How could I Improve pt 2
This is a sticky topic.
    That explains now why 1 won't give the crusher 10 tonnes of force...
    And the SGS system was used due to it being the best crusher as of this post.
      Err...how is SGS the best crusher right now? I can think of a few that are much better: E Clawdius Unum, Under Pressure, N^3
        To me, it appeared to be the one that put out the highest Crushability factor.
          Meh. Doesn't always mean it's the 'best'.
          And I based my output off of Holepunch 2.0. :P
            Spanik 2 has been updated once again. I've added a second motor, needed to make the crushability factor 15 tonnes.
            http://teamcorsairbots.proboards.com...hread=6&page=1
              How did you work out that your mysterious magical system gives 15 tonnes of force? (at the non-existent ram)
                The system is pretty much the same used in Jaws of Death, and Jaws of Death has 15 tonnes at the tips, so...
                  ...forgive me for being a tiny bit skeptical, are there any sources for Jaws Of Death's system having 15 tonnes at the tips? I can't recall anything like that.
                    From the official Battlebots guide:
                    Everything in Jaws of Death, from the clamping jaws to the drive, is hydraulically powered by Char-Lyn J2 hydraulic motors. The motors are fairly heavy, but are small and don't generate much heat.
                    Powered by 2 Char-Lyn J2 Motors(Each powering 1 jaw), the robot's jaws exert 15 tonnes at the tips!
                      Where is this Battlebots official guide again? I've never heard of it.
                        I don't know. All I know is I got it as a present for Christmas from my parents.
                          How can Kody improve? Simple. He updates the renders of his vapourbots.
                          In this instance, he means all of his current heavyweights. And their previous generations.
                          71 renders.
                          Augh. I'm leaving the otherweights and retired bots for later, my arms hurt. >_<
                            Good Lord...
                            Kody, that was some serious work you did, and the results are awesome.
                            And I was just wondering: Would you be willing to do some renders for me? Please?
                              Why thank you. Truth be told, I partially re-rendered most of them because of Geocities; I was still hosting images from there, and as of late October, Yahoo! will be closing down Geocities. And anyway I had missing images so... :P
                              As for your request (yes I see it :P), I could be a total prick and straight away say no, but I won't...yet. Give me one good reason why I should, though. :P
                                I really need some, since I have no idea what they truly look like. Sure I understand the basic shape, but I probably need to see them in a CAD...
                                And you don't have to do the outdated bots. All you would need to do is make CADs for the latest ones.
