Re: How could I Improve pt 2
I'd avoid using a dog clutch purely on the premise that they work in a very very rough and impacting manner. They are indeed using in race car gearboxes, but require double clutching and rev matching (The method of matching the motor rpm with the gearbox rpm by blipping the throttle during gear change) for smooth shifts (Requiring a high degree of skill!).
To make a dog clutch that will handle the forces your looking at will be quite heavy, and may even have issues engaging due to the differences speed differences between your kinetic mass and the drive/weapon.
For Infusion, I chose to use Electro-magnetic clutches (emc), these will slip to some degree, but are very reliable. Depending on the size/design, they can handle a fair amount of power. Most car air conditioner pumps have emc's that can handle 3-4HP loads with clamping speeds between 800rpm right up to 6000rpm. The Toyota SC12/SC14 supercharger units have emc's that handle 8-10hp (roughly the parasitic load from running these units on the motor), I have no idea how long they would last if your turning them on and off every few seconds, but they could be a possible solution.
