heavyweights: The Hurting/Quaestor III
                  Superheavyweights: Drive/Kick Robut
                  Lewis Matthews:
                  Featherweights: Beauty 2/Microcompression
                  Middleweights: El Diablo/Hyper-Ventilate
                  Heavyweights: Compression/Armoured Wedgie
                  Superheavyweights: Vertigo/Disector
                  The seedings will be coming up once everyone is in
                  See you later
                    FRFFT: Series Two
                    FW: Dizzy Tilly / Little Hitter
                    LW: Ziggo / Ground Zero
                    MW: Hazard / T-Minus
                    HW: Blue Hurricane / Mad Dash
                    SHW: Ziggy / Toro
                    Blue Hurricane
                    Weight: 100kg
                    Shape: Disc
                    Dimensions: 88 X 88 X 27
                    Colour: Royal Blue for the sides, and a nice shade of midnight blue for the top and bottom.
                    Power: 2 X LEM-130s @ 36v, with a couple of NiCad Batteries.
                    Wheels: Two Aluminium Wheels with a nice layer of Asmaprene Urethane on it.
                    Armour: 3.25mm Hardox for top and bottom, and 11mm Grade 5 Titanium for the sides.
                    Top Speed: 13mph
                    Ground Clearence: 5mm Everywhere.
                    Turning Circle: Zero! Need I say more?!
                    Weapon: Ok, the weapon is a nasty 32kg spinning rim, which is made out of 11mm Grade 5 Titanium, with 4 X Tungsten-tipped teeth. (2 teeth on bottom, and 2 on top) The teeth are all made out of hardox, and also curved to rip off skirts and panels with ease. It also runs on a single LEM-130 Lynch, and spins at about 2000RPM. This can rip through titanium and dent hardox quite easily. Heavily Shock-Proofed, as well.
                    Srimech: Invertible
                    Strengths: Can cause a lot of damage
                    Weaknesses: Not the best pushing power by a long shot
                    Mad Dash
                    Weight: 100kg.
                    Body Shape: Box with a front scoop.
                    Color: Chartreuse Body, Pure Black Scoop.
                    Dimensions: 100 X 90 X 36
                    Drive: 2 X LEM-130s @ 36v powered by 4 X NiCad Batteries.
                    Top Speed: 20 mph.
                    Tyres: 4 X Vulkanized Tyres.
                    Armour: 4.2mm Hardox
                    Ground Clearence: Completely 0mm on the front and 6mm anywhere else. (including sides)
                    Weapon 1: Static Scoop to deflect other spinners.
                    Weapon 2: In the middle of the scoop, there is a Tornado-esque drum thingy powered by S28-150, spinning at 3220RPM.
                    Srimech: Invertible, Side spikes prevent it from getting beached on its side.
                    Strengths: Can run both ways up, EXTREME Pushing Power, Deadly Drum, Can get under anything, Shock-Proofed.
                    Weaknesses: So-So Turning
                    Here is a clip of Ziggo: http://www.youtube.com/watch?v=1SwpLoA02TEhttp://www.youtube.com/watch?v=1SwpLoA02TE
                    Here is a clip of Ground Zero: http://www.youtube.com/watch?v=dAeY0D2eiLEhttp://www.youtube.com/watch?v=dAeY0D2eiLE
                      FRFFT: Series Two
                      Current Entries
                      Joey McC
                      Featherweight: Isolation/Satanix
                      Middleweight: Doom/Hard Cheese
                      Heavyweight: The Hurting/Quaester III
                      Superheavyweight: Kick Robut/Drive
                      Samuel Park
                      Featherweight: Dizzy Tilly/Little Hitter
                      Middleweight: T-Minus/Hazard
                      Heavyweight: Mad Dash/Blue Hurricane
                      Superheavyweight: Ziggy/Toro
                      Lewis Matthews
                      Featherweight: Beauty 2/Micrompression
                      Middleweight: El Diablo/Hyper-Ventilate
                      Heavyweight: Armoured Wedgie/Compression
                      Superheavyweight: Vertigo/Disector
                      Samuel: There arent any lightweight competitions in this series. Sorry. Also, I need info on Dizzy Tilly
                      Lewis: I need info on Beauty 2
                      Joey: I need info on Isolation
                      Thanks guys
                        FRFFT: Series Two
                        Isolations on ZED, or should be.
                          FRFFT: Series Two
                          Id like to swap Dizzy Tilly for Aargh.
                          http://www.youtube.com/watch?v=cM0DHfFZSjAhttp://www.youtube.com/watch?v=cM0DHfFZSjA
                          Aargh is the robot with the big spinning disc.
                            FRFFT: Series Two
                            Samuel: Arrgh is fine
                            I need 5 more people, please
                              FRFFT: Series Two
                              Here are the seeds
                              Featherweights:
                              1: Deadly Lampshade
                              2: Little Hitter
                              Middleweights:
                              1: El Media Diablo
                              2: Hazard
                              Heavyweights:
                              1: The Hurting
                              2: Nitro-Gene 5.0
                              Superheavyweights:
                              1: Drive
                              2: Ziggy
                              Not to rush people, but there are still five spaces here
