Robot SMASH!! III: Lock3d and Load3d
We€™re the ones with the CRASH!!
We€™re the ones with the BASH!!
We are the ones that take out the TRASH!!
And you€™ll never escape from Robot SMASH!!
*Jonathan Pearce and Henry Rollins appear in the SMASH!! Box, suspended 10 feet above the Robotagon itself with screens behind them showing lists of robots and battles*
JP: And so we here now at the heat A final.
Henry: The two seeded robots of Heat A have made it here, reigning champion PsycloniZer and seventeenth seed ISDSFA.
JP: In round 1 the champion teamed up with Eye of Ran to take out With or Without You, but Storm II pitted Eye of Ran to go through.
Henry: In the other eliminator ISDSFA flipped Robo-Sheep out of the arena before confining Ramminator 1 ½ to the pit.
JP: In round 2 PsycloniZer took out newcomer Agro 3.5.
Henry: And ISDSFA pitted former grand finalist Storm II.
JP: Now both machines are here at the final, I€™m betting PsycloniZer will win through.
Henry: I think the surprise and ISDSFA will prevail.
JP: Let€™s get down to the Robotagon and see!
Battleboard
PsycloniZer (1) vs. ISDSFA (17)
*Henry appears in the middle of the Robotagon with the robots in their starting squares and the Roboteers on either side of him*
Henry: This is a Robot SMASH!! Series 3: Lock3d and Load3d Heat A round 3 match-up!
In the Red Corner, seeded number #1, PsycloniZer!
In the Blue Corner, seeded number #17, ISDSFA!
Roboteers, standby!
Booth Red: Andrew Jackson
Booth Blue: Frank Goacher
House Robot: Shunt (Robot Wars)
#5...
#4...
#3...
#2...
#1...
#SMASH!!
Both seeded robots get off the mark relatively quickly as the green light is shown, with PsycloniZer€™s two wheel drive allowing it the mobility it needs to dodge away from ISDSFA€™s opening onslaught which is a dangerous box-rush right at the start of the match and get that dangerous ring up to full speed, but the hardox front scoop of ISDSFA is virtually un-damageable and Frank follows the champion, bashing it with the scoop and causing one of the hammers to hit the ground, stopping the ring in its tracks and knocking PsycloniZer away across the arena floor. The seventeenth seed follows up the attack, driving in underneath the ground clearance of PsycloniZer and pushing it across the arena floor and up against the arena wall, lifting it up onto the barrier only for Andy to quickly drive back down and away across the arena floor before the three hammers become a dangerous blur once more, but still the lynch motors in ISDSFA€™s drive are powerful and fast and are gunning the Behemoth-shaped machine across the arena at the reigning champion, who once again has it€™s weaponry stopped in its tracks and is knocked into the spike strip! ISDSFA follows up the attack and drives in underneath PsycloniZer again, pushing Andy across the Robotagon and into the CPZ! Shunt attacks, bringing the diamond-edged axe down onto the top of PsycloniZer, snagging a wheel hole! The scoop lifts PsycloniZer and Shunt holds the champion in mid-air, reversing across the arena before turning on the spot to suspend PsycloniZer over the pit for a few moments before dumping it onto the flame pit and reversing back into his CPZ. PsycloniZer is undamaged by the flames, but ISDSFA comes in again and making good use of the linear actuators flips PsycloniZer up and over and brings the flywheel into play, the 8 Kj€™s not damaging the underside of PsycloniZer and missing the tyres completely, but throwing Andy a little away from ISDSFSA and onto the closed pit. Frank makes a beeline for the release button, hoping to quickly confine the number #1 seed to the depths of the chasm and although the release button is pressed PsycloniZer is away from the pit and has the spinning ring up to a violent pace courtesy of the lynch motor that drives it. Frank comes on another thundering box rush, but Andy side steps him this and slams into the side of the hardox machine, knocking off the side panel completely and sending Frank flying across the arena and into the spike strip! CRASH! PsycloniZer runs in behind the dazed ISDSFA now and before Frank can put his motors in reverse and push Andy away nudges the seventeenth seed into the CPZ! Shunt whacks the top of ISDSFA with his axe and Frank drives forward, getting his own scoop under Shunt€™s and lifting the lightweight house robot up and over onto his back! Shunt is out of the equation, but PsycloniZer has been given time to spin up again while ISDSFA defended itself from Shunt and now slams into the rear of the series 1 bronze medallist, knocking off another panel (the rear one this time) and sending ISDSFA flying into the spike strip again! CRASH! And this time when Frank tries to get ISDSFA back on the attack there is no response down there in the arena, it seems ISDSFA isn€™t moving for some reason! Refbot moves in and nudges the Behemoth-shaped robot, pushing it against the spike strip to see if ISDSFA makes an attempt to escape, but not even the weaponry is moving and so Refbot begins the count.
ISDSFA is down and out of the competition, although with Shunt on its back there is now house robot to deliver any more pain and ISDSFA is saved by the bell.
CEASE!
ISDSFA (17) doesn€™t stand at all anymore; PsycloniZer (1) storms on through to the heat final!
Heat B:
Nidhogg Evo (3) vs. 259 vs. Exertion vs. Masamune
Sheer Heart Attack 2 (19) vs. GBOD vs. Lethal Execution vs. Supernova
JP: We€™ll be back...
Henry: Next time!
Battleboard
Roboteers, standby!
#5...
#4...
#3...
#2...
#1...
#SMASH!!
CEASE!
Heat B:
Henry: Next time!
