Robot SMASH!! III: Lock3d and Load3d
PsycloniZer vs. Eye of Ran vs. Storm II vs. With or Without You
Indeed I shall team up with Eye of Ran. If Typhoon 2 could cause damage to Storm II, Im pretty sure PsycloniZer can do the same. Spin up to full speed and try and knock those pannels off. There are quite a few edges to attack. Without You apparently only has 180o of protection against opponents under 200mm in height. Well it just so happens PsycloniZer is 175mm in height
So if I can get to those unprotected areas, the 4mm Aluminium is at my mercy. And once one part is out, both parts are out.
Looks like another great tournament. Good luck to all.
