The Chevron Championship Series 2 - Medium Medium Speed Ones
  • #61
    Thing is, Chris, youve been here for ages (like 2003?) so everybody assumes youve got the information already (not saying its right but thats pretty much whats happened, just like with Tony IIRC, although he was here for a much shorter period of time). Kinda shocking when we find out you dont.
    • #62
      Joey, when your child wants to learn to swim, you dont just throw it in the deep end of a swimming pool.
      Well actually...
      • #63
        Thats all very well, but theres the issue...and this is extremely important...of whether I understand it or not.
        If we take Mega Masher 2, for instance. Its got a weight, body shape, dimensions, top speed, TC, GC, Armour, Power for the drive, power for the weapon, THE weapon, what it does...now, as far as Im concerned, and as far as Ive gathered from what Ive seen from Robot Wars and the competitors websites, thats enough. The fact that youre now telling me that I HAVE to talk about the weapon motor voltage, a concept Ive got no chance of understanding, throws me completely.
        As far as Im concerned, Ive got the vitals and thats enough. I know that the more detail, the better...but surely it could go to the point of rediculous-ness. I mean, I dont even want to consider the possibility of having to describe the EXACT shade of red it is.
        I appriciate you all for helping me, but youre throwing too much stuff at me, stuff I simply dont need all in one go.
        Ill try my best to update the stats as best I can. But I cant do more than I understand, Im afraid.
        • #64
          Ive tried to give the stats an update. But this really is pushing my limits somewhat.
          CYCLONE FORCE 3
          Weight; 100 kilos
          Body Shape; Low invertable box, kinda like Storm 2, but without the wedge. Only 80cm in length and width and 30cm high.
          Speed; 20mph
          TC; 0
          GC; Side is 0mm due to skirts. Otherwise, 10mm. See set-ups for front GC
          Wheels; 6 inner
          Armour; 8mm Titanium.
          Power; LEM130s at 36 volts, ala Storm 2. 3x12v batteries.
          Colour; A blue-ish grey tone all over.
          Weapons; The robot has 3 set-ups...
          SET UP 1...An electric lifter device, similar to Storm 2. In theory, it can lift 190 kilos. The front makes a wedge and results in a 0mm GC. However, the wedge is useless upside down.
          SET-UP 2...Two large 30 centimetre long steel spikes, powered by their own pneumatic system and running off CO2. The front with this GC is 10mm.
          SET-UP 3...A simple bucket scoop, like X-Terminator. The scoop is static, but can get underneath virtually zero ground clearance. Its front is 0mm.
          Srimech; The robot runs inverted, the sides are protected by the skirts and back stranding is impossible.
          Inspiration; The original Cyclone was named because it is the name of a storm and it sounds threatening. The force came later, after it became a pusher.
          Strengths;Raw power
          Weaknessess;Limited control.
          LEPROSY INFECTION
          Weight; 100 kilos
          Body Shape; Invertible box, looks a bit like Tetanus Booster, only slightly larger. About 140cm in length, 90cm in width and 30cm in height.
          Speed; 18mph
          TC; 0
          GC; 6mm. The mini-skirts hang down to about 1mm.
          Wheels; 4 inner, top sticking out. Hinged mini-skirts hang from the side, and these protect the wheels from low lying discs.
          Armour; 7mm titanium
          Power; 3x 12v batteries, powered by S28-400 Magmotors. LEM130 motor for the drum.
          Colour; A disgusting shade of lime green.
          Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this explained below. By the drum are two hindged wedge type devices, which drive oppodents onto the drum.
          Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
          Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
          Strengths; Drum, control is pretty good
          Weaknessess; Wheels may be vulnerable to axes
          MEGA MASHER 2
          Weight: 100 kilos
          Body Shape: A Triangle shape, a bit like Inshredable (from Series 6). 0.85m in length and width, and 0.35m at its highest point. The sides are heavily angled, a bit like UFO in S7, only more so.
          Speed: 15mph
          TC: 0
          GC; 0 at front, 6mm elsewhere.
          Wheels; 6 inner, aranged in a 3-wheel-a-side formation. This means that four wheels are always on the ground at any one time.
          Armour: A nice 3.25mm Hardox, all over.
          Power: 3x 12v batteries, plus Bosch 750s at 36v.
          Colour: Red and yellow.
          Weapons; The front is a wedge, and the back has a nasty vertical titanium 35cm in diameter disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage.
          Srimech: The robot can run inverted, with the sheer angling at the sides making stranding near impossible.
          Inspiration; This is probably the only robot I have where I have had no inspiration. It just came as a good name.
          Strengths: Power, weaponary
          Weaknessess: New and untested design.
          AXE-O-LOTL
          Weight: 100 kilos
          Body Shape: Comengetorix shaped (box-wedge?), a metre long, 70cm wide and 30cm high.
          Speed: 20mph
          TC: 0
          GC: 0mm at the front, 6mm elsewhere.
          Wheels: 4 inner
          Armour: 3.25mm Hardox all around.
          Power: LEM130s at 36 volts, ala Storm 2. 3x12v batteries.
          Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
          Weapons: A very nasty pneumatic titanium axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
          Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
          Inspiration: My favourite amphibian, the axolotl.
          Strengths: Powerful weaponary
          Weaknessess: Obviously a limited CO2 supply.
          • #65
            I dont wanna dive into this discussion but I want to say you miss a point here. With real robots, the actual robots do the fighting, the way the roboteer describes it does not effect the way it fights.
            With vapourbots, there are no actual robots. All the fighting is done by the robot you DESCRIBE. The description is vital in vapourbots.
            • #66
              I know that, and thats what Im trying to do. Im also using my favourite secret weapon...common sense. I mean, if an axe can fire 40 times in a match, or a blade can spin at 2000rpm, I would (and this is personally just me) have been able to figure it out from there.
              Besides that, I dont wish to risk conflicting information.
              • #67
                Thing is that you cant assume what is and what isnt unless you know more things and are able to make a more accurate guess. Right, so I should just suppose two discs made of different material, Hardox and titanium, give out the same amount of kinetic energy when spinning at 2000rpm then, Chris? Of course not. They have a different MOI (Moment Of Inertia, and I explained that to you a bit before; the higher the MOI, the more kJ) and different dimensions, which both contribute to the amount of kJ they dish out, and thus one of the discs is stronger.
                Same thing with the axe situation youre referring to. For an axe to fire 40 times in a match, it would have be dependent on the size of the ram (if its thinner, then yeah it can fire more times because less CO2 is used), but also the amount of CO2 for the axe.
                Stats build on each other, Chris. You cant have one without the other.
                (Message edited by kodster on January 05, 2009)
                • #68
                  Yeah, I know that. But, unfortunately, the way youve described it falls under the technological blabble in my book.
                  The whole issue I think is going on here is the understanding. You may, but dont you think youre asking a bit much for me to be able to grasp that straight away. I mean, I only managed to grasp the concept of MOI fairly recently (and you should know because you told me about it), and even now Im still not totally happy with it. Or the whole concept of kenetic energy...that just flys over my head, to be honest. Its a titanium blade spinning at 2000rpm. Thats enough. From the understanding POV anyway.
                  • #69
                    Chris...
                    -a titanium blade weighing 400g, 20cm in diameter with sharp edges on, spinning at 2000rpm
                    -a titanium blade weighing 40kg, 1 metre in diameter, and shaped into large hammers at the ends, spinning at 2000rpm
                    You and I know that these two things will do completely different amounts of damage when they hit...and yet you say material and rpm is all thats needed? I think theres a bit missing there :P
                    And btw, I could do with Cyclone Forces length really, but if you could make changes to the stats with regards to what Kody and Marti have (very excellently I must say, thanks guys ) mentioned above and add a length, we could be rolling.
                    • #70
                      Joey, thats completely different. OBVIOUSLY that sort of stuff would be included as well...in fact, Id probably have that down before I even have the material and RPM. Thats unneccessary.
                      Oh, and because it seems you havent noticed, Ill repost what was posted 6 posts up.
                      CYCLONE FORCE 3
                      Weight; 100 kilos
                      Speed; 20mph
                      TC; 0
                      Wheels; 6 inner
                      Strengths;Raw power
                      LEPROSY INFECTION
                      Weight; 100 kilos
                      Speed; 18mph
                      TC; 0
                      MEGA MASHER 2
                      Weight: 100 kilos
                      Speed: 15mph
                      TC: 0
                      AXE-O-LOTL
                      Weight: 100 kilos
                      Speed: 20mph
                      TC: 0
                      Wheels: 4 inner
                      • #71
                        ...I had noticed it, and had asked for you to make changes, there was no need to repost exactly the same thing twice :P
                        I did manage to miss the length and bit in Cyclone Forces stats though, so sorry about that, and in the interests of not causing you to start World War II over very little Ill assume some things, like weight of discs and ram sizes and such, so it looks as though you are in.
                        THINGS I NEED NOW
                        Stats from Frank (entire squad), Martyn (entire squad), Kody (Intriguous) and Marti (4th bot)
                        • #72
                          As it was, Joey, the thing you asked for WAS the thing already in the post, which you admitted to having missed. Thats the only reason it was posted twice.
                          Just so you know.
                          • #73
                            The big entry list
                            1: Kody Kunz (Toronto in Canada)
                            -Macduff The 4th (6)
                            -Super Gore Septua
                            -Shadow Zone Forever
                            -Intriguous (stats needed)
                            2: Paul Cuomo (Orpington)
                            -Nitro-Gene 5.0
                            -Harraz
                            -Autoism 3.0
                            -Blast
                            3: Daniel Stickler (Merthyr Tydfil in Wales)
                            -Monsoon Season
                            -Fling
                            -Squish Reincarnated
                            -MacBeth
                            4: Richard Southworth (Lancashire)
                            -Battle Raptor 5
                            -Double Killa 2
                            -MORD 2
                            -Ringwraith
                            5: Jack Orr (Richmond)
                            -CroOKeD
                            -Boxx
                            -Pick-Axe Of Doom
                            -Typhoon 2
                            6: Samuel Park (Vancouver in Canada)
                            -Blue Hurricane
                            -Paralyzation 2
                            -Mad Dash
                            -Ramminator Evilution
                            7: Andrew Jackson (Worcester)
                            -Gehenna (3)
                            -Exertion (5)
                            -PsycloniZer
                            -Wedga Triton
                            8: Elliot Stevens (Jersey in the Channel Islands)
                            -The Kill Point
                            -Skullcrusher
                            -Joker
                            -Night Stalker
                            9: Shane Swan (Mablethorpe)
                            -Ripper (2)
                            -Envy
                            -Thor
                            -Megamouse
                            10: Martijn Benschop (Enschede in the weed smoking Netherlands)
                            -Back To Rock III
                            -Sheer Heart Attack 2
                            -Under Pressure
                            -(stats needed)
                            11: Matty Fowler (Milton Keynes)
                            -Assegai
                            -Hypertension Mk. 3.5
                            -Action Control
                            -Roo Of All Evil
                            12: Steve McGregor (Glasgow in Scotland)
                            -Spin Dash Unleashed
                            -Turbo Tails
                            -Venus Fly Trap
                            -Jack In The Box
                            13: Frank Goacher (Gainsborough) - stats needed for all
                            -Door Stops (4)
                            -Raging Tempest?
                            -Cobalt?
                            -The May Tracks Has You?
                            14: Alex Holt (Geddington)
                            -Darkestar (1) - stats redesign in the coming but its heat will be later on so no pressure
                            -Tengu VII
                            -Achilles
                            -Slammer VI
                            15: Liam Eliot (Cardiff in Wales)
                            -Brutalis 2.1
                            -The Subjugator
                            -LockJaw Epidemic
                            -System Shock V: Hex
                            16: Lewis Matthews (Liverpool)
                            -Alpha Bolt
                            -Shadow Ninja
                            -Jolly Roger
                            -Orion
                            17: Martyn Forsyth (Kelvedon) - stats needed for all
                            18: Christopher Mason (Onehouse)
                            -Leprosy Infection
                            -Mega Masher 2
                            -Cyclone Force 3
                            -Axe-O-Lotl
                            Otherweights
                            Antweights:
                            Tiny Titanium Teeny (Liam Eliot)
                            Flamberge (Kody Kunz)
                            Kobe (Dan Stickler)
                            MicroForce 3.0 (Andy Jackson)
                            Dead Meat (Jack Orr)
                            Little Nipper (Elliot Stevens)
                            Slice n Dice 2 (Richard Southworth)
                            Featherweights:
                            Sons Of Thunder (Elliot Stevens)
                            OverDrive (Andy Jackson)
                            Skink (Jack Orr)
                            Apocalypto (Liam Eliot)
                            Micrompression (Lewis Matthews)
                            Micro Gore Evo (Kody Kunz)
                            Little Hitter (Sam Park)
                            Deadly Lampshade (Dan Stickler)
                            Sith (Alex Holt)
                            Lightweights:
                            Scarab (Kody Kunz)
                            Tiny Tengu (Alex Holt)
                            Crash (Richard Southworth)
                            Vincent (Dan Stickler)
                            Titanium Titan v2 (Liam Eliot)
                            Ziggo (Sam Park)
                            Minilith (Andy Jackson)
                            Roundhouse Kick (Lewis Matthews)
                            Bottom (Elliot Stevens)
                            Middleweights:
                            Blizzard (Alex Holt)
                            259 (Elliot Stevens)
                            Hyper-Ventilate (Lewis Matthews)
                            ROID (Andy JAckson)
                            Zero (Liam Eliot)
                            Hazard (Sam Park)
                            The Bone Collector (Dan Stickler)
                            Xianghua II (Kody Kunz)
                            Super Heavyweights:
                            Fulcrum (Kody Kunz)
                            Cause And Effect (Dan Stickler)
                            SLAM! (Liam Eliot)
                            Diesector (Elliot Stevens)
                            UberForce 2.0 (Andy Jackson)
                            The Red Knight (Alex Holt)
                            Vertigo (Lewis Matthews)
                            I am actually quite eager to start this, so get your entries in before the end of the month at least. :P
                            • #74
                              Double post to say that Steve McGregor has pointed out to me that his otherweights werent on the list.
                              They are now, my bad.
                              So...uh...entries in quick please...looking forward to tourney starting...postcount +1?
                              • #75
                                Triple posts ftw
                                There is a distinct lack of activity on the boards atm, so could I ask that the people with entries still outstanding (Martyn, Martijn and Frank) get them in as soon as is reasonably practical please?
                                I hate to sound like Paul here but I am eager to get this started while I still have the time to get some done before more exams.
                                Besides, Dans saying he might change his squad again.
