Given that some people have wished for me to do a minor, and given great enjoyment and pleasure I gained from reading Liams Challenge Belt battles, Im doing my own Challenge Belt battles. So...
EYE OF THE ROBOT - CHALLENGE BELT
The E.O.T.R tornumnent is having a bit of a rest, but due to the recent hypotheticals I€™ve been doing, I€™m doing a minor competition to keep me on task and keep me busy.
Now for the arena:
The Arena
The €˜WreckTaGon€™ is a hexagon shaped arena with three starting squares, coloured gold, green and blue. Originally, it had very little in the way of hazards, and still does, but these are very deadly - we still have the flipping spikes, and we also have the impaling spikes, set in sets of 5 in each corner of the arena, each made of Hardox and designed to cause serious damage. The pit release button for this arena is located on the bottom right side of the arena, with the actual pit being a mere 1meter away from it. Added hazards include the saws mounted into the floor to throw other robots away, and vertical flywheels behind each starting square - they weigh 50kg and spin at 1200rpm, each giving 50kj each. The arena is indestructible, with the floor being made of 50mm Hardox, with 3mm of polished Stainless Steel over the top of that, making the floor impossible to damage and VERY SLIPPERY! The walls are also made of 50mm Hardox, and are 65cm high, giving everyone the ability to flip someone OOTA! The arena (from a birds-eye view) is 5metres down and 7metres wide.
The Entry-Rules
€ I need 13 people to enter 1 robot (It MUST be a vapourbot)
€ Wheeled robots must weigh a maximum 100kg
€ Shuffling robots weigh a maximum of 110kg
€ Walkers weigh a maximum 135kg
€ When you enter, give me your hometown (if outside of the UK, tell me the country as well), and a link for your robot stats, so I can find them!
€ Once all the robots have been entered, I€™ll give the belt first of all to the robot with the most experience in E.O.T.R. I will then pick a random list of challengers. To keep a belt, you must win a total of 3 fights in a row., but you only get 1 chance at it.
The Judging System
Basically, Ive invented my own system - has 6 catogories, in which I mark out of 10. I then times that score in each section by how much the section is worth:
Dominance = ? x 6
Damage = ? x 5
Aggression = ? x 4
Stategy = ? x 3
Control = ? x 2
Style = ? x 1
So get entering! Only 13 spaces avaliable.
Now for the arena:
The Arena
The Entry-Rules
The Judging System
Dominance = ? x 6
Damage = ? x 5
Aggression = ? x 4
Stategy = ? x 3
Control = ? x 2
Style = ? x 1
