How could I Improve pt 2
This is a sticky topic.
  • How could I Improve pt 2
    Thats a good vapourbot, and it seems to be your best one so far. Well done Ben.
      Added on ZED
        Can I just say Ben, you are improving all the time, and youve produced some really good robots.
          right here we go again...
          Shape: Cylinder with hinged skirts
          Colour: Black, but covered with white fur
          Speed: 22MPH
          Weight: 100KG
          Armour: 7MM Titanium
          Drive: 2 LEM200s @ 48V
          Power: 10 NiCad Battlepacks @ 48V
          Locomotion: 4 Vulkalon coated wheels
          Ground Clearance: 0MM thanks to skirts
          Turning circle: 0
          Dimensions: 80X80X40 (Including skirts)
          Weaponry: A pneumatic crushing jaw with two points which can exert a force of 10 tonnes, the claw is mounted on a turret capable of turning 360 degrees
          Srimech: A linear actuated bar on the back of the claw
          Strengths: Powerful weapons, 360 degree attack, Fast, Nice pyrotechnics show
          Weaknesses: Slow to self-right, flammable
          (Message edited by neontetra23 on August 02, 200
            Shape: A cylinder on its side (its an axlebot)
            Colour: Dark blue with Grey-White spots
            Speed: 17MPH
            Weight: 100KG
            Armour: 8MM Titanium
            Drive: 2 LEM130s @ 36V
            Power: 6 NiCad Battlepacks @ 36V
            Locomotion 2 large Stinger like wheels
            Ground clearance: 10MM
            Turning Circle: 0
            Dimensions: 40X40X90
            Weaponry: A spinnig drum with 40 1CM teeth, it weighs 25KG, the casters behind the drum are linked to small pneumatic rams to flip the robot over to deal with attacks from the rear, it is powered by 2 C40-300 magmotors it spins at 4000RPM
            Srimech: Invertible
            Strengths: Powerful weaponry, Can change direction of attack in seconds, Thick armour
            Weaknesses: Exposed wheels, Quite slow
              I HATE MISTAKES!!
              Shape: Box
              Colour: Yellow and Black danger stripes
              Speed: 25MPH
              Weight: 110KG
              Armour: 5MM Titanium
              Drive: 4 LEM130s @ 36V
              Power: 8 NiCad Battlepacks @ 36V
              Locomotion: titanium tracks with a vulkalon coating
              Ground Clearance: 0MM at front, 4MM everywhere else
              Turning Circle: 0
              Dimensions: 120X70X20
              Weaponry: 1) A 15KG pointed sledgehammer, powered by pneumatics that comes down in 0.8 seconds
              The next three weapons are interchangeable
              2) A 7MM static Hardox wedge at the front
              3) 5 5MM static Hardox forklift arms at the front
              4) A 7MM hinged Hardox scoop
              5) On the top of the robot there are 8 rows of 6 curved teeth that are only used when I am using the wedge, the first 6 rows face the rear and collapse when you drive forward and lock in place to damage the tyres of other robots when you drive backwards, the last row faces the opposite way and are fixed in place
              Srimech: Axe, can run inverted if axe is taken off
              Strengths: powerful weapons, weapons synergy and is capable of 1 or 2 hit KOs
              Weaknesses: Thin armour, easily flipped and sides and rear are vunerable
                Shape: Box with rounded rear
                Colour: Light green
                Speed: 35MPH
                Weight: 100KG
                Armour: 6MM Titanium
                Drive: 6 LEM200s @ 36V
                Power: 12 NiCad Battlepacks @ 36V
                Locomotion: 6 wheels with a vulkalon coating
                Ground Clearance: Varies at front, 2MM everywhere else
                Turning Circle: 0
                Dimensions: 80X55X25
                Weaponry: 1) A ramming spike array with three rows of 5, they are 7CM long and made of solid hardox
                2) A hinged 7MM hardox scoop
                3) A 30CM long hardox wedge
                4) A hinged cylinder with 3 40CM long spikes on
                5) A concave scoop
                Srimech: Invertible
                Strengths: Fast, Strong, Low ground clearance
                Weaknesses: May be uncontrollable
                  Shape: A wedge with angled sides
                  Colour: Grey-White
                  Speed: 20MPH
                  Weight: 100KG
                  Drive: 2 C40-300 Magmotors @ 48V
                  Power: 5 NiCad Battlepacks @ 48V
                  Locomotion: 2 Vulkalon coated wheels
                  Ground Clearance: 0MM at front, 1-2MM on sides, 3MM at back
                  Turning Circle: 0
                  Dimensions: 110X40X25
                  Weapons: 1) A angled front-hinged flipper powered by 3 100X80 rams
                  2) 2 Linear actuated hardox goat horns to hold opponents in place
                  Srimech: The flipper
                  Strengths: Powerful flipper, Quick
                  Weaknesses: Not good at pushing
                    May I ask...whats the inspiration behind the Robo-names?
                      Theyre robots?
                        Well yeah, but its too obvious. :P And...yeah. :P
                          Shape: Box with rear double-side wedge
                          Colour: black and yellow stripes (Like a Bee)
                          Speed: 17MPH
                          Weight: 100KG
                          Drive: 2 LEM200s @ 36V
                          Power: 8 NiCad Battlepacks @ 36V in the rear of the robot to act as a counter-weight
                          Locomotion: 2 Large Vulkalon coated wheels near the front of the robot
                          Ground Clearance: 5MM at front, 0MM at back
                          Turning Circle: 0
                          Dimensions: 100X50X30
                          Weapons: A spinning drum with 40 1CM teeth, it weighs 25KG
                          Srimech: Invertible
                          Strengths: Powerful weapon, Quick, Invertible
                          Weaknesses: Vunerable from the sides
                          Shape: Box with 2 A-frames coming out of the front
                          Colour: Brown (Synthetic feathers)
                          Speed: 20MPH
                          Weight: 110KG
                          Locomotion: 2 Titanium tracks with a urethane-rubber coating
                          Ground clearance: 1MM
                          Dimensions in CM: (LxWxH) 55x75x20
                          Weaponry: 1) 2 15KG square spinning disks
                          2) 2 15KG triangular spinning disks
                          3) 2 15KG Dragonstrike style spinnig disks
                          4) 2 15KG Kishar style spinning disks
                          5) 2 15KG Carnage style spinning disks
                          6) I forget, will post later
                          Each blade spins inwards at 200RPM, each powered by a LEM200
                          Srimech: Invertible
                          Strengths: Powerful weaponry, Strong tracks
                          Weaknesses: Tracks are open to axes and crushers
                          Dragonstrike:http://www.teamdragon.org.uk/html/dragonstrike.htmlhttp://www.teamdragon.org.uk/html/dragonstrike.html
                          Carnage:http://www.teamdragon.org.uk/html/carnage.htmlhttp://www.teamdragon.org.uk/html/carnage.html
                          Kishar:http://www.teamdragon.org.uk/html/kishar.htmlhttp://www.teamdragon.org.uk/html/kishar.html
                            Shape: A sideways cylinder (Axlebot)
                            Colour: White with black patches
                            Speed: 20MPH
                            Weight: 100KG
                            Armour: 4MM Titanium
                            Locomotion: 2 Vulkalon coated wheels with large spikes
                            Ground Clearance: 8MM
                            Turning Circle: 0
                            Dimensions: 55X55X70
                            Weaponry: A torque hammer with a difference, it has a 10 KG vertical flywheel with 12 3CM teeth, it rests on casters, it is powered by a C40-300 Magmotors, it spins at 3000RPM
                            Srimech: Invertible
                            Strengths: Powerful weapons, Invertible, Fast
                            Weaknesses: If casters are destroyed the weapon is useless, Hard to control, Easy to flip
                              I think, Ben, youve got confused between LEM130s and LEM200s.
                              The former (LEM130, commonly used at 36V and 48V) is only 3kg in weight, and produces 9hp at 36V and 12hp at 48V, and are the most commonly used motor in a vapourbot, due to their weight to power ratio - they weigh 1kg more than a Bosch 750w, but produce 8hp more.
                              The latter (LEM200, commonly ran at 48V and 60V) weigh 4 times more than the 130, at 12kg each, but produce more hp each, as its 25hp for the 48V model and 52hp each for the 60V. Do Or Die and my own Knyfe use them, but I use the 48V one as the 52hp combined means a minimum of 104hp, which is overdone, but Chez uses the 60V ones at his own risk
                              With Robo-Panda, sticking LEM200s or any LEM in is a waste, as axle-bots hardly do any pushing. Used the Bosch 750w at 36V, as it will allow to make the disc heavier and armour stronger, as you will have 10kg spare.
                              Look here for LEM motor info:
                              http://www.lemcoltd.com/lem_130.htmhttp://www.lemcoltd.com/lem_130.htm - Look here for LEM130 info
                              http://www.lemcoltd.com/lem_170.htmhttp://www.lemcoltd.com/lem_170.htm - Look here for LEM170 info
                              http://www.lemcoltd.com/lem_200.htmhttp://www.lemcoltd.com/lem_200.htm - Look here for LEM200 info
                                Ok Revised stats
                                Speed: 20MPH
                                Weight: 100KG
                                Drive: 2 LEM170s @ 36V
                                Turning Circle: 0
                                Weaponry: 1) A torque hammer with a difference, it has a 10 KG vertical flywheel with 12 3CM teeth, it rests on casters, it is powered by a C40-300 Magmotors, it spins at 3000RPM
                                2) An optional scoop made of 6MM hardox
                                Srimech: Invertible
