The Killer Toad Tournament - The Final Assault
    9 down, 8 to get (I think)
      Wedge, Killy and Spin Dash for me, please, Dave.
      STATS:
      1. Wedge Devolution
      SHAPE- low wedge with sloped rear
      COLOUR- sleek and shiny silver
      WEIGHT- about 100kg
      DIMENSIONS- 90cm X 75cm X 30cm
      SPEED- 16mph
      TURNING CIRCLE- 0
      GROUND CLEARANCE- 0mm at the front, 7mm for the rest of the robot. Fitted with Biohazard-style skirts on sides and rear, giving 0mm
      ARMOUR- 4mm Hardox
      WHEELS- inside robot, 4-wheel drive
      POWER- 2 X LEM-130s; 2 x 12v 3amp NiCad packs, giving 36v @ 12amp
      WEAPONS- As usual, the main weapon is a rear-hinged flipper. This is very similar to Chaos 2, except the blade at the bottom is bent ala Bigger Brother, allowing the flipper to have greater effect against bots with skirts or low centres of gravity. The flipper itself is powered by 2 X 80mm high pressure pneumatic rams, each running at 250psi. This should allow Wedge Devo to comfortably flip up to 1 tonne.
      SRIMECH- The flipper can right the machine easily and the rear wedge should hopefully prevent a Chaos-style self-flip. Also, Wedge Devo is equipped with a grey semi-sphere on either side of robot to prevent it getting stuck on its side
      NOTES- flashing red light on top of robot, flies Scotland flag
      STRENGTHS- powerful flipper, fast, manoeuvrable, difficult to get underneath, tough armour, good traction
      WEAKNESSES- could prove a bit tricky to control, limited CO2 (like all other flippers :P)
      http://img166.imageshack.us/img166/7555/wedgedevolutionza6.pnghttp://img166.imageshack.us/img166/7...olutionza6.png
      2. Killotine: EVO
      SHAPE- compact box-wedge ala Storm 2, rounded back
      COLOUR- red
      WEIGHT- about 100kg
      DIMENSIONS- 100cm X 70cm X 35cm
      SPEED- 16mph
      TURNING CIRCLE- 0m
      GROUND CLEARANCE- virtually 0mm at the front with spatula, 10mm at sides and back. Skirts at sides and back produce 0mm.
      ARMOUR- 3.25mm Hardox
      WHEELS- inside robot, 4WD
      WEAPONS- The main weapon is the large pneumatic axe, composed of 3.5mm hardox. It is very similar to that of Killerhurtz and operates with a rack-and-pinion system like Terrorhurtz. Running on 160psi, the axe runs off an 80mm X 20mm ram and stores its gas in a 2kg main bottle and 1kg buffertank. If anything goes wrong with the axe, Killotine can use its great pushing power to simply ram its opponents to death.
      SRIMECH- The axe. Even if it€™s already been fired while flipped, the axe can right itself ala Killerhurtz. Also, just like the original Killotine, the machine has a rounded back and a red semi-sphere on either side of robot to stop it getting beached.
      NOTES- flies the Scotland flag, thanks to Tom, Aaron & AJ for helping with the design
      STRENGTHS- Fast, dangerous weapon, good amount of traction, difficult to get under, quick srimech, nice and fast
      WEAKNESSES- so-so turning, limited gas supply
      http://img511.imageshack.us/img511/8806/killotineevocw0.pnghttp://img511.imageshack.us/img511/8...tineevocw0.png
      3. Spin Dash Unleashed (formerly Metal Sonic Spin Dash)
      SHAPE- skirted box, with rounded sides and back.
      COLOUR- dark blue bodywork, with red-and-white striped skirting.
      WEIGHT- about 100kg
      DIMENSIONS- 100cm X 75cm X 20cm
      SPEED- 16mph
      TURNING CIRCLE- 0mm
      GROUND CLEARANCE- virtually 0mm all round, 10mm at sides and rear without skirts.
      ARMOUR- 4mm Hardox
      MOVEMENT- inner, 6WD
      POWER- 2 x LEM-130s. These run at 36v and produce approximately 18hp.
      WEAPONS- A horizontal Pussycat-style saw blade on the front. The blade is mounted on the underbelly ala Code:BLACK and is designed to chew up skirts and wheels. It is powered by an S28-150 Magmotor and runs at 3000rpm. Its 18hp and shape also makes it an excellent battering ram.
      SRIMECH- invertible. The rounded sides and rear also prevent it getting beached.
      NOTES- flies Scotland flag.
      STRENGTHS- excellent traction, fast, tough armour, low weaponry, invertible
      WEAKNESSES- untested, so-so manoueverability, saw blade less effective upside-down
      PIC- http://img137.imageshack.us/img137/5359/spindash6ta1.pnghttp://img137.imageshack.us/img137/5...indash6ta1.png
        Flick of the Wrist (or perhaps even Flick of the Wrist 2 :wink
        Back to Rock III
        Liar 2
        http://strickenone.proboards99.com/index.cgi?board=thvapourshttp://strickenone.proboards99.com/i...oard=thvapours
        Gonna teach those kidnappers!
          Interesting...
          SOR X
          PsycloniZer
          Ge5orce
          http://strickenone.proboards99.com/index.cgi?board=ajhw
            Cat With Wheels,
            Crimson Thunder,
            Sithis,
            Stats in the same place as the two people above me.
              Ben R
              MC Franky G
              Paul C
              Liam
              Alex H
              Samuel
              Mart
              Dan (awaiting entries)
              Stevie
              AJ
              Danny B
              I make that 11 entries so far, so 6 more to get
                Since my earlier post got ignored...
                [b]1. http://i276.photobucket.com/albums/k...inaIV.pngSeung
                • #23
                  Sorry Kody :blush:
                  • #24
                    Hello?
                    • #25
                      hi
                      • #26
                        Be patient Paul
                        Its really rich of you to say that when EOTR is going the way it is
                        • #27
                          Hey Paul
                          5 more entries to get, if not, I could also give out byes in round 1.
                          • #28
                            hi
                            can i reserve a place, i have 1 vapour done but my others are being upgraded
                            jack
                            • #29
                              4 more entries to get
                              • #30
                                Can you swap Nitro-Gene 4.0 for the latest model please?
                                http://strickenone.proboards99.com/index.cgi?board=tivapours&action=display&thread=17 7&page=1http://strickenone.proboards99.com/i...n=display&thre ad=177&page=1
