Eye Of The Robot - Series 5 Re-Opened
    Ill enter the same robots I previously entered in EOTR 5
      Frank, you need to pick another realie, as you originally entered FireStorm, but Alex has entered that.
        quote:
        are you gonna concentrate on this or on the Challenge Belt first Paul?
          No no no, Martijn, you have to put that in bigger letters so that he can see it.
          (Message edited by kodster on June 14, 200
            Liam is imminently returning! The world is saved! He wants a space reserved
              as you wish Kody
              quote:
              +2>are you gonna concentrate on this or on the Challenge Belt first Paul?
                in other words, if you finish the challenge belt first, reserve me a spot
                • #23
                  ...Can I just kill Alex and take Firestorm from him?
                  Meh, Ill enter Warrior SKF simply to screw Aaron up should he want to enter
                  • #24
                    If I was that easy to kill do you reckon Id still be around now?
                    • #25
                      Yes.
                      • #26
                        I killed Alex ages ago and have been replacing him for quite some time now
                        he loves you
                        • #27
                          Well yeah, because if you were that easy to kill you wouldnt be a threat and thus not worth killing.
                          • #28
                            Paralyzation
                            Shape: Box with low wedge
                            Weight: 100kg
                            Dimensions: 99 X 94 X 40
                            Batteries: 6 X 36V 3.6ah NiCad BattlePack
                            Drive: 2 X MagMotor S28-400 each at 24V
                            Wheels: 4 X Foam Packed Wheels with a thin layer of vulkalon rubber on them
                            Top Speed: 19 mph
                            Ground Clearence: 0mm at the front, and 3mm on sides and back
                            Armour: 3.23 mm Hardox
                            Weapon: 19kg Spinning Drum with 10 teeth Powered by a 24V LEM-130, spins at 4600 RPM
                            Srimech: Why should it? Its invertible.
                            Strengths: The Drum, Good Control, Foam Packed Tyres, Hard to Approach from the Front
                            Weaknesses: Exposed Tyres...
                            Turbo Shredder
                            Body Shape: Box
                            Weight: 100 kgs
                            Top Speed: 15 mph
                            Dimensions: 96 X 93 X 42
                            Armour: 4mm Stainless Steel All Around
                            Ground Clearence: 3.2mm all around
                            Wheels: 4 X Wheels Inside (Aluminum Hub)
                            Power: 2 X Lem-130s running on 36 volts
                            Battery: 4 X BPK-3600-36 BattlePacks
                            Weapons: A very nasty 19kg, 3800RPM horizontal spinning disc powered by a LEM-130 on 24V, capable of dishing out 30KJ
                            Srimech: Invertible
                            Strengths: Powerful Weapon, Great Pushing Power
                            Weaknesses: None Hopefully
                            Death Wish 2
                            Body Shape: Just a simple Box with rear wedge
                            Weight: 100kg
                            Dimensions: 90 X 85 X 30
                            Drive: Steel Tracks with Vulkalon rubber powered by 2 X LEM-130
                            Batteries: 4 X 36V NiCad BattlePacks
                            TC: Zero
                            Top Speed: 19 mph
                            GC: 0.0014mm at the back and 4mm anywhere else
                            Armour: 4mm Hardox
                            Skirts: A Titanium skirt on the rear
                            Weapon: At the front, there is a big and devastating 21kg Horizontal Spinning Flywheel powered by a Honda CR125 Motorbike Motor. Its top speed is 9000RPM. It is deadly within 2 seconds.
                            Srimech: None, but Invertible and rounded sides and back help it not to get stuck
                            Strengths: Devastating Name and Weapons, Extremely Sturdy Tracks
                            Weaknesses: As usual, the tracks might be exposed to axes or crushers (Although Very Strong and Sturdy)
                            Drum Boy
                            Shape: Barberous 2 and a bit
                            Colour: BLACK
                            Weight: 100kg
                            Dimensions: 96 X 42 X 42
                            Armour: 8mm Titanium
                            Wheels: 2 X Tightly Foam Packed Wheels with Hardox Hubs, based on Stinger
                            Drive: 2 X C40-500 Magmotors Powered by 4 X 24V NiCad BattlePacks
                            Speed: 15mph
                            Ground Clearence: 6.8mm All Around
                            Turning Circle: Zero
                            Weapon: 19kg Full Body Drum with 8 X Grade 5 Titanium Teeth, a bit blunt and curved upwards. Its powered by 2 X LEM-130s and spinning at 3000RPM. This also spins upwards to flip AND damage opponents at the same time.
                            Strengths: Invertible, Flipping it does nothing at all, PSYCHOTIC WEAPON!!!!
                            Weaknesses: Although EXTREMELY sturdy, wheels kind of exposed.
                            Revenge of Black Death
                            Shape: Box with wedge
                            Weight: 100kg
                            Armour: 4mm Hardox
                            Dimensions: 90 X 87 X 30
                            Drive: 2 X 24V LEM-130
                            Wheels: 2 Aluminum Hub Wheels with a thin layer of urethane rubber
                            Top Speed: 19 mph
                            Batteries: 4 X 24V NiCad Battlepacks
                            TC: Zero
                            GC: 0mm on front, 5mm on the back and sides
                            Weapon: Flipper powered by 2 X CO2 Fire Extinguisher Tanks, 13kg Laser-Cut, Horizontal Flywheel with 4 curved teeth on the back powered by a single LEM-170, spinning at about 4000RPM
                            Srimech: Flipper, Flywheel on the back and sloped sides prevent it from getting beached.
                            Strengths: Flipper, Disc, Good Pusher
                            Walk Don€™t Run 3
                            Shape: Disc Shaped
                            Weight: 110 kg
                            Armour: 6mm Hardox for the ring, 3.5mm Hardox for the top and bottom
                            Dimensions: 89 X 89 X 20
                            Drive: 4 Shuffling Pads with 6 Legs with vulkalon rubber
                            Batteries: 5 X 24V NiCad BattlePacks
                            TC: Zero
                            Top Speed: 13 mph
                            GC: 3.8mm
                            Weapon: A 32kg Spinning ring with 2 X 2kg Hypnodisc style teeth, but more larger and more curved, Spinning at 2200RPM powered by a 36V LEM-130, has an absolute buttload of shock proofing inside to stop it from self-destructing.
                            Srimech: Its Invertible
                            Strengths: 360 degree Killing zone, EXCEEDINGLY DESTRUCTIVE!!!!!!, If anything happens to the spinning ring, it can use a Storm 2-style tacitc: RAM TO DEATH
                            Weaknesses: Almost invincible, but does not like flippers, although invertible
                            Axetra
                            Weight: 100kg
                            Shape: Box with skirts and a Firestorm-style Low Front Wedge
                            Dimensions: 97 X 83 X 42
                            Armour: 3.6mm Hardox
                            Power: 4 X 36v NiCad BattlePacks
                            Drive: 2 X S28-400s
                            Wheels: 4 X Vulkanised Tires
                            Ground Clearence: 6mm without skirts and 0mm with skirts
                            Top Speed: 15 mph
                            Turning Circle: (Seriously, does this need to be here?) Zero
                            Weapon: A great big 200PSI 9kg axe powered by the same system that Terrorhurtz uses, capable of dishing out 1000kg of raw force, diamond coated blade to maximize damage. Can dent hardox easily.
                            Srimech: Axe, Round back and cylinders on sides prevent it from getting beached
                            Strengths: Can still push if axe fails, Can cause a lot of damage
                            Weaknesses: Only limited to 50 hits
                            I will also enter Gravity.
                            My bots will represent Vancouver, British Columbia.
                            (Message edited by samuel3764 on June 16, 200
                            • #29
                              Paul i want my vapour at ur tournament so heres my vapours
                              Name: Texas Chainsaw Massacre 2
                              Shape: Sewer Snake (new version lifter)
                              Colour: Grey
                              Speed: 28MPH
                              Weight: 220lb (100kg)
                              Armour: 6mm TI
                              Chassis: Titanium
                              Drive: 4 LEM 130s
                              Power: 4 12v battlepacks giving 48 volts total
                              Motivation: 6 Battle Tread Carefree Wheels
                              Ground Clearance: 0mm on the front 5mm on both sides and 0mm on back
                              Turning Circle: Zilch
                              Dimensions in CM (LxWxH): 1,14 x 76 x 46m
                              Weaponry: Lifting Tusk powered by a 7hp 2-stroke STIHL disc cutter engine the tusk is made from S7 Tool Steel and heat treated to give it maximum strength and can lift 500-800kg up to 1.2 meters about the ground
                              Self-Righter: Invertible
                              Strengths: Powerful Lifter good armour, speed
                              Weakness: exposed wheels
                              Name: Psycho Killer 2
                              Shape Tornado (RW 7)
                              Colour: black
                              Speed: 24MPH
                              Armour: 6mm TI
                              Chassis: Titanium
                              Drive: 2 x LEM130 at 36v.
                              Power: 6 NiCad Battle Packs at 36v
                              Motivation: 2 TI Tracks w/ 1inch custom made raptor claw for grip (inside of the robot)
                              Ground Clearance: 0mm on the front 1mm on both sides and 1mm on back
                              Dimensions in CM (Length x Height x Wide) 75cm x65cm 20cm
                              Weaponry: crushing/lifting claw powered by a modified chainsaw engine driving a hydraulic pump at 2000psi it also has 2 custom made TI wedge on front to help get its opponents to the weapon with ease.
                              Self-Righter: invertible but can self right with weapon
                              Strengths: Powerful lifter, good armour and speed
                              Weakness: Hates spinners
                              Name: The Grudge 1
                              Shape: Suicidal Tendencies
                              Colour: Black
                              Speed: 18MPH
                              Armour: 6mm TI
                              Chassis: Titanium
                              Drive: 2 x S28-400 Magmotors @24v
                              Power: Four 12v, 16Ah Hawkers
                              Motivation: Custom Made titanium tracks w/rubber strips on it for grip
                              Ground Clearance: 2mm
                              Turning Circle:0
                              Dimensions in CM: 1.38m x 0.74m x 0.70m
                              Weaponry: Pneumatic stinger powered by a 4€ bore, 12€™ stroke air cylinder at 200psi giving it about 2200 joules at end of swing
                              Self-Righter: The Stinger has a spike on top that pop out to self right the machine Strengths: Powerful weapon, good armour and speed
                              Weakness: exposed tracks from the back
                              • #30
                                Thank Rurak, but you need at least one more vapour and 4-2 realies.
                                I also need entrants from Chris and AJ and were set to go.
