Eye Of The Robot - Series 5
  • #61
    Here are my stats:
    Minesweeper
    Weight: 100kg
    Shape: Tornado (S6)
    Colour: Silver, with MINESWEEPER written on the sides in red.
    Dimensions: 90cm x 85cm x 25cm
    Drive: 4x Bosch 750 motors, powered by 5x 36V NiCad Battlepacks.
    Locomotion: 4 Titanium/Vanadium alloy wheels with Vulkanized rubber tyres.
    Armour: 6mm Hardox
    Speed: 16mph
    Ground Clearance: 0mm at front and back due to scoops, and 5mm at sides.
    Turning Circle: 0m
    Weapon: 2 snowplow-like scoops that can move slightly vertically, like Behemoths, so I get good pushing power, but 0mm ground clearance at front and back.
    Srimech: Invertible
    Roveress
    Weight: 100kg
    Shape: Growler, with a pink bow on top of his head.
    Colour: Brown, with black and white splotches in some places.
    Dimensions: 100cm x 70cm x 40cm
    Drive: 4x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
    Locomotion: 4 foam filled wheels.
    Armour: 6mm Titanium/Vanadium alloy.
    Speed: 20mph
    Ground Clearance: 0mm at front, and 9mm everywhere else.
    Turning Circle: 0m
    Weapon: The bottom Jaw Is fixed to the ground, and shaped like a wedge. Once a robot is stuck on the wedge, which has Mute-style barbs on it, the top Jaw, powered by a 2kg 1000psi Nitrogen tank, comes down with over 5 tonnes of force.
    Srimech: A lifting arm, built into the back of the robot, powered by a Bosch drill motor.
    Cyrilium Mach 3
    Weight: 100kg
    Shape: Mortis (S4)
    Colour: Gold
    Dimensions: 100cm x 70cm x 30cm
    Drive: 4x S28-400 Magmotors, powered by 5x 24V NiCad Battlepacks.
    Armour: 5mm Hardox
    Speed: 21mph
    Ground Clearance: 0mm at front, and 5mm everywhere else.
    Turning Circle: 0m
    Weapon 1: A diamond tipped pneumatic axe, powered by a 220psi 2kg C02 tank. it can poke holes in 3mm Titanium, and actually scratch 5mm titanium.
    Weapon 2: A flipping arm, powered by a 1.5kg C02 tank at 750psi. It can lift up to 250kg.
    Srimech: The flipping arm.
    Armory
    Weight: 100kg
    Shape: Big rectangular prism with a wedge at the front.
    Colour: Yellow, with blue on the top and bottom.
    Dimensions: 90cm x 50cm x 30cm
    Drive: 2x S28-400 Magmotors, powered by 5x NiCad Battlepacks.
    Locomotion: 2 externally mounted fully Vulkanized rubber wheels.
    Speed: 20mph
    Ground Clearance: 0mm at front due to wedge, 0mm at sides and back with skirts, 5mm without skirts.
    Turning Circle: 0m
    Armour: 7mm Titanium/Vanadium alloy
    Weapon: a 20kg Supernova shaped titanium disc with 2 2kg Hardox Hammerheads, powered by an LEM-200.
    Srimech: Invertible
    Trojan/Virus/Worm (TVW for short)
    Shape: Biohazard
    Dimensions: 95cm x 65cm x 25cm
    Weight: 100kg
    Speed: 20mph
    Ground Clearance: 0mm all around due to skirts, and 5mm without.
    Colour: Black
    Turning Circle: 0m
    Locomotion: 4 solid rubber wheels mounted internally.
    Power: 4x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
    Armour: The skirts are 4mm titanium, while the body armour is 6mm titanium.
    Weapon: A Hydra-shaped axe, powered by 2x 2kg Co2 tanks feeding Co2 to a 70mm bore 550mm stroke ram, which gives it about 660kgs of force. It has the ability to pierce 3mm titanium, and actually scratch 5mm titanium.
    Srimech: Due to the power of the axe, the robot can easily self-right.
    Notes: Has lots of shockproofing to prevent shock damage.
    Side Swipe
    Weight: 100kg
    Shape: Panzer (S3) with a Tornado style wedge on the front
    Colour: Silver
    Dimensions: 85cm x 60cm x 39cm
    Drive: 2x TWM3R Team Whyachi gearboxes connected to 2x S28-400 Magmotors, powered by 6x NiCad Battlepacks.
    Locomotion: 4 Vulkanized rubber wheels with Aluminum Boron Carbide hubs.
    Speed: 20mph
    Ground Clearance: 0mm at front due to wedge, at sides due to skirts over the wheels. 5mm at back. 5mm at sides without skirts.
    Turning Circle: 0m
    Weapon: A 7kg Terrorhurtz style axehead, for use as a thwackbot weapon.
    Srimech: Invertible
    • #62
      I edited my entry again.
      Walk Don€™t Run 3
      Shape: Disc Shaped
      Weight: 110 kg
      Armour: 1cm Grade 5 Titanium for the ring, 4mm titanium/vanadium for the top and bottom
      Dimensions: 89 X 89 X 21
      Drive: 4 Shuffling Pads, 6 Legs with vulkalon rubber
      Batteries: 5 X 24V NiCad BattlePacks
      TC: Zero
      Top Speed: 13 mph
      GC: 3.8mm
      Weapon: A 32kg Spinning ring with 2 X 2kg Hypnodisc style teeth, but more larger and more curved, Spinning at 2200RPM powered by a 36V LEM-130.
      Srimech: Its Invertible
      Strengths: 360 degree Killing zone, EXCEEDINGLY DESTRUCTIVE!!!!!!, If anything happens to the spinning ring, it can use a Storm 2-style tacitc: RAM TO DEATH
      Weaknesses: Almost invincible, but does not like flippers, although invertible
      • #63
        Oh yeah and my robots are representing Vancouver, British Columbia, Canada.
        • #64
          Ah, you live in Vancouver? Im jealous of you.
          • #65
            Whoa! I go to sleep for a few hours, and 2 more people have signed-up! I just need to more, and 2 realies from Alex please. Then I get this baby moving.
            List Of Entries
            1- Joey McConnell (Pontefract)
            a. Phoenix Down
            b. Gabriel II
            c. Nidhogg
            d. No Objections
            e. Isolation
            f. QE2
            g. Haardvark
            h. Dreadnaut
            2- Liam Eliot (Cardiff, Wales)
            a. Apocalypse
            b. Hatchet: Evo
            c. Werewolf
            d. Beta-Rex
            e. LockJaw
            f. Collateral Damage
            g. Panic Attack
            h. Storm 2
            3- Steven McGregor (Glasgow, Scotland)
            a. Wedge Devolution
            b. Killotine: EVO
            c. Metal Sonic Spin Dash
            d. Whirligig 4.5
            e. E Clawdius Unum
            f. Turbo Tails
            g. Chaos 2
            h. Pussycat
            4- Christopher Mason (Onehouse, Suffolk)
            a. Orka MK.4
            b. Die-Ceratops ReInvertus
            c. Leprosy Infection
            d. Mega Masher 2
            e. Cyclone Force 3
            f. Obliteration
            g. Humdrum
            h. Squirmin Vermin
            5- Kody Kunz (Etobicoke)
            a. Intriguing
            b. Wedginator 6.0
            c. Killobite 5.0
            d. Seung Mina IV
            e. Tira IV
            f. Kracko
            g. Iron Awe 5
            h. Surgeon General
            6- Frank Goacher (Gainsborough)
            a. The 6isc
            b. Tempest Evil-Est-Lution
            c. Sakura
            d. The May Tracks Has You
            e. ISDSFA
            f. Masamune
            g. FireStorm 5
            h. Big Nipper
            7- Alex Holt (Geddington)
            a. Kali
            b. Achilles
            c. Ramthrax 2
            d. Tengu VII
            e. Black Panther
            f. Baldur Gamma
            g. Dante
            h. Darkestar
            8- Mark Elam (Texas, USA)
            a. Cyrillium Mach 3
            b. Trojan/Virus/Worm
            c. Armory
            d. Side Swipe
            e. Minesweeper
            f. Roveress
            g. Tornado
            h. Corkscrew 2
            9- Daniel Stickler (Swansea, Wales)
            a. Manic Monsoon
            b. Sonic Boom
            c. Requiem
            d. Weapon Synergy
            e. Supreme Glory Omega
            f. Pure Evil: ROTD
            g. Typhoon 2
            h. Gemini
            10- Samuel Park (Vancover, British Columbia)
            a. Revenge Of Death Wish
            b. Walk Don€™t Run 3
            c. Death Wish 2
            d. Drum Boy
            e. Paralyzation
            f. Turbo Shredder
            g. Warhead
            h. Shrederator
            11- ???
            a. ???
            b. ???
            c. ???
            d. ???
            e. ???
            f. ???
            g. ???
            h. ???
            12- ???
            a. ???
            b. ???
            c. ???
            d. ???
            e. ???
            f. ???
            g. ???
            h. ???
            Get signing - only 2 spots left!
            • #66
              Paul, I have done the CAD of Wedginator Devilution. Its up in the Images section. Can you replace W 6.0 with that, please?
              Stats will come a bit later.
              • #67
                NAME- Death Threat 0.2
                SHAPE- Long box with rounded back,
                COLOUR- dull grey all over
                WEIGHT- about 110kg
                DIMENSIONS- L:95cm W:70 cm H:30cm
                SPEED- 13mph
                TURNING CIRCLE- 0m
                GROUND CLEARANCE- 0mm with hinged skirts, 10mm underneath
                ARMOUR- 5mm hardox
                MOVEMENT- Tracks with 2 Lem 130 Motors with 3 Ni-cad battery packs at 24 Volts
                WEAPONS- Horizontal crushing claws at front made out of titanium with 6.25 tons of crushing power
                SRIMECH- Invertible. Side spikes to stop it resting on its side
                NAME: Axes of Evil
                SHAPE: Hexagon, sloping in to a point in the middle.
                COLOUR: dark green.
                WEIGHT: around 100kg
                DIMENSIONS: 60x60x50
                SPEED: 15mph
                TURNING CIRCLE: 0mm
                ARMOUR: 20mm polycarbonate
                GROUND CLEARANCE: 0mm all over with skirts, 15mm with.
                MOVEMENT: 2WD inside robot. powered by two Bosch motors running at 24 volts.
                WEAPONS: Rack and Pinion axe mechanism powered by two CO2 tanks at 160psi. It has two terrorhurtz style heads, one on either side of the shaft, because Axe of Evil doesnt work with the pun, and the name has to be accurate.
                SCRIMECH: the axe has spikes sticking out to aid self righting from any angle.
                NAME: If Cats Had Wheels We Could Have Cat Races, How Cool Would That Be? A.K.A Cat With Wheels
                SHAPE: Wedge with sloped sides.
                COLOUR: Like a Tabby Cats coat
                WEIGHT: Around 100Kg
                DIMENSIONS: L:100cm W:70cm H:50
                cm
                SPEED: 18mph.
                TURNING CIRCLE: Omm
                ARMOUR: 7mm Titanium
                GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
                MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts
                WEAPONS: Front hinged high pressure C02 flipper, powered by two rams, running at 500psi.
                SCRIMECH: flipper.
                SHAPE: Box with wedge at front and inverted wedge at back.
                COLOUR: Deep Red.
                WEIGHT: Around 100kg
                DIMENSIONS: L:110cm W:65cm H:23cm
                SPEED: 30mph
                TURNING CIRCLE:0mm
                ARMOUR: 5mm hardox
                GROUND CLEARANCE: 0mm at the front, 0mm with hinged skirts at sides, 20mm at sides under the skirts and at back. (Well, technically 23cm at the very back, thanks to the inverted wedge.
                MOVEMENT: 4 Wheels with Vulkanon tires and aluminium hubs powered by 4 36v LEM130s Powered by 6 NiCad battlepacks.
                WEAPONS: None but the force.
                SCRIMECH: Invertable.
                Shape: Cylinder
                Colour: Black with red teeth
                Weight: 100kgs
                Dimensions: L:90cm W:90cm, H:30cm
                Speed: 15mph
                Turning Circle: 0cm
                Armour: 8mm Titanium all around.
                Ground Clearance: 7mm
                Movement: 4 invertable wheels with Vulkanon treads, powered by a couple of LEM130s at 36V with 3NiCad battlepacks
                Weapons: Ring spinner powered by an etek running at 48volts, which can deal out around 80kjs of power. Two five kilo hardox teeth, curved to rip armour. The whole ring is about 20kg.
                Scrimech: Invertible.
                Name: Lethal Injection
                Shape: Stinger, but with static prongs between the wheels.
                Colour: Unpainted.
                Weight: 100kgs
                Dimensions: L:55cm W:60cm H:45cm
                Speed: 18mph
                Turning Circle: 0cm
                Armour: 9mm titanium on the wheels, 5mm Hardox for the prongs and disc.
                Ground Clearance: Ermm.. Being a stinger style axlebot, it doesnt really have one. The prongs are 0mm however.
                Movement: 2 stinger style wheels with Vulkanon rubber tyres, with 2 LEM130s and 4 NiCad battlepacks at 24volts.
                Weapons: Spinning disc positioned in between the prongs. The idea is that the opponent will be wedged on the prongs then caught by the disc. The disc is powered by a LEM130 at 2000rpm and deals about 60kj.
                For Realies, Ill enter Roadblock and Cunning Plan, both from series 1 of Robot Wars.
                • #68
                  Cunning Plan is FEATHERWEIGHT - you need a heavy weight.
                  • #69
                    Fine, replace it with The Creature, series 4.
                    • #70
                      List Of Entries
                      a. Phoenix Down
                      b. Gabriel II
                      c. Nidhogg
                      d. No Objections
                      e. Isolation
                      f. QE2
                      g. Haardvark
                      h. Dreadnaut
                      a. Apocalypse
                      b. Hatchet: Evo
                      c. Werewolf
                      d. Beta-Rex
                      e. LockJaw
                      g. Panic Attack
                      h. Storm 2
                      a. Wedge Devolution
                      b. Killotine: EVO
                      d. Whirligig 4.5
                      e. E Clawdius Unum
                      f. Turbo Tails
                      g. Chaos 2
                      h. Pussycat
                      a. Orka MK.4
                      d. Mega Masher 2
                      e. Cyclone Force 3
                      f. Obliteration
                      g. Humdrum
                      h. Squirmin Vermin
                      a. Intriguing
                      b. Wedginator Devilution
                      c. Killobite 5.0
                      d. Seung Mina IV
                      e. Tira IV
                      f. Kracko
                      g. Iron Awe 5
                      h. Surgeon General
                      a. The 6isc
                      c. Sakura
                      e. ISDSFA
                      f. Masamune
                      g. FireStorm 5
                      h. Big Nipper
                      a. Kali
                      b. Achilles
                      c. Ramthrax 2
                      d. Tengu VII
                      e. Black Panther
                      f. Baldur Gamma
                      g. Dante
                      h. Darkestar
                      a. Cyrillium Mach 3
                      c. Armory
                      d. Side Swipe
                      e. Minesweeper
                      f. Roveress
                      g. Tornado
                      h. Corkscrew 2
                      a. Manic Monsoon
                      b. Sonic Boom
                      c. Requiem
                      d. Weapon Synergy
                      f. Pure Evil: ROTD
                      g. Typhoon 2
                      h. Gemini
                      c. Death Wish 2
                      d. Drum Boy
                      e. Paralyzation
                      f. Turbo Shredder
                      g. Warhead
                      h. Shrederator
                      11- Danny Bailey (Bedford)
                      a. Death Threat 0.2
                      b. Crimson Thunder
                      c. Axes Of Evil
                      d. Cat With Wheels
                      e. Lethal Injection
                      f. Sithis
                      g. Roadblock
                      h. The Creature
                      12- ???
                      a. ???
                      b. ???
                      c. ???
                      d. ???
                      e. ???
                      f. ???
                      g. ???
                      h. ???
                      1 spot remaining! Who will grab that last spot?
                      By the way Alex H - you need to remove 2 of your vapours and replace them with real robots.
                      • #71
                        Masamune
                        Shape: Barrel shaped, with a 20 CM long wedge at the front, with a sword blade extender. More on this a little later.
                        Speed: 15 MPH
                        Size: 80x50x25 CMs (LWH)
                        GC: 3 CMs at the sides and rear, 0 at the front.
                        Armour: 6 mm Hardox all over except for a 5 mm Ali baseplate. With the exception of the wedge, the barrel is made out of one sheet of hardox so there are no plates that can just be torn off.
                        Weapon: Retractable sword lifter. The sword blade can be extended 15 CMs out from the wedge to allow it to get under any spinner safely, or it can be retracted to extend only a couple of CMs from the wedge to allow it to lift with more control. The actual moving part s the wedge, which is powered by two linear actuators and should be able to lift around 200 KGs. It can also be lowered slightly, causing the sword to dig into the floor slightly resulting in it being able to get under even 0 GC wedges and skirts. The actual sword blade is made from 5 mm grade 5 Ti.
                        Drive: 4 internal wheels with vulkanised tyres, powered by two S28-400 Magmotors at 24 volts.
                        Batteries: 4 packs of 24 volt NiCads.
                        Shrimech: The rollover barrel shape. If it gets stranded against a wall, it can use the sword to push itself away.
                        • #72
                          Oopss... missed that rule... hmmm....
                          Ill take out dante and baldur and put in....
                          T.R.A.C.I.E and bodyhammer (s1)
                          With two finallists how can I lose? lol
                          • #73
                            If there is a spot left, please save it for me!
                            • #74
                              To be fair, TRACIE is probably the best S1 robot to use if you ignore the fiact it has a 46kg weight disadvantage.
                              • #75
                                LOL, Mark has a 4-wheel drive thwackbot!!
