The Killer Toad Tournament Special
Mega Masher 2 vs. Mad Dash
So it€™s time for the 2nd fight in the series of 7 grudge matches, this time it is the battle between Mega Masher the 2nd and Mad Dash.
The first robot into the arena today is Mega Masher 2, this Minion look-a-side with side skirts plus it has 4 wheel drive. The front has a wedge and there is a rear mounted vertical disc. The armour is Hardox, plus the 4 wheel drive is powered by some Bosch 750€™s at 36 volts. The top speed is limited to 12 mph, and the sides are protected by skirts, protecting the 10mm ground clearance, however the skirts only protect the sides down to 1mm, to aid manoeuvrability, however the rear end is exposed with 10mm, and as the rear end also contains the spinning disc which is powered by it€™s own Lem 130 giving it quite a bit of damaging potential, or DP as I like to call it.
The 2nd robot into the arena today is Mad Dash, which is an invertible box with front scoop combo, twinned with a nasty looking small drum half-buried in the scoop itself, the main power comes from the drive system, mixing 4 wheel drive with 2 Lem 130€™s for drive. The front armour is 5mm Hardox, but it looks like the remaining armour is titanium, which should hold out unless it comes up against a vertical spinner, oh dear. The ground clearance is 0mm at the scoop and 6mm everywhere else, and with a top speed of 20mph, it has the power to out-run Mega Masher, but does it have the control?
The 3rd robot into the arena today is Remy, everybody€™s favourite* ref robot (in a survey, 3 people were asked what their favourite ref robot was, and Remy came out top by all 3 people).
Everybody is ready for a royal rumble, as the lights come down, and the action begins
3
2
1
Activate
The green light is showing on Remy, as she reverses to allow both Mad Dash and Mega Masher out, and both robots come storming out of the starting squares, scoop against the wedge, as both are heading towards each other, the crowd are waiting for a dodge by either team, but the dodge doesn€™t come as both robots slam into each other, as the slightly lower front scoop with the weight of the drum pushing the front down against Mega Masher€™s whose rear spinning disc doesn€™t act in it€™s favour, as Mad Dash is underneath Mega Masher, as the drum sparks against the Hardox wedge, causing no damage, but the wheels of Mega Masher are spinning as they try to get a grip, but Mad Dash slams Mega Masher at top speed towards the nearest arena wall.
Bang
Mad Dash drops Mega Masher and drives away looking for the next attack, as Mega Masher comes away, the rear spinning disc has taken quite a bit of damage and has actually bent, having the force put onto it. Mad Dash spins and drives towards Mega Masher. Chris dodges, as Samuel spins the controls around and comes back onto the attack, ramming into the side of Mega Masher and pushing Mega Masher sideways before dumping it into the pit.
Cease
In a battle of Wedge vs. Scoop, the scoop came out on top and Mega Masher ended up in the pits. Mad Dash dashes its way to victory.
Next up:
Lunch
But after that
Spin Dash Unleashed vs. SOR X
Damn it€™s raining :sad:
3
2
1
Activate
Bang
Cease
Next up:
Lunch
But after that
