How could I Improve pt 2
This is a sticky topic.
  • #61
    Im not saying majors suck, I have fond memories from some of the bigger tournaments. But times have changed, no longer are there plenty of writers with enough enthusiasm to knock out a large number of battles in quick succession. More regular, smaller tournaments seems to fit the bill IMHO.
    • #62
      *points to the question asked*
      • #63
        Paul Cuomo, can you check ZED? I need to speak to you about something
        • #64
          Could someone check over this please?
          http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=378http://strickenone.proboards99.com/i...teamww&thread= 378
          • #65
            55cm high, is that a typo?
            • #66
              Question on my part: If you decide to take a vapourbot into production, does it seize to be a vapourbot?
              • #67
                Too high and not long enough, Liam.
                • #68
                  too heavy too.
                  • #69
                    Yeah, would it be better to make the weapons interchangeable?
                    • #70
                      Yes, that would help. Also make it like less than half the height, and increase the length by a considerable amount.
                      • #71
                        Well if you want to keep both weapons you need to make the armour way thinner than 9mm.
                        keep in mind that every square meter 1mm thick Titanium is 4,5kg.
                        And dont forget that all those motors need batteries.
                        • #72
                          Id assume that the real robot is then a real robot, while the set of stats remains the vapourbot. Of course if the real version turns out to suck youve shot yourself in the foot, lol.
                          • #73
                            In that case Ill just keep it secret which one I picked.
                            • #74
                              Oh, before I forget...
                              Paul, I contacted Mario de Jongh (the guy who makes custom rams, youve seen him on this site), and he agrees with me that Nitro-Gene 5.0 is still in the wrong. You see, the bottles are still too big for the height of the body, and the pressure on the valves would blow them off completely.
                              If I were you, Id think about switching for CO2 and start calling it Carbo-Gene.
                              • #75
                                right.. new heavy
                                Robo-Platypus
                                Shape: Rectangle
                                Colour: Red wth a picture of a platypus on the top
                                facing the rear, the tail covers the flipper
                                Speed: 20 MPH
                                Weight: 100KG
                                Armour: 4MM Hardox
                                Drive: 2 C40-300 Magmotors @ 36V
                                Power: 6 NiCad Battlepacks @ 36V
                                Locomotion: 6 Wheels that just poke through the top and bottom of the robot
                                Turning circle: 0M thanks to skid steer
                                Dimensions: 100X30X20
                                Weaponry: A rear-hinged flipper powered by a 80X100 ram at 750 PSI, powered by dual 3KG Co2 tanks, the flipper also has a built-in front-hinged flipper powered of the same ram and shares the Co2 tanks with the other flipper, the first flipper is 40X30X1 and the other is 20X15X1 and is exactly in the middle of the other flipper
                                Srimech: Invertable and the flipper can right it
                                Strengths: Powerful flippers, Fast, Invertable, Unique weapon
                                Weaknesses: May be hard to control, Not sure if weapon is do-able
                                (Message edited by neontetra23 on July 28, 200
