Pussycat Tribute Tournament 3...continued!
Youd probably lose at least half of your team in order to beat one.
No problem if I beat it.
However, the No.2 seed is back for that championship crown and is looking forward to getting some practice on two equally vicious newcomers - Charybdis, the disc-clad walker, and the unique 5-way cluster that is The Team That Wasn€™t There.
Let€™s get a-fightin€™!
With the Team members trundling merrily around the ring, SpunOut rams right into Charydbis€™ side as the walker tries to take out one part of the Team!! With its far superior traction, the No.2 seed shoves the newcomer right across the arena and smacks it into the arena wall!! However, just as the PTT2 runner-up backs away from Charybdis, two segments of the Team nip over and slide underneath SpunOut€™s side!! With their combined pushing power, the twins successfully shove the 2nd seed across the ring and right into another arena fence!! While one MORE member of the Team activates the Pit Release Button, Charybdis finds itself being circled by the other two members, just as SpunOut and the remaining pair begin a gruesome tango!! With the twins still running rings round the walker, Alex decides that enough is enough!! As SpunOut gets side-on to one of the segments and rams it across the arena, the Team member whom released the Pit heads over to join the party by Charybdis!! Suddenly, the walker scuttles round...allowing the 20kg machine to head wedge-first into the flywheel!!! Disc meets cluster piece...and the cluster piece is sent a-twirling out of control!! As Hector€™s companion tries to regain control of his stunned segment, Charybdis gives the pack member a good thwack on its side with the flywheel!!! The force sends the Team member rolling onto its back, as the two sections hounding SpunOut slide under the No.2 seed again, giving him a short, sharp trip to the arena wall again!!! With one final blast from the spinner, the battered Team member falls silent...one down, four to go!!! The Lexen armour has received dents and scrapes, and something must have been bashed about inside!!! While the now-free SpunOut another cluster piece shoved across the arena and Charybdis gets shoved side-on across the ring by the other two members, Refbot starts counting out the immobile segment!!!
As SpunOut once again takes a Team segment on a tour around the arena, the two team members shoving Charybdis around find the perfect place to send the walker...to Matilda!!! On reaching the House Robot€™s CPZ, the two pieces back off slightly, allowing €˜Tildy to head disc-first into the side of Charybdis, trying to get free!! The flywheel hits the side of the walker and even makes the 200kg competitor €œjump€ slightly off the ground!!!
However, for all its trouble, Alex€™s machine still seems OK!! Scuttling away from the CPZ, the walker trundles by SpunOut, who is sending another section across the arena, closely followed by ANOTHER section!!! This is madness!!!
Wishing to end Alex€™s confusion, the other two competitors nip around to Charybdis€™ side and start shoving the PTT newcomer over towards the Pit!!! However, with the edge getting closer, the skirted box turns and whacks one of the segments on the wedge with its flywheel!!! As it tries to get a second attack on the wounded member, its partner swerves round to Charybdis€™ side and gives it a good hard shove!! As Alex€™s machine tries to get back into step (and as the No.2 seed gets shoved side-on round the arena by the two other team members
), the walker€™s harassers swing round the side once more!! Just as SpunOut breaks free from another slam and starts shoving another team member across the arena (closely followed by its partner), the other two surviving segments use their combined strength to push Charybdis back down the arena...to the edge of the Pit...and in!!!
As Frank€™s machine swings round once again, Hammerer takes the opportunity to ram Bigger Brother side-on with its front two wedges!! Shoving the No.18 seed into the arena wall, the arm slowly lowers in its eerie arc...down onto the RW5 runner-up!! Andy activates the electromagnet, raises the arm that little bit...and has Bigger Brother off the ground, dazed and confused!!! Swinging round, the No.18 seed under its control, Hammerer trundles down the arena and nudges Bigger Brother into the Pit Release Button!!! However, as the No.18 seed hits the tyre, Dave fires the flipper!! Combined with the hard shove given by Andy€™s machine, Bigger Brother has managed to get itself free from the magnet...and now he€™s angry!!! As Falchion heads back down the arena to help Andy out, the No.18 seed nips around to the PTT newcomer€™s side and slides under the rounded side!! One flip later and Falchion gives the audience a nice little barrel roll!!!
Just as Hammerer trundles over and nudges the No.18 seed€™s side, Bigger Brother swerves away from the arm and round under Hammerer€™s side!! One flick later, and the PTT newcomer is over on its back!! The arm begins to slowly push the machine over...but Dave is after revenge!!! The No.18 seed is guided under Hammerer€™s side and Mr Sheppard shoves the newbie across the arena, pursued by the irritated Falchion!! Now smack-bang against the fence, Bigger Brother€™s flipper goes off again...now Hammerer is propped against the wall!!! Just as the wheels start trying to gain grip (and as Frank€™s machine gets ever nearer), Dave lets the No.18 seed slide under Andy€™s final entry once again!! The flipper fires...and Hammerer to toppled up, onto and over the arena barrier!!! Our final PTT3 melee has drawn to a close...with Falchion slipping under Bigger Brother and tipping it over again!!!
A newbie to our Warzone, we€™ve already seen Mr Maw go out in Round 2 this year to former champion Beta. However, the shuffler is back to gain some of its honour back - and God help those who meet the Nightmare-style disc and Toro-esque flipper arm along the way!
Very pleased with his work, Kody sends his machine around the toppled House Robot and gently taps the 50 Point Target!! Swinging round, Junkyard Maw leaves Matilda alone and continues down the arena...right into a charging Dead Metal!!! Not wanting him to hinder his plans, Kody activates the flipper...and casually flicks the House Robot off his front and out of the way!! Back on the run, the PTT newcomer scuttles down the arena, this time into Sir Killalot!! The Knight of the Realm tries to grab onto the flipper...but Kody€™s machine has already driven underneath the front of the House Robot!!! The flipper fires...and Sir K is flicked off the ground!!!
Smacking back down on his track, the furious Knight takes a swing at Junkyard Maw...only to find that the PTT newcomer has sneaked behind the House Robot and nudged the 75 Point Target!!!
Infuriated, Sir K swings round for another clash, but Kody€™s machine has already nipped away from the Knight and back into the arena!! Dodging another charge from DM, Junkyard Maw scuttles over to the other corner of the arena, to the Multi-Ball!! The shuffler nudges into the bumper and racks up 10 points as the balls cascade down to the ground!!
and very well done to Lord Roper and Mr J
to take a look back at their previous meeting...the Grand Final of PTT2!
...but we€™re finally about to fill the last place in our Series Semi-Finals! Once again, Gilbert and Roper meet in another Clash of the Titans, but who will triumph this time - the 5-way newbie clusterbot or the ram-happy 2nd seed? Our Final Heat Final will provide us with an answer...
), the No.2 seed tries a new tactic - as the 2 Lightweights get closer, the PTT2 runner-up uses its six wheels to swing right round and strike both cluster pieces with the dreaded flywheel!! While one member is scarred, but safe, the already wounded segment looks worse for wear...due to the fact that only one side seems to be working!!! SpunOut revs up the disc again and dodges another joint assault, as Refbot starts to count out the half-immobile Lightweight!!!
The No.2 seed falls victim to the quintuplets€™ ruthless teamwork and misses out on the title a second time!
(roughly translated as €œHow are you finding the tournament€™s writing up until now?€Â) Pros, cons, the good times, the bad times, the top fights, the plop fights
- ANY views on the tourney thus far will be more than welcome!
