Eye Of The Robot - Series 5
Here are my stats:
Minesweeper
Weight: 100kg
Shape: Tornado (S6)
Colour: Silver, with MINESWEEPER written on the sides in red.
Dimensions: 90cm x 85cm x 25cm
Drive: 4x Bosch 750 motors, powered by 5x 36V NiCad Battlepacks.
Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
Armour: 6mm Hardox
Speed: 16mph
Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
Turning Circle: 0m
Weapon: 2 snowplow-like scoops that can move slightly vertically, like Behemoths, so I get good pushing power, but 0mm ground clearance at front and back.
Srimech: Invertible
Roveress
Weight: 100kg
Shape: Growler, with a pink bow on top of his head.
Colour: Brown, with black and white splotches in some places.
Dimensions: 100cm x 70cm x 40cm
Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 4 foam filled wheels.
Armour: 6mm Titanium/Vanadium alloy.
Speed: 20mph
Ground Clearance: 0mm at front, and 9mm everywhere else.
Turning Circle: 0m
Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge. Once a robot is stuck on the wedge, which has Mute-style barbs on it, the top Jaw, powered by a 2kg 1000psi Nitrogen tank, comes down with over 5 tonnes of force.
Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
Cyrilium Mach 3
Weight: 100kg
Shape: Mortis (S4)
Colour: Gold
Dimensions: 100cm x 70cm x 30cm
Drive: 4x S28-400 Magmotors, powered by 5x 24V NiCad Battlepacks.
Armour: 5mm Hardox
Speed: 21mph
Ground Clearance: 0mm at front, and 5mm everywhere else.
Turning Circle: 0m
Weapon 1: A diamond tipped pneumatic axe, powered by a 220psi 2kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
Weapon 2: A flipping arm, powered by a 1.5kg C02 tank at 750psi. It can lift up to 250kg.
Srimech: The flipping arm.
Armory
Weight: 100kg
Shape: Big rectangular prism with a wedge at the front.
Colour: Yellow, with blue on the top and bottom.
Dimensions: 90cm x 50cm x 30cm
Drive: 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
Locomotion: 2 externally mounted fully Vulkanized rubber wheels.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, 0mm at sides and back with skirts, 5mm without skirts.
Turning Circle: 0m
Armour: 7mm Titanium/Vanadium alloy
Weapon: a 20kg Supernova shaped titanium disc with 2 2kg Hardox Hammerheads, powered by an LEM-200.
Srimech: Invertible
Trojan/Virus/Worm (TVW for short)
Shape: Biohazard
Dimensions: 95cm x 65cm x 25cm
Weight: 100kg
Speed: 20mph
Ground Clearance: 0mm all around due to skirts, and 5mm without.
Colour: Black
Turning Circle: 0m
Locomotion: 4 solid rubber wheels mounted internally.
Power: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Armour: The skirts are 4mm titanium, while the body armour is 6mm titanium.
Weapon: A Hydra-shaped axe, powered by 2x 2kg Co2 tanks feeding Co2 to a 70mm bore 550mm stroke ram, which gives it about 660kgs of force. It has the ability to pierce 3mm titanium, and actually scratch 5mm titanium.
Srimech: Due to the power of the axe, the robot can easily self-right.
Notes: Has lots of shockproofing to prevent shock damage.
Side Swipe
Weight: 100kg
Shape: Panzer (S3) with a Tornado style wedge on the front
Colour: Silver
Dimensions: 85cm x 60cm x 39cm
Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
Locomotion: 4 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
Speed: 20mph
Ground Clearance: 0mm at front due to wedge, at sides due to skirts over the wheels. 5mm at back. 5mm at sides without skirts.
Turning Circle: 0m
Weapon: A 7kg Terrorhurtz style axehead, for use as a thwackbot weapon.
Srimech: Invertible
Here are my stats:
Minesweeper
Weight: 100kg
Shape: Tornado (S6)
Armour: 6mm Hardox
Speed: 16mph
Turning Circle: 0m
Srimech: Invertible
Roveress
Weight: 100kg
Speed: 20mph
Turning Circle: 0m
Cyrilium Mach 3
Weight: 100kg
Shape: Mortis (S4)
Colour: Gold
Armour: 5mm Hardox
Speed: 21mph
Turning Circle: 0m
Armory
Weight: 100kg
Speed: 20mph
Turning Circle: 0m
Srimech: Invertible
Shape: Biohazard
Weight: 100kg
Speed: 20mph
Colour: Black
Turning Circle: 0m
Side Swipe
Weight: 100kg
Colour: Silver
Speed: 20mph
Turning Circle: 0m
Srimech: Invertible
I just need to more, and 2 realies from Alex please. Then I get this baby moving.
