Classic SMASH!!
  • Classic SMASH!!
    Right, this will take place after Team Builders (if that ever happens ) and before RS!!3
    I need 8 people to enter 2 robots each, preferably 1 vapour and 1 realie, but you can enter 2 realies if you want. In each heat there will be 4 robots, which will be wittled down to 3 after the gauntlet (robot with lowest distance is eliminated). Then down to 2 robots after the trial (see Trials) and then the remaining robots fight each other to gain a place in the series final, which will follow the same pattern.
    Weight Limits:
    80kg for wheeled/tracked robots (classic heavyweights! Yes I support Joey!)
    150kg for true walkers
    100kg for shufflers
    Flying robots are banned
    Clusterbots are allowed, but no more than three and each must make up an equal percentage of the robots overall weight.
    Battles
    You can win by:
    Flipping
    Stacking
    OOTA
    Pitting
    Critically impair opponent€™s motion (eg take out 50% of the drive)
    Completely immobilise opponent€™s drive
    You cannot pin an opponent for more than 30 seconds, the same goes for holding on with a weapon. Note however that this rule no longer applies to stacking.
    Each fight lasts 3 minutes maximum. If two or more robots are running at the end the fight will be judged on damage, aggression, control and dominance. Each is marked out of ten, and times on order of importance: Damage x 4, Aggression x 3, Control x 2, Dominance x 1
    Team Welsh Darklords (house robots)
    Robot Name: Furnace
    Shape: Low Dome with lots of holes
    Weight: 195kg
    Length: 105cm
    Width: 105cm
    Height: 20cm
    Motivation: 4 vulcanised titanium tracks, internal
    Drive: 4 LEM-130s at 48v
    Armour: 9mm hardox
    Weaponry: Out of the holes there are large bursts of flame, so basically there is a flamethrower within each one
    Speed: 25mph
    Ground Clearance: 7mm
    Turning Circle: 0
    Srimech: None
    Colour: A mix of yellow, orange and red
    Strengths: Hot!
    Weaknesses: Ground Clearance
    Robot Name: Psychopath
    Shape: Long wedge
    Weight: 290kg
    Length: 120cm
    Width: 95cm
    Height: 30cm
    Motivation: 10 inner vulcanised wheels
    Drive: 10 S28-400s at 24v
    Armour: 8mm hardox
    Weaponry: A 35kg hammer on the wedge, powered by a 100m x 120mm nitrogen ram at 2400psi, the gas is stored in 2 x 5kg tanks
    Speed: 25mph
    Ground Clearance: 0 at the front, 8mm at sides and rear
    Turning Circle: 0
    Srimech: Hammer
    Colour: Dark blue with a platinum hammer
    Strengths: Powerful weaponry
    Weaknesses: Huh?
    Robot Name: Sumo Shock
    Shape: Box with a front plough
    Weight: 160kg
    Length: 90cm
    Width: 95cm
    Height: 17cm
    Motivation: 4 x vulcanised titanium tracks, internal, but invertible
    Drive: 2 LEM-200s at 72v
    Armour: 6mm hardox
    Weaponry: Plough and pushing power
    Speed: 30mph
    Turning Circle: 0
    Ground Clearance: 0 at front, 6mm at sides and rear which is covered by 7mm hardox torsion sprung skirts
    Srimech: Invertible
    Colour: Light blue with the name in yellow on top
    Strengths: Pushing power
    Weaknesses: Nuh
    Robot Name: King
    Shape: Sir Killalot with a wedge at the rear
    Weight: 1000kg
    Length: 200cm
    Width: 200cm
    Height: 70cm
    Motivation: 6 x vulcanised titanium tracks, internal
    Drive: 8 LEM-200s at 60v
    Armour: 10mm hardox
    Weaponry: A large flywheel powered by 4 E-Teks in the rear wedge, plus the two arms at the front. The right one has a hydraulic claw at 5000psi and the other has another one, they rise high enough to right the robot
    Speed: Up to 40mph
    Ground Clearance: 10mm, but 0 at rear
    Turning Circle: 0
    Srimech: The arms and side pneumatic rams
    Colour: The colour of DEATH
    Strengths: Everything
    Weaknesses: None
    Robot Wars House Robots:
    Shunt
    Matilda
    Sergeant Bash
    Dead Metal
    Refbot (present in all battles)
    Sir Killalot
    Growler
    Mr. Psycho
    Stats
    This applies mostly to vapours. I know a lot of realies, but not every single one that ever existed so I if don€™t know much about a realie I will tell you, a video will usually suffice, but as long as you can give a description you should be OK. You only have to post a video or a description if I require one for one or more realies, I will let you know.
    You can set your stats out in any format, but they must include the following (please note one category- such as power- may contain both drive motor and batteries/voltage):
    Robot Name: What your robot is called
    Shape: What shape your robot is
    Weight: See weight limits
    Dimensions: Preferably in CM, l x w x h unless stated otherwise
    Motivation: Wheels/Tracks/Legs etc.
    Armour: What your robot is armoured with
    Weaponry: What weapons (if any) your robot has
    Speed: What speeds can it reach or what speed is its average?
    Ground Clearance: Remember if it is 0 all round you won€™t move, though you can make it 0 with skirts, though if you have skirts please state the clearance behind them
    Turning Circle: Most types are 0, unless you have car steering
    Colour: What colour(s) you robot is
    Srimech: What your robot has to right itself (if it can) or is it invertible?
    Please note that the following three are OPTIONAL:
    Strengths: Pros of your design
    Weaknesses: Cons of your design
    Notes: Anything else?
    Reservation Policy
    You can reserve a place in the competition, but it will be held only for 1 week. If anyone gets their stats in before you then it€™s whoever gets their stats in first gets the spot. Every time that the entry list is posted I will write next to your name how much time is left of your reservation
    The Arena
    The first SMASH!! Took place in a slightly modified version of the RW arena, but the second created the coliseum. Now we have an entirely new arena, the ROBOTAGON! This is a fairly small 12 metre x 12 metre octagon with two starting squares, a red in the top left corner and a blue in the bottom right corner. Each square is big enough for two robots. In the bottom left corner there is a pit, big enough for any robot. The release button is on the top wall. In the top right corner there is a hazard coloured semi-circle where a house robot will patrol. Surrounding the perimeter of the arena there is a strip of tungsten static spikes, and in the bottom side there is flame pit for all those comedy robots covered in fur... The walls are 50mm hardox and just 45cm high; the floor is stainless steel for plenty of magnetism
    The Gauntlet
    The gauntlet is 25 metres long and 30 metres wide, there are three routes to choose from:
    Left:
    First there 5 rows of glass walls, with some that will break and others that wont as they are macrolon in disguise! For rows of Macrolon walls there is a wall that will fall down upon impact, this must be found. After that there is a large square that belches flame from the floor, also there are killsaws hidden at various points. After this square there is a runway with a 50kg mace swinging up ahead courtesy of nitrogen at 2400psi. After that there is the finish line, guarded by Furnace
    Right:
    First off there is a long corridor with spikes that fire from the walls and can push you into the pits opposite them. There are five pits in total, and thus five spikes. After that there is a large quare made of several parts, some of which are neutral squares and others that are floor flippers that can potentially send you back ot the corridor and a sideways one that can flip you into the middle route! After this square there are three football goals with balls infront of them. The posts will retract into the floor when three goals are scored, allowing you to pass. Then there is the finish line, guarded by Psychopath.
    Middle:
    First off a narrow bridge with pits underneath, there are several coloured spots along that indicate a lifter spot. If you dont cross them fast enough then the lifter (hinged at the side) wiill activate, dropping you into the pit. There are three lifters in total. After that there is a turn table which must be crossed, but Sumo Shock stands in your way. After that you must pass King.
    You have just 45 seconds to complete the gauntlet. Each heat will be allocated a route except Heat 4, in which the participants can pick one of their choice.
    Trials
    Sumo Basho:
    Stay on the sumo plinth with Sumo Shock for as long as you can. The plinth is 10 metres in diameter, and the round ends either when:
    a) you are pushed off
    b) Sumo Shock is pushed off
    c) 1 minute passes
    King of the Hill:
    A light will shine on a space on the arena floor below, and the robot that is the last one in the square goes through. Basically you all run to get into the square, then try to get the other robots out. Takes place in the arena, with hazard inactive
    Football:
    The goal is protected by King, and the robot that doesnt score is out. This takes place in the arena with hazards inactive
    Tug of War:
    Against Sumo Shock, pull into the pit. Ends when:
    a) you are pitted
    b) Sumo Shock is pitted
    c) 1 minute passes
    So 8 people to enter 2 robots, realies can be from RW1 to 4, overweight realies are allowed if from those series, but you can only choose heavyweights and not lightweights like Cunning Plan etc.
    Get Entering!!!
    Classic SMASH!!
    [b]1. http://i276.photobucket.com/albums/k...er.pngJunkyard
      Classic SMASH!!
      I reserve a place! (going to design a new classic HW as Im not too sure if Boris is any good, therefore actual entries to be posted later)
      And looks good Liam.
        Classic SMASH!!
        Proof people dont read the opening post
          Classic SMASH!!
          Id like to reserve as well.
            Classic SMASH!!
            Reserve!
              Classic SMASH!!
              Entries
              1) Kody Kunz
              a- Junkyard Mawler
              b- Hypno-Disc (S4)
              2) Joey McConnell
              RESERVED (1 week left)
              3) Christopher Mason
              4) Ben Read
              Also Id like to add that your realie cant be an eariler or later version of a robot someone else has entered (e.g Kody has entered S4 Hypno-Disc, you cant pick the S3 version)
                Classic SMASH!!
                Spawn Again (S5)
                Wild Thing (S4)
                  Classic SMASH!!
                  Samuel, you cant use bots over 80kg. The Extreme 1 Spawn Again was (thanks Joey), and on account of that I expect the S5 version was. :P
                  (Message edited by kodster on September 20, 200
                    Classic SMASH!!
                    Joey (hell know ) how much did Spawn weigh in S5? I think it was 80kg Sam so you should be fine, just checking with the master
                      Classic SMASH!!
                      I want to reserve Cassius II?
                        Classic SMASH!!
                        I guess the question mark was a typo, lol
                        thats fine
                        Entries
                        1) Kody Kunz
                        a- Junkyard Mawler
                        b- Hypno-Disc (S4)
                        2) Joey McConnell
                        4) Ben Read
                        a- Cassius II
                        b- ???
                        5) Samuel Park
                        a- Wild Thing (S4)
                        b- ??? (according to Robot Wars: The Ultimate Guide Spawn Again was 84kg going into series 6, so it was probably a similar weight in series 5. Unless I can be proven wrong Samuel must replace this realie)
                        (Message edited by Swim2win on September 20, 200
                          Classic SMASH!!
                          Spawn Again...
                          http://www.youtube.com/watch?v=_spRxbMC5ckhttp://www.youtube.com/watch?v=_spRxbMC5ck
                          Yeah, its okay, I guess...
                            Classic SMASH!!
                            I am proven wrong
                              Classic SMASH!!
                              BAD TEMPER JR
                              Weight: 80 kilos
                              Body Shape: Rectangular, long and low. Similar dimensions to Tornado, but not invertible.
                              Speed: 12mph
                              TC: 0
                              GC: 7mm
                              Wheels: 4 inner
                              Armour: 6mm titanium
                              Power: 3x 12v batteries, powered by S28-400 Magmotors, at 24v...the usual.
                              Colour: Red underbelly, black sides, grey top, white weapon.
                              Weapon: Pneumatic knife blade, powered by CO2. Theres about 40 odd hits in it. Basically, it looks like someone stuck the blade of Overkill onto the axe arm of Dominator 2.
                              Srimech: The weapon goes that.
                              Notes: I have a little Lego model if you need pictures.
                              Strengths: Persistant.
                              Weaknessess: The arm is fairly long, so it has to be a distance away to work effectively.
                              My realie is Onslaught, preferably the S4 version (because of its display in the Annihilator)
