Eye Of The Robot - Annihilator
  • #46
    So why did you build a Mortis shaped robot?
    • #47
      Theres nothing wrong with the basic shape, its more that Mortis had a high ground clearance and seemingly continual mechanical failures...if it had been reliable and perhaps drven a bit better, it could have done much better than it did in the wars.
      • #48
        Having seen Mortis up close and personal, and having seen it in action several times I can assure you, Mortis was as reliable as any robot out there and way ahead of its time. Particularly in the live events higher groundclearence is not a downside either.
        • #49
          General tactics are to come in with the disc on anybody who happens to be in the way. Its a 5-way battle so proper tactics go out of the window
          • #50
            I realise that, I was just referring to the way they went out in series 3 and 4 (broken track? and lifter problems).
            • #51
              Darn It!!
              Another loss, but hey, at least I have a good machine.
              • #52
                Mark - I am +1>SO fed up of your annoying, continuous posts which lack common sense! You knew about your defeat way in advance and stop doing this. I wish now that Timothy was back, because compared to you, he was Einstein.
                +1>STOP SENDING IDIOTIC MESSAGES!
                • #53
                  Mark, just naff off. Nobody is going to help you if youre going to act like a total prat.
                  • #54
                    Joy - despite Marks idiotic filled posts, I feel in a good mood for today, and so will you (hopefully :wink after reading the next Annihilator round! Enjoy!
                    ROUND TWO
                    No Objections vs. Leprosy Infection vs. Requiem vs. Brutalis 2.0 vs. Spiny
                    NO OBJECTIONS vs. LEPROSY INFECTION vs. REQUIEM vs. BRUTALIS 2.0 vs. SPINY
                    Booth #1: Liam E, Joey M
                    Booth #2: Chris M
                    Booth #3: Dave S, Daniel S
                    Roboteers, stand by!!!
                    3€¦2€¦1€¦activate!!!
                    The three spinning weapons of Leprosy Infection, Spiny and Requiem rotate up to their velocity, and now No Objections and Brutalis move out, chosing a target€¦Joey has chosen, and aims for Requiem! Brutalis moves out and Leprosy is his target, but Chris speeds forward to greet it! Leprosy stylishly swifts to the left side of Dantomkia-shaped robot, and the teeth dig in, and Brutalis tumbles over! Marks in the Hardox bodywork are noted by the audience, and so is the quick response of Liam to thrust his robot back onto its wheels! Liam puts the power down to drive away, but Chris pushes on again, seeming to give Brutalis no rest and no room to run! Spiny meanwhile is having another go at Requiem, while No Objections seems to be remaining low€¦until now - Joey goes into a spin, and Requiem is suddenly forced back onto it by Dave! Suddenly, Daniel€™s robot experiences the blasts from the spinning ring and the spinning disc! His has left pieces of Ti/V Alloy scattered over the arena floor, allowing for another run-up by Spiny - BASH! This time, both machines are deflected! Elsewhere, the Leprosy Infection and Brutalis battle is still raging, but Brutalis is knocked over again! Another self-right, but another income of drum! Liam is starting to feel slightly worried, as he hasn€™t got an attack in on Leprosy, but suddenly reverses from Chris€™ robot and powers forward and at long last underneath! Now Brutalis is shoving the drummer to the edge€¦FLIP! No! Leprosy is only flung over, and now pushes unto the wedge of Brutalis once more, the turned-over drum scraping away at the front armour. No Objections is doing queit and effective work, pushing underneath Spiny and ramming it into the drum of Requiem! BOOM! Spiny gets flung up, and now Joey puts his power down and pushes Spiny across the ring and into Leprosy Infection! Spiny seems to have the powerful blade though, and Leprsoy takes some damage to the drum€¦NO - THE CHAIN HAS COME LOOSE! Daniel is pushing his controls in all directions, but something seems to have been dislodged from it! Requirem is being counted right down!
                    10€¦9€¦8€¦7€¦6€¦5€¦4€¦3€¦2 €¦1€¦cease!!!
                    Liam is relieved that he€™s through, but suddenly Spiny hits in! A Hardox panel flies off of the battebot, and he flies as well! Brutalis lands OOTA! But Liam knows he€™s safe, as Leprosy Infection, Spiny and No Objections stand strong!
                    Result:
                    Requirem needs more strength required, as well as a cab to go home!
                    BRUTALIS 2.0, LEPROSY INFECTION, NO OBJECTIONS AND SPINY GO THROUGH TO THE NEXT ROUND!!!
                    ROUND THREE
                    No Objections vs. Leprosy Infection vs. Brutalis 2.0 vs. Spiny
                    Send in tactics, comments, predictions and few helpers to clean the arena
                    • #55
                      *sends his minions to clean up the arena*
                      Im going to risk it and ask Liam if he wants some sort of a team up against the other two. Otherwise, my tactics are mostly the same - spin, move away if I stop spinning, avoid the pit, and if I have to target anyone, go for Leposy Infection with the lifter and stop the drum.
                      Good luck Liam, Chris, Dave
                      • #56
                        Why Chris, why?
                        Sure, Ill team up with Joey again. If I dont Im almost certainly out! I seem to be doing OK so far, considering this is my first proper tourney, but Brutalis is feeling the heat after that round!!
                        Good Luck everyone!
                        And Joey, I propose we target Leprosy- I WANT REVENGE.
                        Also, great battles from Paul it must be said.
                        • #57
                          Sorry Liam :sad:
                          Want to team up against Leprosy?
                          • #58
                            Im all for it Dave!
                            DIE LEPROSY DIE
                            • #59
                              Im going for Leprosy as well...Chris may need a binbag at some point
                              Take it as a compliment, we think your robots are so good they have to die...
                              • #60
                                Well, it seems I have 3 members for my new club:
                                KILL-LEPROSY-INFECTION-AFTER-WHAT-IT-DID-TO-ME
                                Members:
                                Me
                                Joey
                                Dave
