Eye Of The Robot - Challenge Belt
Id like to enter:
Holepunch
Weight: 100kg
Length: 100cm
Width : 70cm
Height: 40cm at the top of the beak, 28cm at the top of the armour.
Armour: 40mm Hdpe and 8mm 7075 aluminium baseplate.
Speed: 13mph - powered by 2 wheelchair motors running overvolted at 36v. with 150mm wheels
Shape: Razer-esqe looks, wedge at the front, a bit more boxy with rounded edges at the back.
Weapon: A Pneumatic crusher (yes i said Pneumatic) with a 250mm bore 120mm stroke full pressure 7075 aluminium 15mm wallthickness ram, giving a massive 25+ tonnes of force on the ram. this is levered down 2:1 giving 12.5 tonnes of force at the tip.
The Ram is fed by 4 burkert valves from 4 corners of the ram providing maximum flow to the ram. The beak is retracted by 2 gas springs at the front under the beak still protected from the sides.
Strengths: Very fast working beak, with tremendous force.The gear ratios on wheelchair motors provide a lot of pushing power all be it not very fast.
Weaknesses: This thing guzzles gas like a Hummer sucks petrol. I only have 5 to 7 good bites before the gasbottle starts to drain depending on the weather. To save weight I had to go for a slow drive. Selfrigting is also not garantueed.
Ground Clearance: 0mm at the front due to a sloaped front that scrapes the floor. 10 mm at the rear.
Srimech: when lucky it rolls over when the beak is in top position due to the low centre of gravity.
Notes: Still in development, so it is probably going to have some teething problems.
pictures:
All dressed up: http://www.computerclub.nl/uploads/fanfic/holepuncharmoured.jpghttp://www.computerclub.nl/uploads/f...charmoured.jpg
Barenaked: http://www.computerclub.nl/uploads/fanfic/holepunchwihoutarmour.jpghttp://www.computerclub.nl/uploads/f...houtarmour.jpg
Id like to enter:
Holepunch
Weight: 100kg
Length: 100cm
Width : 70cm
pictures:
If you wish to know how young, just check my profile :wink
