How could I Improve pt 2
This is a sticky topic.
  • #91
    thanks! How do I post my robot on there?
    • #92
      When you register, I shall open your section up so you can post there.
      Whats your team name? (thatll be the section title)
      • #93
        my team name is Team Animatronic Animals
        • #94
          Mkay.
          For reference, could you please post your fixed stats here first?
          • #95
            I will do it later and I am logging off for now, BYE!
            • #96
              Kody:
              Hardox = 7.8kg/dm3
              Ti=4,5kg/dm3
              so if 4mm hardox on a robot is 60kg, 7mm Ti is 61kg.
              So your not saving weight, it gets heavier.
              • #97
                That is not a bad attempt at all Ben. If you follow Kodys advice you should have a pretty solid vapourbot there. However, you shouldnt listen to Kody regarding the wheels. The number of wheels you have, as far as I am aware, does not effect the speed or torque of your robot. Gearing effects that. I also dont agree with this more wheels = less manouverability idea. We have all seen Chaos 2 (2WD), Tornado (4WD) and Storm II (6WD) turn directly on the spot - so where did this idea stem from? The only benefit I can see of having less wheels is that it reduces the weight. Im probably wrong, but thats what I think anyway.
                • #98
                  so what armour do you suggest Leo
                  and i think i will change back to 6 wheel drive
                  • #99
                    4WD and 6WD machines have more friction while turning on the spot and less direct drive, if that makes any sense, 2WD machines turn more efficiently, pretty much enhancing their manouverability
                    which is exactly why you only see 2WD twackbots, 2WD makes spinning on the spot alot more smoothly
                    • How could I Improve pt 2
                      i dont want to spin on the spot i just want a 0 turning circle
                      Oops! i almost forgot the GC is 1mm on the body and 0mm at the front of the flipper
                          Err...two problems with that.
                          1: Having a 0 turning circle without being able to spin on the spot is impossible, because they are the same thing.
                          2: If your GC is only 1mm, you wont really be able to move.
                            that made me laugh slightly, no offense intended
                            0 turning circle = turning on the spot
                            you can have 0 turning circle with any amount of wheels you want, be it 2WD, 4WD, 6WD. The key difference is that with 2WD you can turn QUICKER, with 6WD however, you have more traction and can push better. 4WD is good for both pushing (not as good as 6WD) and turning (not as good as 2WD)
                            so, what will it be Ben, a 6WD robot with lotsa push or a 4WD robot with better agility?
                              Damnit, I keep forgetting Hardox and titanium densities.
                                Hold everything Martijn...isnt that conflicting with what AJ said about Chaos 2, Tornado and Storm 2?
