Shape: Box with low wedge
Weight: 100kg
Dimensions: 99 X 94 X 40
Batteries: 6 X 36V 3.6ah NiCad BattlePack
Drive: 2 X MagMotor S28-400 each at 24V
Wheels: 4 X Foam Packed Wheels with a thin layer of vulkalon rubber on them
Top Speed: 19 mph
Ground Clearence: 0mm at the front, and 3mm on sides and back
Armour: 3.23 mm Hardox
Weapon: 19kg Spinning Drum with 10 teeth Powered by a 24V LEM-130, spins at 4600 RPM
Srimech: Why should it? Its invertible.
Strengths: The Drum, Good Control, Foam Packed Tyres, Hard to Approach from the Front
Weaknesses: Exposed Tyres...
Turbo Shredder
Body Shape: Box
Weight: 100 kgs
Top Speed: 15 mph
Dimensions: 96 X 93 X 42
Armour: 4mm Stainless Steel All Around
Ground Clearence: 3.2mm all around
Wheels: 4 X Wheels Inside (Aluminum Hub)
Power: 2 X Lem-130s running on 36 volts
Battery: 4 X BPK-3600-36 BattlePacks
Weapons: A very nasty 19kg, 3800RPM horizontal spinning disc powered by a LEM-130 on 24V, capable of dishing out 30KJ
Srimech: Invertible
Strengths: Powerful Weapon, Great Pushing Power
Weaknesses: None Hopefully
Death Wish 2
Body Shape: Just a simple Box with rear wedge
Weight: 100kg
Dimensions: 90 X 85 X 30
Drive: Steel Tracks with Vulkalon rubber powered by 2 X LEM-130
Batteries: 4 X 36V NiCad BattlePacks
TC: Zero
Top Speed: 19 mph
GC: 0.0014mm at the back and 4mm anywhere else
Armour: 4mm Hardox
Skirts: A Titanium skirt on the rear
Weapon: At the front, there is a big and devastating 21kg Horizontal Spinning Flywheel powered by a Honda CR125 Motorbike Motor. Its top speed is 9000RPM. It is deadly within 2 seconds.
Srimech: None, but Invertible and rounded sides and back help it not to get stuck
Strengths: Devastating Name and Weapons, Extremely Sturdy Tracks
Weaknesses: As usual, the tracks might be exposed to axes or crushers (Although Very Strong and Sturdy)
Drum Boy
Shape: Barberous 2 and a bit
Colour: BLACK
Weight: 100kg
Dimensions: 96 X 42 X 42
Armour: 8mm Titanium
Wheels: 2 X Tightly Foam Packed Wheels with Hardox Hubs, based on Stinger
Drive: 2 X C40-500 Magmotors Powered by 4 X 24V NiCad BattlePacks
Speed: 15mph
Ground Clearence: 6.8mm All Around
Turning Circle: Zero
Weapon: 19kg Full Body Drum with 8 X Grade 5 Titanium Teeth, a bit blunt and curved upwards. Its powered by 2 X LEM-130s and spinning at 3000RPM. This also spins upwards to flip AND damage opponents at the same time.
Strengths: Invertible, Flipping it does nothing at all, PSYCHOTIC WEAPON!!!!
Weaknesses: Although EXTREMELY sturdy, wheels kind of exposed.
Revenge of Black Death
Shape: Box with wedge
Weight: 100kg
Armour: 4mm Hardox
Dimensions: 90 X 87 X 30
Drive: 2 X 24V LEM-130
Wheels: 2 Aluminum Hub Wheels with a thin layer of urethane rubber
Top Speed: 19 mph
Batteries: 4 X 24V NiCad Battlepacks
TC: Zero
GC: 0mm on front, 5mm on the back and sides
Weapon: Flipper powered by 2 X CO2 Fire Extinguisher Tanks, 13kg Laser-Cut, Horizontal Flywheel with 4 curved teeth on the back powered by a single LEM-170, spinning at about 4000RPM
Srimech: Flipper, Flywheel on the back and sloped sides prevent it from getting beached.
Strengths: Flipper, Disc, Good Pusher
Walk Don€™t Run 3
Shape: Disc Shaped
Weight: 110 kg
Armour: 6mm Hardox for the ring, 3.5mm Hardox for the top and bottom
Dimensions: 89 X 89 X 20
Drive: 4 Shuffling Pads with 6 Legs with vulkalon rubber
Batteries: 5 X 24V NiCad BattlePacks
TC: Zero
Top Speed: 13 mph
GC: 3.8mm
Weapon: A 32kg Spinning ring with 2 X 2kg Hypnodisc style teeth, but more larger and more curved, Spinning at 2200RPM powered by a 36V LEM-130, has an absolute buttload of shock proofing inside to stop it from self-destructing.
Srimech: Its Invertible
Strengths: 360 degree Killing zone, EXCEEDINGLY DESTRUCTIVE!!!!!!, If anything happens to the spinning ring, it can use a Storm 2-style tacitc: RAM TO DEATH
Weaknesses: Almost invincible, but does not like flippers, although invertible
Axetra
Weight: 100kg
Shape: Box with skirts and a Firestorm-style Low Front Wedge
Dimensions: 97 X 83 X 42
Armour: 3.6mm Hardox
Power: 4 X 36v NiCad BattlePacks
Drive: 2 X S28-400s
Wheels: 4 X Vulkanised Tires
Ground Clearence: 6mm without skirts and 0mm with skirts
Top Speed: 15 mph
Turning Circle: (Seriously, does this need to be here?) Zero
Weapon: A great big 200PSI 9kg axe powered by the same system that Terrorhurtz uses, capable of dishing out 1000kg of raw force, diamond coated blade to maximize damage. Can dent hardox easily.
Srimech: Axe, Round back and cylinders on sides prevent it from getting beached
Strengths: Can still push if axe fails, Can cause a lot of damage
Weaknesses: Only limited to 50 hits
I will also enter Gravity.
My bots will represent Vancouver, British Columbia.
Paul i want my vapour at ur tournament so heres my vapours
Name: Texas Chainsaw Massacre 2
Shape: Sewer Snake (new version lifter)
Colour: Grey
Speed: 28MPH
Weight: 220lb (100kg)
Armour: 6mm TI
Chassis: Titanium
Drive: 4 LEM 130s
Power: 4 12v battlepacks giving 48 volts total
Motivation: 6 Battle Tread Carefree Wheels
Ground Clearance: 0mm on the front 5mm on both sides and 0mm on back
Turning Circle: Zilch
Dimensions in CM (LxWxH): 1,14 x 76 x 46m
Weaponry: Lifting Tusk powered by a 7hp 2-stroke STIHL disc cutter engine the tusk is made from S7 Tool Steel and heat treated to give it maximum strength and can lift 500-800kg up to 1.2 meters about the ground
Self-Righter: Invertible
Strengths: Powerful Lifter good armour, speed
Weakness: exposed wheels
Name: Psycho Killer 2
Shape Tornado (RW 7)
Colour: black
Speed: 24MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x LEM130 at 36v.
Power: 6 NiCad Battle Packs at 36v
Motivation: 2 TI Tracks w/ 1inch custom made raptor claw for grip (inside of the robot)
Ground Clearance: 0mm on the front 1mm on both sides and 1mm on back
Dimensions in CM (Length x Height x Wide) 75cm x65cm 20cm
Weaponry: crushing/lifting claw powered by a modified chainsaw engine driving a hydraulic pump at 2000psi it also has 2 custom made TI wedge on front to help get its opponents to the weapon with ease.
Self-Righter: invertible but can self right with weapon
Strengths: Powerful lifter, good armour and speed
Weakness: Hates spinners
Name: The Grudge 1
Shape: Suicidal Tendencies
Colour: Black
Speed: 18MPH
Armour: 6mm TI
Chassis: Titanium
Drive: 2 x S28-400 Magmotors @24v
Power: Four 12v, 16Ah Hawkers
Motivation: Custom Made titanium tracks w/rubber strips on it for grip
Ground Clearance: 2mm
Turning Circle:0
Dimensions in CM: 1.38m x 0.74m x 0.70m
Weaponry: Pneumatic stinger powered by a 4€ bore, 12€™ stroke air cylinder at 200psi giving it about 2200 joules at end of swing
Self-Righter: The Stinger has a spike on top that pop out to self right the machine Strengths: Powerful weapon, good armour and speed
Weakness: exposed tracks from the back
