Listen everyone. Im very sorry for the mess I caused in VRW Series 2, And Ill redo the tourney, with special side events with equally special names. But first, the intro....
Welcome to the VRW Series 2 Tournament!
Basic FRA Rules Apply
Rules: I need 8 people to enter 4 robots. Here is the way the fights will go:
Round 1: 2x 4-bot melees
Round 2: 2x 1-on-1
Round 3: 1x 1-on-1
Please put your stats like this:
Name:
Weight:
Shape:
Colour:
Dimensions(cm):
Drive:
Locomotion:
Armour:
Speed:
Ground Clearance:
Turning Circle:
Weapon:
Srimech:
There are also special events named after famous robots Which I will drop if you ask:
The Wedge Devolution Flipper Frenzy
The Mass Disctruction Ultimate Full Body Spinner Smash-up
The Killotine: Evo Axe Attack
The Nidhogg Crusher Crunch-Up
The Arena is the Plot Hole Arena:
Plot Hole Arena
This arena is a rather simple 20m x 20m square, with 40kg Hardox hammers in the corners, so shove an opponent in there to do some damage to them. There is a plot hole in the center of the arena, covered so you cant get sucked in. At the left wall, there is a plot hole opener button, which will remove the cover from the plot hole, so you can shove the other bot in.
No House Bots.
Well, youre reading this? You are? Well, stop reading and start entering!
Round 2: 2x 1-on-1
Round 3: 1x 1-on-1
Name:
Weight:
Shape:
Colour:
Dimensions(cm):
Drive:
Locomotion:
Armour:
Speed:
Ground Clearance:
Turning Circle:
Weapon:
Srimech:
Plot Hole Arena
No House Bots.
