Design Your Own House Robot
    6 down, 3 more to get.
    Introducing the 10th house robot (in case anybody noted that I asked for 9 people to enter 1 bot each and there are 10 house robots).
    Name - Custard Cream
    Shape - Like a custard cream (http://i14.photobucket.com/albums/a305/Atomic_Train/custard-cream-big.jpghttp://i14.photobucket.com/albums/a3...-cream-big.jpg)
    Weight - 300KG
    Movement - 8 Wheel drive, using a similar set-up as Rocky Dennis, where the wheels are paired up in 4 dollies which can turn sideways to aid turning by the use of the software. The motors are Lem 200s
    Weapon - Apart from the CO2 self-righter on the top, there are a couple slicing sword blades which run around in the gap between the top and bottom biscuit.
    Ground clearance - 2CM apart from front wedge
    Turning Circle - nothing
    Speed - 10 mph, although it has a 360 degree weapon.
    Colour - Like a custard cream
    armour - 6mm hardox
    Strengths - The swords are rather nasty if they hit you
    Weaknesses - High ground clearance
      *nibbles on Custard Creams wedge*
      ...mmmmmmmmmm...creamy, yet crunchy all at once...
      ...Im very sorry. I let go of myself for a moment then, and I apologise sincerely. :sad:
        Its the latest in the line of food based objects. First you had the Pie of Doom (of which I wished I still had the picture), then the killer wedge (of cheese) and now Custard cream, the biscuit which bites
          Hmmmm... Ill have my stats up later tonight.
            Better late than never...
            Weight: 300kg
            Armour: 4mm Marine Fibreglass body.
            Speed: Roughly 15mph, powered by 4 x LEM200 Motors running at 48v geared down 3:1. Fin has 4 solid rubber wheels and uses a skid-steer driving system similar to Growler or Razer.
            Shape: Box wedge with sides. Think Spawn of Scutter from series 4.
            Weapon 1: The front wedge has a wedge extender made from 5mm Titanium and 2 thick Hardox horns mounted on the top of the wedge to trap robots on the wedge and drive them around the arena.
            Weapon 2:2 x Hardox drums (70cm long with a diameter of 30cm), each with hundreds of small Titanium teeth, each tooth being only 5mm long. Each drum is powered by 2 3120 Husqvarna chainsaw motors geared down 4:1 so the drums spin at just under 2700RPM. Each drum weighs 45kg and is mounted on each side of the robot to stop opponents side-swiping the machine. Each drum packs around 30kJ of power.
            Weapon 3: A double headed axe mounted on a horizontal pivot (think Abaddon€™s bowling ball thing from series 3).
            Strengths: Multiple weaponry, good speed and pushing power.
            Weaknesses: Considerably lightweight compared to other House Robots, no srimech.
            Ground Clearance: 0mm on front, 1cm on sides, 5cm on back.
            Srimech: None!!!!!!!11!!!!!!OMGWTFN00B!!!!
              We need 2 more house robots.
                You took the words out of my mouth.
                Wheres Franky, he has a twisted mind.
                • #23
                  True.... Kustom 2 would be a great house robot....
                  • #24
                    At the risk of sounding like Mark, is there any more news on this?
                    • #25
                      House Bots:
                      Magnavox
                      Apocalypinator
                      Golden Lotus
                      Night Stalker
                      Die-Ro
                      Custard Cream
                      Fin
                      Exa-Gore-Ic: Evo
                      We still need 2 more house bots.
                      • #26
                        dont worry Joey, theres always someone that sounds like Mark more than you do :wink:
                        • #27
                          And his name begins with M and ends with K :wink:
                          • #28
                            Whos Mick?
                            • #29
                              Muck, more like.
                              • #30
                                No, hes talking about Mack. Duh.
