Robot SMASH!! III: Lock3d and Load3d
TEAM BRAVEHEART
1. Wedge Devolution
2. Killotine: EVO
3. Spin Dash Unleashed
4. Whirligig 4.5
5. E Clawdius Unum
6. Turbo Tails
7. Traffic Warden
8. 13 Black (RW Ex 2)
STATS:
1. Wedge Devolution
SHAPE- low wedge with sloped rear
COLOUR- sleek and shiny silver
WEIGHT- about 100kg
DIMENSIONS- 90cm X 75cm X 30cm
SPEED- 16mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
ARMOUR- 4mm Hardox
WHEELS- inside robot, 4-wheel drive
POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
NOTES- flashing red light on top of robot, flies Scotland flag
STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers :P)
http://img166.imageshack.us/img166/7555/wedgedevolutionza6.pnghttp://img166.imageshack.us/img166/7...olutionza6.png
2. Killotine: EVO
SHAPE- compact box-wedge ala Storm 2, rounded back
COLOUR- red
WEIGHT- about 100kg
DIMENSIONS- 100cm X 70cm X 35cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front with spatula, 10mm at sides and back. Skirts at sides and back produce 0mm.
ARMOUR- 3.25mm Hardox
WHEELS- inside robot, 4WD
WEAPONS- The main weapon is the large pneumatic axe, composed of 3.5mm hardox. It is very similar to that of Killerhurtz and operates with a rack-and-pinion system like Terrorhurtz. Running on 160psi, the axe runs off an 80mm X 20mm ram and stores its gas in a 2kg main bottle and 1kg buffertank. If anything goes wrong with the axe, Killotine can use its great pushing power to simply ram its opponents to death.
SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. Also, just like the original Killotine, the machine has a rounded back and a red semi-sphere on either side of robot to stop it getting beached.
NOTES- flies the Scotland flag, thanks to Tom, Aaron & AJ for helping with the design
STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
WEAKNESSES- so-so turning, limited gas supply
http://img511.imageshack.us/img511/8806/killotineevocw0.pnghttp://img511.imageshack.us/img511/8...tineevocw0.png
3. Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
SHAPE- skirted box, with rounded sides and back.
COLOUR- dark blue bodywork, with red-and-white striped skirting.
WEIGHT- about 100kg
DIMENSIONS- 100cm X 75cm X 20cm
SPEED- 16mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
ARMOUR- 4mm Hardox
MOVEMENT- inner, 6WD
POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
NOTES- flies Scotland flag.
STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
4. Whirligig 4.5 (sort of formerly Whirligig 4.0)
SHAPE- flat disc
COLOUR- gold with Mauler-style scary face on top. The face shows the direction of the robot.
WEIGHT- about 100kg (see bottom)
DIMENSIONS- 101.6cm diameter X 12.7cm
SPEED- 15mph
TURNING CIRCLE- 0
GROUND CLEARANCE- 8mm
ARMOUR- 1.905 cm thick Grade 5 titanium
FEET- inside robot, uses 4 DrillZilla-style shuffling plates. These help prevent the bot being flung halfway across the ring on contact with another bot, ala Typhoon
POWER- 2 X S28-400s running on 36v. Uses 120 X NiCad cells at 36v, producing 12amps at 36v overall for drive and weapon power
WEAPONS- The main weapon on Whirligig is the spinning outer ring, fitted with 9 x Pussycat-style claws. The spinner is powered by an LEM-130 running at 36v. It can reach speeds of 1000rpm and produce up to 100kJ...more than enough to kill another bot at full speed.
As well as this, the power in the shuffling feet mean that Whirly can act as a pretty powerful pusher if the shell fails to work
SRIMECH- the robot is invertible and the blades prevent Whirly landing on his side
NOTES- flies Scotland flag, thanks to AJ, my first properly calculated machine
STRENGTHS- fast, manoeuvrable, very deadly weaponry, tough armour, scary face shows its direction, very good traction, cant be flung away on impact as easily as Typhoon
WEAKNESSES- so-so manoeuvrability, feet may prove vulnerable to crushers and axes
WEIGHT CHECK:
armour = 33.72kg (inc blades)
chassis, mounts, bracing etc = about 30kg
drive and weapon motors = 12kg overall
NiCads = about 15kg
feet = about 10kg overall
TOTAL WEIGHT = 100.72kg. Fits right into the roller limit, with the 1% error margin rule. Probably.
http://img137.imageshack.us/img137/1297/whirligig45xt7.pnghttp://img137.imageshack.us/img137/1...ligig45xt7.png
5. E Clawdius Unum (formerly Clawdius Decimus Murderous)
SHAPE- skirted wedge with small box section and rounded back
COLOUR- deep green with red shield emblazoned on the wedge, depicting a gold lion with a crown
WEIGHT- about 100kg
DIMENSIONS- 95cm X 70cm X 40cm
SPEED- 14mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- virtually 0mm at the front, 0mm at sides and rear thanks to skirts (arranged in a Biohazard fashion, corner-to-corner), 10mm without
ARMOUR- 4mm Hardox
POWER- 2 X S28-400 MagMotors
WEAPONS- The main weapon, as ever, is the hydraulic diamond-tipped crushing claw. It is powered by a Vivoil pump with an 80mm x 40mm ram, with a 2kg tank for storing the hydraulics. The claw runs at 3000psi and, aided by the diamond tip, should be able to leave plenty of holes in another robot.
The front wedge also features a Firestorm-style blade and two flat spears to aid in getting under the opposition. The wedge itself is now home to several Mute-style barbs to help ensnare other robots.
SRIMECH- A rear-hinged pneumatic arm on either side, powered by a pair of linear actuators. The rounded rear also prevents the robot getting beached.
NOTES- flies the Scotland flag, thanks to AJ, et tu, Brute? written on the underbelly
STRENGTHS- Quite nippy, good traction, powerful weapon, difficult to get underneath, fairly quick srimech
http://img137.imageshack.us/img137/1801/eclawdiusunumor1.pnghttp://img137.imageshack.us/img137/1...iusunumor1.png
6. Turbo Tails
SHAPE- short box with front wedge, sloped sides & rounded rear
COLOUR- yellow with the foxs face looking particularly evil on the front slope
WEIGHT- approx 100kg
DIMENSIONS- 100cm X 75cm X 25cm
SPEED- 16mph
TURNING CIRCLE- 0m
GROUND CLEARANCE- approx 0mm at front (titanium blade), 8mm everywhere else
ARMOUR- 3.5mm monocoque Hardox, with 2mm yellow fur over that.
MOVEMENT- 4 inner wheels
POWER- 2 x C40-500 MagMotors. Can produce approximately 12hp.
WEAPONS- Tails chief weapon is the horizontal spinning blade. Now mounted on top, its a bit heavier than before and has Fluffy-style heads instead of the old hammers. Its powered by an LEM-130 running at 36v and has top speeds of around 2500rpm, so its definately just as deadly as before - if not, more so!
The front wedge also hosts a forward-hinged flipping arm, powered by an 80mm x 20mm full-pressure CO2 ram. The arm operates at 750psi, giving it a fair bit of oomph, and stores its gas in a 2kg main bottle. Capable of just over 30 fires per fight.
SRIMECH- The flipper. Sloped sides and rounded rear also prevent it getting beached.
STRENGTHS- weapons synergy, touger armour, fast, fairly compact, greater pushing power
WEAKNESSES- not quite as manouverable as before, flammability, wholl take it seriously?
http://img84.imageshack.us/img84/7952/turbotailslongered5.pnghttp://img84.imageshack.us/img84/795...slongered5.png
7. Traffic Warden (HW)
SHAPE- rigid U shape, rounded rear
COLOUR- black with a yellow stripe
WEIGHT- 100kg, I hope
DIMENSIONS- 95cm X 150cm X 25cm
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 10mm
ARMOUR- 4mm Grade 5 titanium
MOVEMENT- four inner wheels
POWER- 2 x Etek-RT motors, running at 48v and producing 38hp.
WEAPONS- Two vertical hydraulic clamps within the middle of the machine. Each clamp is powered by an 80mm x 40mm ram operating at 3000psi, delivering up to 10 tonnes of crushing power. When an opponent slips into the middle, the clamps activate and hold them in place. Traffic Warden can then drag them around and shove them into the nearest arena hazard. Think of it as Huggy Bear on steroids.
SRIMECH- invertible, rounded rear should prevent it getting beached
NOTES- flies Scotland flag, super special awesome thanks to Daniel Stickler, Martijn and AJ for helping with the design
STRENGTHS- good traction, tough shell, fairly manoueverable, nippy, powerful grip
WEAKNESSES- untested weapon, exposed ground clearance
http://img381.imageshack.us/img381/1130/trafficwardenfinalto6.pnghttp://img381.imageshack.us/img381/1...enfinalto6.png
Hope thats all OK, Liam. Should be another belter of a contest.
BTW, since youre asking for spare House Robots, Id be happy to donate some of the Team Coldheart players. :wink:
TEAM BRAVEHEART
1. Wedge Devolution
2. Killotine: EVO
4. Whirligig 4.5
5. E Clawdius Unum
6. Turbo Tails
7. Traffic Warden
STATS:
1. Wedge Devolution
WEIGHT- about 100kg
SPEED- 16mph
TURNING CIRCLE- 0
ARMOUR- 4mm Hardox
2. Killotine: EVO
COLOUR- red
WEIGHT- about 100kg
SPEED- 16mph
TURNING CIRCLE- 0m
WEIGHT- about 100kg
SPEED- 16mph
TURNING CIRCLE- 0mm
ARMOUR- 4mm Hardox
SHAPE- flat disc
SPEED- 15mph
TURNING CIRCLE- 0
WEIGHT CHECK:
NiCads = about 15kg
WEIGHT- about 100kg
SPEED- 14mph
TURNING CIRCLE- 0m
ARMOUR- 4mm Hardox
6. Turbo Tails
SPEED- 16mph
TURNING CIRCLE- 0m
SPEED- 15mph
TURNING CIRCLE- 0mm
