The Crash & Burn Tournament 3
    Paul...
    Nitro-Gene 5.0 - You didnt explain to me about the extension...as for the ram, Ill think about it.
    The Rock - 3cm of rubber is still kinda iffy...
    Knyfe - Is fine now.
    Heyght - Like The Rock, the rubber is iffy...and if the entire armour is monocoque, how could you have 6mm titanium for the base? Again, for the ram, Ill have to think about that one...
    D.V.D.: The Sequel - If the sides are slanted like , then the rear wouldnt really be triangular...
    MeCannibal 3.0 - You still havent told me if the skirt is circular (and if it is, it wont work well
    Chris, okay, got it.
    (Message edited by kodster on July 30, 200
      Ill give it a go
      Robo-Platypus
      Robo-Aardvark
      Stats on the How Could I Improve Pt 2
      Realies:
      Iron-Awe 5
      Kan Opener
      Biohazard
      El Diablo
      Toro
      Gemini
        Ben, Id recommend you start out with all realies until your vapourbots get some experience in mini-tournaments. Major tournaments are not that good for blatant newcomers.
        That, and El Diablo is a MW. Toro is also a SHW. They are not accepted.
          ok
          Iron-Awe 5
          Kan Opener
          Biohazard
          Gemini
          Gravity
          Tsunami
          Onslaught
          The Judge
            The Judge is also a SHW...
              Ok
              Iron-Awe 5
              Kan Opener
              Biohazard
              Gemini
              Gravity
              Tsunami
              Onslaught
              Nightmare
                Mkay, youre in.
                • #23
                  Given that Im half-asleep right now, Ill try and get my entries posted tomorrow. Cheers for the reservation, Kody!
                  • #24
                    Thanks
                    • #25
                      Thats odd.... thought Id posted my entry.... evidently not
                      Slammer
                      Salamander
                      Tengu
                      Achilles
                      Baldur
                      Black Panther
                      Archangel of the Abyss
                      Dante
                      I wont be around for the next ten days to sort out any problems though.
                      http://www.alexjholt.tkwww.alexjholt.tk as usual
                      • #26
                        Kody - Ive sorted the problems out for you - theyre on my page on ZED.
                        Are they fine NOW?
                        • #27
                          No, Paul...in fact, you didnt change Heyght at all. :S Youre doing what Mark did, saying you changed stats when you didnt...
                          And as for the rams on N-G and Heyght, Im going to have to say no. Your rams wouldnt fare well with so much pressure, no matter how big you make them. Make the kg pressure lower, especially for Nitro-Gene, if you dont know a busted flipper.
                          Really, Paul, if youre not going to take this seriously...
                          • #28
                            Ill enter the usual:
                            Death Threat
                            Axes of Evil
                            Cat With Wheels
                            Crimson Thunder
                            Sithis
                            Lethal Execution
                            Blue Sparks
                            Leviathan
                            You know where, Kody.
                            • #29
                              Ill enter:
                              Shear Heart Attack 2
                              Axe to Fall/Axe to Fall 2
                              Flick of the Wrist/Flick of the Wrist 2
                              Another Night at the Bar/Three Nights at the Bar
                              Back to Rock III
                              With or Without You
                              Liar 2
                              A realie/Under Pressure
                              there
                              • #30
                                What if I made Heyghts armour chassis mounted and reduced the ratio on the flipper to 5.4:1, making it 600kg at the tips, rather than 800kg, and made the rams 90mm?
                                As with Nitro, should I use smaller rams, say around the 100-90mm mark?
