The Chevron Championship Series 2 - Medium Medium Speed Ones
  • #46
    THE CURRENT CHEVRON CHAMPIONSHIP 2: MEDIUM MEDIUM SPEED ONES ENTRY LIST
    1: Kody Kunz
    -Macduff The 4th
    -Super Gore Septua
    -Shadow Zone Forever
    -Intriguer (or Intriguous if finished)
    2: Paul Cuomo
    -Nitro-Gene 5.0
    -Harraz
    -Autoism 3.0
    -Blast
    3: Daniel Stickler
    -Monsoon Season
    -Fling
    -Squish Reincarnated
    -MacBeth
    4: Richard Southworth
    -Battle Raptor 5
    -Double Killa 2
    -MORD 2
    -Ringwraith
    5: Jack Orr
    -CroOKeD
    -Boxx
    -Pick-Axe Of Doom
    -Typhoon 2
    6: Samuel Park
    -Blue Hurricane
    -Paralyzation 2
    -Mad Dash
    -Ramminator Evilution
    7: Andrew Jackson
    -Gehenna
    -Exertion
    -PsycloniZer
    -Wedga Triton
    8: Elliot Stevens
    -The Kill Point
    -Skullcrusher
    -Joker
    -Night Stalker
    9: Shane Swan
    -Ripper
    -Envy
    -Thor
    -Megamouse
    10: Martijn Benschop
    -Back To Rock III
    -Sheer Heart Attack 2
    -Under Pressure
    11: Matty Fowler
    12: Steven McGregor
    -Spin Dash Unleashed
    -Turbo Tails
    -Venus Fly Trap
    -Jack In The Box
    13: Frank Goacher (recieved provisional entries through msn)
    -Door Stops
    -Raging Tempest?
    -The May Tracks Has You?
    -Cobalt?
    14: Alex Holt
    -Darkestar (redesign)
    -Tengu VII
    -Achilles
    -Slammer VI
    15: Liam Eliot
    -Brutalis 2.1
    -The Subjugator
    -LockJaw Epidemic
    -System Shock V: Hex
    16: Lewis Matthews
    -Alpha Bolt
    -Shadow Ninja
    -Jolly Roger
    -Orion
    17: Martyn Forsyth (entered via msn)
    18: ?
    The summary of all this is:
    All of Dans updated entries are fine, glad you finally decided on a lineup :P
    Martyn has sort of agreed to enter
    There is (I think) one space remaining...Aaron? Leo? Someone else?
    If its not too much trouble, would people give me a location I can use in the intro, to save me saying From England, The Failbot! or similar? PLEASE DONT TELL ME IF ITS BEEN STATED OR I ALREADY KNOW, NO SPAMMING PLZKTHX. :P
    I shall be on the forums only, and then intermittently, for about a week so email me if any problems arise that require my attention.
    Thank you all for entering so far, and for all the messages of encouragement
    • #47
      Will From Lancashire be OK for me, Joey?
      • #48
        From Milton Keynes/Bedford will be fine over here
        • #49
          Right, I have decided on my machines... they shall be:
          Action Control
          Assegai
          Hypertension Mk 3.5
          Roo Of All evil
          • #50
            From Orpington, Kent for me Joey.
            • #51
              From Vancouver, British Columbia for me, sil vous plait.
              • #52
                OK, seeing as there is a space open, Ill enter.
                Ill be entering...
                Leprosy Infection
                Mega Masher 2
                Cyclone Force 3
                Axe-O-Lotl
                Stats should be in the usual spot, and Im representing Onehouse in Suffolk.
                • #53
                  from Richmond, in Surrey will be fine for me joey
                  • #54
                    oh and can i enter skink in the feathers
                    • #55
                      Cardiff, Wales
                      • #56
                        Im from Liverpool, England
                        • #57
                          Everyone except for Lewis I was aware of already :P (just Lancashire is fine btw, Richie)
                          Chris: Dimensions please, for most of them. Also I suspect that Cyclone Force 3 is somewhat overweight, with the 11mm Ti (presumably all around) and the interchangable weapons. If Storm II couldnt manage it, you probably cant
                          Also ground clearances are somewhat vague (6mm, presumably all around? I will be forced to assume from that that any skirted areas are 6mm too :P), as are, come to think of it, the rest of the stats. Is it too much to ask that you make them a bit more detailed and tell me what weapons are made of, give power other than same things as other robot, and other things? I have decided to to maintain a standard for entries here, I cant make exceptions because thats the way youve always done it.
                          Jack: Yep, you can enter Skink in the feathers.
                          Full list up next time I can get online, the last space will be filled either by Chris (if he sorts his stats out) or the first person who hasnt already entered that can come up with four decent robots.
                          EDIT: Elliot, just noticed theres no motors in Skullcrusher, if you have trouble working out which to use my table (yep, blatant plugging ftw :P) might help:
                          (Message edited by joeychevron on January 05, 2009)http://strickenone.proboards99.com/index.cgi?board=chevawards&action=display&thread=4 91http://strickenone.proboards99.com/i...lay&thread=491
                          • #58
                            Skullcrusher uses 2 750watt motors
                            Hope its OK
                            • #59
                              Is should be, yeah...theres a few 750 watt motors (none as used by Firestorm unfortunately, cant remember what they had motor wise :P) but Ill assume theyre Bosch 750s on 24v, as used by Pussycat, Anvil, Hellbent, Bigger Brother, and more. Good little motors those are.
                              • #60
                                Joey, when your child wants to learn to swim, you dont just throw it in the deep end of a swimming pool.
                                What Im saying is that IS kinda asking for quite a considerable amount...I can get updated stats, but theres no way you can expect me to pull off ALL of that information in one go.
