I am running a new tournament:
Scrapyard Skirmish
I need 16 People to enter 8 robots, Minimum of 0 realies, Maximum of 2
The Line-up will be like this:
Heats:
16 heats of 8
1 robot goes out in the Gauntlet
1 robot goes out in the Trial
2 3-way melees, 2 go through
2 1-1 KO battles, 2 go through to the Semi-final
Semi-Finals:
4 Semis of 8 robots
2 4-way melees, 2 go through
1 4-way melee, 2 go through to Final
Grand Final:
1 goes out in Gauntlet
1 goes out in Trial
1 6-way melee to decide the winner
Arena: A 20X20 square box
Hazards: 2 CPZs, 1 in the top corner, 1 in the bottom, A spinning flywheel on the left wall of the arena, it spins at 5000RPM, A pit in the bottom left corner, below the pit there is a pair of hydraulic pincers that can push forward and pit the robot, there is a flipper in the top right hand corner and a drop zone just to the right of the centre of the arena, the house robots are 11 Deadly Sins, Zoo-Keeper and Cage (All on ZED)
Gauntlet: A 100X60 box
A circular cage at the start, there are three routes:
1) To the left, you must push a box up a ramp and into a hole, then drive over it onto another ramp, at the bottom of the 2nd ramp there is the house robot 11 Deadly Sins (Stats on ZED)
2) In the centre there are 5 rows of 3 sets of 2 killsaws, 1 set of each contains killsaws, 1 contains flywheels and 1 contains nothing, pick the best route
3) The route to the right contains 14 squares, some are pits, some are flippers (some throw forward, some throw back) and some are just squares that do nothing
Trials: Football,Sumo,Grand Prix,Tug Of War,Joust,Skitttles,Spinning Top, British Bulldog 1, British Bulldog 2
Football: A 15X15 octagon with a goal, gaurded by Cage (Stats on ZED)
Sumo: A 15X15 Circle, simple, push Cage out of the arena
Grand Prix: A 100M figure 8 track, simple complete 10 laps first
Tug Of War: Pull Cage into the pit
Joust: Push Cage 10M
Skittles: Push a ball into pins, knock them over
Spinning top: stay on the spinning arena longer than Cage
British Bulldog 1: 5 Blocks, get in between them then past Cage and Zoo-Kepeer
British Bulldog 2: Blocks, get in between them then past 11 Deadly Sins
I also need 8 robots for an Mayhem event
8 teams of 2 robots for football
and 16 teams of 2 for Tag-Team
Stats and Pics please
Scrapyard Skirmish
Heats:
16 heats of 8
Semi-Finals:
4 Semis of 8 robots
Grand Final:
1 goes out in Trial
