Vapourbot Vengeance Series 1
And now, the end is near for one of the following machines. A place in the Semi Finals is up for grabs. Are you sitting comfortably? Then well begin...
But first lets see how our heat finalists got this far!
In round one Atomic turned the turtle over the arena wall, and flipped Cygnus X3 over onto its back and unable to self right. Wedgas Revenge got its revenge on Mean Streak, before doing the same to Araknia!
Round two saw Atomic send Hellbent down the the underworld, via the camera tracks, of course, whilst Wedgas Revenge tried to flip SMIDSY out of the arena once, twice and thrice, before Matilda finally did the honours with her ferocious flywheel!
HEAT G: HEAT FINAL
House Robots - Dead Metal and Sir Killalot
3...2...1...ACTIVATE!
Atomic surges from its starting grid, the speed and acceleration catching Wedgas Revenge off guard, speeding across the arena floor and slamming head first with the flipper into its opponent. The flipping plate, however, fails to get underneath Wedgas Revenge, but the force of the slam sends the machine from Shrewsbury reeling backwards. Before AJ can fire the flipper, Atomic has reversed off the front scoop and drives around the arena, hoping to get underneath via the sides. Wedgas Revenge turns to block Atomic off, and manages to get Atomic onto the flipper. This time, Wedgas Revenge fires its flipper and Atomic is flicked away, but not flipped over onto its back. Stephen Bebb spins Atomic back to face Wedgas Revenge, but AJ is one step ahead of him and gets under the front of Atomic, driving it towards the arena wall and flipping it up in the air! Atomic thuds back to the ground, a hiss of CO2 venting from the underneath. Atomic self rights and quickly escapes another onslaught from Wedgas Revenge, who can sense victory is coming its way. Atomic crashes into the pit release, the driving of Stephen Bebb almost manic and uncontrollable, before headinf for Wedgas Revenge once again. This time, neither robot are able to successfully get under one another, Wedgas Revenge slowly but surely pushing Atomic back towards Dead Metals CPZ. Atomic tries desperately not to be outpushed, a surge of grip and aggression shoving Wedgas Revenge back, but unable to finish the job at hand, as Wedgas Revenge finally manages to shove Atomic into Dead Metals CPZ. The claws on Dead Metal latch around the back of Atomic, the saw blade whirring manically as it moves forward in its cradle. The sound of sawblade on Titanium fills the arena with a terrifying shriek, sparks pouring away from the blade like water from a fountain. Atomic wriggles whilst in the cluthes of Dead Metal, the sawblade coming down again and making another fountain of sparks. Eventually Atomic is released from the CPZ and charges directly at Wedgas Revenge, who has placed itself near the centre of the arena. The two machines crash in the middle, Atomic ending up on the scoop of Wedgas Revenge. Andrew Jackson flips Atomic over, leaving the veteran to Robot Wars on its back. Atomic self rights, but fails, the broken gas valve causing the precious CO2 to leak out and leave Atomic weaponless and srimechless. Refbot counts out Atomic as Wedgas Revenge spins in a victorious whirl.
CEASE!
Atomic was more like a Nuclear Disaster than an Atomic Bomb!
Wedgas Revenge goes through to the Series Semi Finals!
HEAT G: HEAT FINAL
CEASE!
