Robot SMASH!! III: Lock3d and Load3d
  • #31
    TEAM BRAVEHEART
    1. Wedge Devolution
    2. Killotine: EVO
    3. Spin Dash Unleashed
    4. Whirligig 4.5
    5. E Clawdius Unum
    6. Turbo Tails
    7. Traffic Warden
    8. 13 Black (RW Ex 2)
    STATS:
    1. Wedge Devolution
    SHAPE- low wedge with sloped rear
    COLOUR- sleek and shiny silver
    WEIGHT- about 100kg
    DIMENSIONS- 90cm X 75cm X 30cm
    SPEED- 16mph
    TURNING CIRCLE- 0
    GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
    ARMOUR- 4mm Hardox
    WHEELS- inside robot, 4-wheel drive
    POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
    WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
    SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
    NOTES- flashing red light on top of robot, flies Scotland flag
    STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
    WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers :P)
    http://img166.imageshack.us/img166/7555/wedgedevolutionza6.pnghttp://img166.imageshack.us/img166/7...olutionza6.png
    2. Killotine: EVO
    SHAPE- compact box-wedge ala Storm 2, rounded back
    COLOUR- red
    WEIGHT- about 100kg
    DIMENSIONS- 100cm X 70cm X 35cm
    SPEED- 16mph
    TURNING CIRCLE- 0m
    GROUND CLEARANCE- virtually 0mm at the front with spatula, 10mm at sides and back. Skirts at sides and back produce 0mm.
    ARMOUR- 3.25mm Hardox
    WHEELS- inside robot, 4WD
    WEAPONS- The main weapon is the large pneumatic axe, composed of 3.5mm hardox. It is very similar to that of Killerhurtz and operates with a rack-and-pinion system like Terrorhurtz. Running on 160psi, the axe runs off an 80mm X 20mm ram and stores its gas in a 2kg main bottle and 1kg buffertank. If anything goes wrong with the axe, Killotine can use its great pushing power to simply ram its opponents to death.
    SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. Also, just like the original Killotine, the machine has a rounded back and a red semi-sphere on either side of robot to stop it getting beached.
    NOTES- flies the Scotland flag, thanks to Tom, Aaron & AJ for helping with the design
    STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
    WEAKNESSES- so-so turning, limited gas supply
    http://img511.imageshack.us/img511/8806/killotineevocw0.pnghttp://img511.imageshack.us/img511/8...tineevocw0.png
    3. Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
    SHAPE- skirted box, with rounded sides and back.
    COLOUR- dark blue bodywork, with red-and-white striped skirting.
    WEIGHT- about 100kg
    DIMENSIONS- 100cm X 75cm X 20cm
    SPEED- 16mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
    ARMOUR- 4mm Hardox
    MOVEMENT- inner, 6WD
    POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
    WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
    SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
    NOTES- flies Scotland flag.
    STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
    WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
    http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
    4. Whirligig 4.5 (sort of formerly Whirligig 4.0)
    SHAPE- flat disc
    COLOUR- gold with Mauler-style scary face on top. The face shows the direction of the robot.
    WEIGHT- about 100kg (see bottom)
    DIMENSIONS- 101.6cm diameter X 12.7cm
    SPEED- 15mph
    TURNING CIRCLE- 0
    GROUND CLEARANCE- 8mm
    ARMOUR- 1.905 cm thick Grade 5 titanium
    FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
    POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
    WEAPONS- The main weapon on Whirligig is the spinning outer ring, fitted with 9 x Pussycat-style claws. The spinner is powered by an LEM-130 running at 36v. It can reach speeds of 1000rpm and produce up to 100kJ...more than enough to kill another bot at full speed.
    As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
    SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
    NOTES- flies Scotland flag, thanks to AJ, my first properly calculated machine
    STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
    WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
    WEIGHT CHECK:
    armour = 33.72kg (inc blades)
    chassis, mounts, bracing etc = about 30kg
    drive and weapon motors = 12kg overall
    NiCads = about 15kg
    feet = about 10kg overall
    TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule. Probably.
    http://img137.imageshack.us/img137/1297/whirligig45xt7.pnghttp://img137.imageshack.us/img137/1...ligig45xt7.png
    5. E Clawdius Unum (formerly Clawdius Decimus Murderous)
    SHAPE- skirted wedge with small box section and rounded back
    COLOUR- deep green with red shield emblazoned on the wedge, depicting a gold lion with a crown
    WEIGHT- about 100kg
    DIMENSIONS- 95cm X 70cm X 40cm
    SPEED- 14mph
    TURNING CIRCLE- 0m
    GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
    ARMOUR- 4mm Hardox
    POWER- 2 X S28-400 MagMotors
    WEAPONS- The main weapon, as ever, is the hydraulic diamond-tipped crushing claw. It is powered by a Vivoil pump with an 80mm x 40mm ram, with a 2kg tank for storing the hydraulics. The claw runs at 3000psi and, aided by the diamond tip, should be able to leave plenty of holes in another robot.
    The front wedge also features a Firestorm-style blade and two flat spears to aid in getting under the opposition. The wedge itself is now home to several Mute-style barbs to help ensnare other robots.
    SRIMECH- A rear-hinged pneumatic arm on either side, powered by a pair of linear actuators. The rounded rear also prevents the robot getting beached.
    NOTES- flies the Scotland flag, thanks to AJ, et tu, Brute? written on the underbelly
    STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fairly quick srimech
    http://img137.imageshack.us/img137/1801/eclawdiusunumor1.pnghttp://img137.imageshack.us/img137/1...iusunumor1.png
    6. Turbo Tails
    SHAPE- short box with front wedge, sloped sides & rounded rear
    COLOUR- yellow with the foxs face looking particularly evil on the front slope
    WEIGHT- approx 100kg
    DIMENSIONS- 100cm X 75cm X 25cm
    SPEED- 16mph
    TURNING CIRCLE- 0m
    GROUND CLEARANCE- approx 0mm at front (titanium blade), 8mm everywhere else
    ARMOUR- 3.5mm monocoque Hardox, with 2mm yellow fur over that.
    MOVEMENT- 4 inner wheels
    POWER- 2 x C40-500 MagMotors. Can produce approximately 12hp.
    WEAPONS- Tails chief weapon is the horizontal spinning blade. Now mounted on top, its a bit heavier than before and has Fluffy-style heads instead of the old hammers. Its powered by an LEM-130 running at 36v and has top speeds of around 2500rpm, so its definately just as deadly as before - if not, more so!
    The front wedge also hosts a forward-hinged flipping arm, powered by an 80mm x 20mm full-pressure CO2 ram. The arm operates at 750psi, giving it a fair bit of oomph, and stores its gas in a 2kg main bottle. Capable of just over 30 fires per fight.
    SRIMECH- The flipper. Sloped sides and rounded rear also prevent it getting beached.
    STRENGTHS- weapons synergy, touger armour, fast, fairly compact, greater pushing power
    WEAKNESSES- not quite as manouverable as before, flammability, wholl take it seriously?
    http://img84.imageshack.us/img84/7952/turbotailslongered5.pnghttp://img84.imageshack.us/img84/795...slongered5.png
    7. Traffic Warden (HW)
    SHAPE- rigid U shape, rounded rear
    COLOUR- black with a yellow stripe
    WEIGHT- 100kg, I hope
    DIMENSIONS- 95cm X 150cm X 25cm
    SPEED- 15mph
    TURNING CIRCLE- 0mm
    GROUND CLEARANCE- 10mm
    ARMOUR- 4mm Grade 5 titanium
    MOVEMENT- four inner wheels
    POWER- 2 x Etek-RT motors, running at 48v and producing 38hp.
    WEAPONS- Two vertical hydraulic clamps within the middle of the machine. Each clamp is powered by an 80mm x 40mm ram operating at 3000psi, delivering up to 10 tonnes of crushing power. When an opponent slips into the middle, the clamps activate and hold them in place. Traffic Warden can then drag them around and shove them into the nearest arena hazard. Think of it as Huggy Bear on steroids.
    SRIMECH- invertible, rounded rear should prevent it getting beached
    NOTES- flies Scotland flag, super special awesome thanks to Daniel Stickler, Martijn and AJ for helping with the design
    STRENGTHS- good traction, tough shell, fairly manoueverable, nippy, powerful grip
    WEAKNESSES- untested weapon, exposed ground clearance
    http://img381.imageshack.us/img381/1130/trafficwardenfinalto6.pnghttp://img381.imageshack.us/img381/1...enfinalto6.png
    Hope thats all OK, Liam. Should be another belter of a contest.
    BTW, since youre asking for spare House Robots, Id be happy to donate some of the Team Coldheart players. :wink:
    • #32
      Looks great Steven
      • #33
        Take any housies you want from Team DarkZlayerz, Liam.
        • #34
          You can have some of mine as well
          (Message edited by neontetra23 on September 26, 200
          • #35
            New vapour done...actually something else was planned but mysterious circumstances and events that shall become clearer very shortly disrupted that, so I threw something together very quickly:
            Lights! Camera! Traction! (credit to Matty for the name)
            DIMENSIONS: 100 x 80 x 20 cms
            SHAPE: Box with front wedge
            COLOUR: Yellow and black chevrons
            DRIVE: 2 wheelchair motors on four wheel drive from 2 SLA batteries at 24v, the wheels are some ones nicked from a wheelbarrow and are inside the robot for protection from side attacks.
            SPEED: 8mph
            GROUND CLEARANCE: 10mm all around, except the front which is 0
            ARMOUR: 10mm 2014 T6 aluminium monocoque with the top plate being 5mm 2014 aluminium and 5mm polycarbonate bonded together
            WEAPONS: None
            SRIMECH: Invertible
            STRENGTHS: Moves
            WEAKNESSES: Lack of weaponry
            • #36
              How much does it weigh?
              And also Samuel needs to know Reventon and Ramminator 1 1/2 are identical except for saw blade/disc, they are not accepted by the identical entry rule
              • #37
                It weighs on the right side of 100kg :P
                And as for the project mentioned above, due to lots of last minute things and machinations of thingies that caused stuff to happen, I am leaving Lights! Camera! Traction! in my squad as Ive posted it now and it deserves at least one fight Instead, I would like STAT to be withdrawn and replaced with a Team Britespark/Team Chevron collaboration (or, if you prefer to look at it differently, a Joey/Dan collaboration), Hex Appeal.
                http://strickenone.proboards99.com/index.cgi?board=teambv&action=display&thread=476&p age=1http://strickenone.proboards99.com/i...isplay&thread= 476&page=1
                http://www.youtube.com/watch?v=vMSHBRI3skQhttp://www.youtube.com/watch?v=vMSHBRI3skQ for how the walking system works, its slightly simplified so it doesnt stand up/sit down but it was legal last time I checked.
                • #38
                  Official Team BriteSpark Lineup!
                  *Supreme
                  *Dervish: The l337 Generation (stats should be up by the time the tourney starts!)
                  *Monsoon Magnum
                  *Pure Evil: Back to Basics
                  *Squish Reincarnated
                  *Macbeth
                  *Requiem (the 100kg version)
                  *Compulsory Realie - Terrorhurtz (RR version, or S6 version if that is easier).
                  There is a picture of the new Dervish on ZED, but stats are not finished yet. Should be done by Wednesday.
                  http://strickenone.proboards99.com/index.cgi?board=teambvhttp://strickenone.proboards99.com/i...i?board=teambv
                  • #39
                    Make that done now.
                    • #40
                      Of course, if there is a place for me, Im in!
                      PsycloniZer
                      Axeon 3.0
                      SOR X
                      Ge5orce
                      Monolith
                      Rupture
                      Exertion
                      Tornado (RW7)
                      Stats are http://strickenone.proboards99.com/index.cgi?board=ajhw
                      • #41
                        Actusally, swap Reventon for Shredding Madness.
                        Stats:
                        Shredding Madness (Previously Turbo Shredder)
                        Body Shape: Box
                        Weight: 100 kgs
                        Top Speed: 15 mph
                        Dimensions: 96 X 93 X 42
                        Armour: 3.25mm Hardox All Around
                        Ground Clearence: 5mm all around
                        Wheels: 4 X Wheels Inside (Aluminum Hub)
                        Power: 2 X LEM-130s running on 36 volts
                        Battery: 4 X BPK-3600-36 BattlePacks
                        Weapons: A very nasty 25kg, 3000RPM horizontal spinning disc made out of titanium, and 4 X Hardox Teeth. powered by a LEM-130 on 36V, Heavily Shock-Proofed as well
                        Srimech: Invertible
                        Strengths: Powerful Weapon, Great Pushing Power
                        Weaknesses: None Hopefully
                        • #42
                          1) Joey McConnell
                          a- Nidhogg Evo
                          b- Gabriel III
                          c- Eye of Ran
                          d- No Consequences
                          e- Stiltskin
                          f- Hex Appeal
                          g- Lights! Camera! Traction!
                          h- Gemini (RW5)
                          2) Paul Cuomo
                          a- Knyfe
                          b- Heyght II
                          c- Inferno
                          d- The Rock
                          e- Nitro-Gene 5.0
                          f- MeCannibal 3.0
                          g- WORCK-ER
                          h- Storm II
                          3) Christopher Mason
                          RESERVED
                          4) Martijn M Benschop
                          a- Back to Rock III
                          b- Flick of the Wrist 2
                          c- Liar 2
                          d- Axe to Fall 2
                          e- Sheer Heart Attack 2
                          f- Under Pressure
                          g- With or Without You
                          h- Razer
                          5) Richard Southworth
                          a- ???
                          b- ???
                          c- ???
                          d- ???
                          e- ???
                          f- ???
                          g- X-Terminator (RW7)
                          h- Nightmare (BB5.0)
                          6) Samuel Park
                          a- Deadbeat
                          b- Paralyzation 2
                          c- Bubonic Palgue
                          d- Fatality
                          e- Walk Dont Run 4
                          f- Shredding Madness
                          g- Ramminator 1 1/2
                          h- Tsunami (RW7)
                          7) Kody Kunz
                          a- Wedginator Devilution / Wedgin8or
                          b- Super Gore Revo
                          c- Seung Mina V
                          d- Tira IV
                          e- Killobite Hex
                          f- Macduff the 3rd / 4th
                          g- Intriguer
                          h- Envy
                          Daniel Stickler
                          a- Supreme
                          b- Dervish: The I337 Generation
                          c- Monsoon Magnum
                          d- Pure Evil: Back to Basics
                          e- Squish Reincarnated
                          f- Macbeth
                          g- Requiem
                          h- Terrorhurtz (Most recent)
                          9) Ben Read
                          a- Robo-Hedgehog
                          b- Robo-Mosquito
                          c- Robo-Platypus
                          d- Robo-Mammoth
                          e- Robo-Bee
                          f- Robo-Panda
                          g- Robo-Sheep
                          h- Axe Awe (RW5)
                          10) Alex Holt
                          a- Black Panther
                          b- Achilles
                          c- Tengu VII
                          d- Dante
                          e- Darkestar
                          f- Slammer VI
                          g- Baldur Gamma
                          h- Supernova
                          11) Steven McGregor
                          a- Wedge Devolution
                          b- Killotine: EVO
                          c- Spin Dash Unleashed
                          d- E Clawdius Unum
                          e- Turbo Tails
                          f- Whirligig 4.5
                          g- Traffic Warden
                          h- 13 Black (Extreme 2)
                          12) Danny Bailey
                          a- Crimson Thunder
                          b- Cat with Wheels
                          c- Sithis
                          d- Leviathan
                          e- Lethal Execution
                          f- Blue Sparks
                          g- Death Threat 0.2
                          h- Chaos 2 (Extreme 2)
                          13) Frank Goacher
                          a- Cobalt
                          b- Dead Horse Beater
                          c- The 6isc
                          d- ISDSFA
                          e- Sakura
                          f- Masamune
                          g- The May Tracks Has You
                          h- Firestorm (RW7)
                          14) Leo Van Miert
                          a- Mantis
                          b- Sideswipe
                          c- Eternia
                          d- Holepunch 2.0
                          e- Splinter
                          f- Obsidian
                          g- Symmetry
                          h- GBOD
                          15) Andrew Jackson
                          a- PsycloniZer
                          b- Axeon 3.0
                          c- SOR X
                          d- Ge5orce
                          e- Monolith
                          f- Rupture
                          g- Exertion
                          h- Tornado (RW7)
                          Just realised I counted Martijn twice by mistake, (sorry!) so there is a place still left in, and thankyou to those who are lending HRs
                          • #43
                            The open spots will become realie teams if they are still open when I get stats from Richard and Chris
                            • #44
                              Here are my six vapours:
                              Agro 3.5
                              Battle Raptor V
                              Dendroaspis
                              Drilla Killa VII
                              MORD2
                              SYNDOS
                              AGRO 3.5
                              Weight: 100kg
                              Shape: Low invertable wedge with a low square hinged plate at the front
                              Dimensions: 85 x 65 x 40 (cm; l x w x h)
                              Speed: 17mph
                              Ground Clearance: 0 at front due to hinged plate, 1cm at sides and rear
                              TC: 0
                              Armour: 4mm Hardox
                              Wheels: 2, inside robot, and RC gyro for added control
                              Power: 2 Perm 080s motors on 24V powered by 24V @ 12amp batteries
                              Weapon: The hinged plate at the front allows 0 ground clearance - it can surpass skirts with a good push. At the rear is a 10kg 3000RPM X Terminator-like vertical spinning disc at the rear, made of titanium and powered by a D-Pack.
                              Srimech: Invertable.
                              Tactics: Try to get under opponents and shove, or use the rear disc on them.
                              Strengths: Fast, manouverable, dangerous weaponry
                              Weaknesses: A little tricky to control, high ground clearance
                              BATTLE RAPTOR 5
                              Weight: 100kg
                              Shape: Invertable box with Tornado-like central bars on sides and rear (to prevent it resting there), painted orange with black stripes like the raptors in Jurassic Park
                              Dimensions: 80 x 50 x 30
                              Speed: 17mph
                              Ground Clearance: 0 at front due to low plate, 3mm at sides and rear
                              TC: 0
                              Armour: 4mm Hardox, with holes drilled in it to reduce weight
                              Wheels: 4, inside robot, poke out the top so the robot can run inverted, uses skid steering
                              Power: 4 Perm 080s motors on 24V powered by 24V @ 12amp batteries
                              Weapons: On the front are two electrically powered Vlad the Impaler-style lifting forks - attached to their tips is a plate which runs flat along the floor for 5cm, to get under skirts. On top is a titanium pneumatic axe with a Terrorhurtz-style blade, which pivots at a point about 1/4 of the robots length from the front.
                              Srimech: Axe can act as srimech. Axe blade fits inside the robot and doesnt poke out the top, so can run inverted if axe fails in resting position.
                              Tactics: Try to lift opponents while hammering them.
                              Strengths: Dual weaponry, invertable, fast and manouverable due to skid steering and lack of skirts
                              Weaknesses: Limited CO2 for axe, no weaponry at sides and rear, easily flipped
                              DENDROASPIS
                              Weight: 97kg
                              Shape: High wedge with two large enclosed wheels, painted black
                              Dimensions: 80 x 50 x 45
                              Speed: 20mph
                              Ground Clearance: 0 at front due to hinged plate, 0 at rear due to skirt, 1cm at side and behind skirt
                              TC: 0
                              Armour: 6mm Hardox - rear skirt is 3mm titanium
                              Wheels: 2 stuffed tyres inside robot, and RC gyro for added control
                              Weapon: Two electrically powered arms with stabilising wheels, one on the top wedge and one on the bottom, similar to Cuad the Crusher - the arm at the bottom lifts the whole wedge to overturn a robot thats on it. There is also a static spike on the left and right sides, which can be used when the robot raises itself and spins on the spot.
                              Srimech: Invertable
                              Tactics: Get under opponents with the hinged plate at the front, and lift to overturn them. Can also try to cause damage with the spikes by spinning, or push with the rear skirt.
                              Strengths: Fast, manouverable, versatile
                              Weaknesses: Lack of damaging weaponry, easily flipped from sides
                              DRILLA KILLA 7
                              Weight: 99kg
                              Shape: Low invertable box, painted red, with a Tornado-like low wedge at the front, and an upside down one at the back for when the robot is upside down, and skirts at the sides fixed at the centre so they work whichever way up the robot is
                              Dimensions: 110 x 40 x 25
                              Speed: 17mph
                              Ground Clearance: 0 at front due to wedge; 0 at sides due to skirts, 3mm behind skirts, 25cm at most at back due to inverted wedge
                              Turning Circle: 2cm
                              Armour: 5mm Hardox
                              Wheels: 6, inside robot
                              Weapon: Each wedge has a hole in the centre - inside each hole is a diamond tipped drill, spinning at 600 rpm, which comes out of the hole using a motor. It can come out to cause damage when an opponent is on the wedge, or can stay out and cause damage when the robot rams opponents.
                              Srimech: Invertable; cannot rest on sides due to skirts
                              Tactics: To get under unskirted opponents, slam them around and bring out the drills to damage their underbellies; to ram skirted opponents with the drills out and try to cause damage
                              Strengths: Good pushing power
                              Weaknesses: Drills may not penetrate very thick armour; high ground clearance at back
                              M.O.R.D2
                              Weight: 110kg
                              Shape: Box, with sides that slant outwards from the top and bottom edges to form triangles, like Tornados rear (hopefully this will lower the effectiveness of spinners)
                              Dimensions: 90 x 32 x 35
                              Speed: 20mph
                              Ground Clearance: 0 at front due to plow, 0 at sides and rear due to skirts, which are fixed to the points of the triangles and can work either way up, 4mm behind skirts
                              TC: 5cm
                              Armour: Body is 4mm Hardox; scoop is 4mm titanium; skirts are 3mm titanium
                              Movement: Camshafts like Drillzilla
                              Weapons: At the front is an electrically powered scoop which operates through 180 degrees, so it can work when the robot is inverted. Behind the scoop is a 20kg spinning drum with 8 titanium teeth on it, spinning at 2000rpm and hopefully able to flip robots as well as damage them. The drum comes into play if the scoop is lifted.
                              Srimech: Invertable; triangles at sides and rear prevent it resting there
                              Tactics: Shove opponents with the scoop; then lift the scoop and attack with the drum
                              Strengths: Fast; good traction; powerful drum
                              Weaknesses: Less manouverable than wheeled robots
                              SYNDOS (SLICE N DICE ON STEROIDS)
                              Weight: 96kg
                              Shape: Invertable box with rounded sides and rear
                              Dimensions: 60 x 60 x 45
                              Speed: 12mph
                              Ground Clearance: 4mm at front, 0 at sides and back due to skirts, 4mm behind skirts
                              TC: 0
                              Armour: 4mm Hardox
                              Wheels: 2, inside robot, with RC gyro for extra control
                              Weapon: 25kg 3000rpm titanium vertical spinning disc at front
                              Srimech: Invertable
                              Tactics: Mash with big-a** disc, and try to flip as well.
                              Strengths: Powerful weapon; low ground clearance
                              Weaknesses: No weapons on sides and rear; a bit on the slow side
                              • #45
                                Oh Ill enter, go on
