Incidentally, Ive been looking throught the stats like the sad person I am, and I think its fair to point out to Andre that his robots appear to defy the laws of physics, particuarly in regard to their dimensions and invertability.
k, for my LW , I knocked this together very fast, so feel free to notice any big flaws
Shape: See link
Weight: 27 kg
Drive: 4 wheels, 1 S28-150 MAG @ 24 V PER wheel
Speed: 14 mph max
Armour: 4 mm titanium except for the wedges which is 6 mm
GC: 0 mm under wedge, 1 mm anywhere else
Srimech: invertible
The deal: Its a Rammstein-ish bot split in the middle and linked with an electromagnet. Yes, its a clusterbot made of 2 identical part. The fun part is that I can either link them like pictured (like Rammstein) and make it run like 1 rambot or I can link them so that BOTH wedges face the ground and run them like 2 rambot!
THE BOX IS LOCKED, THE LIGHTS ARE ON, ITS ROBOT FIGHTING TIME!!
Thanks everyone. Heres the line-ups. So theyre unimaginative. So what?
LIGHTWEIGHTS
Against vs Radioactive
Anti Virus 2.0 vs ROID
Claw vs Spinny
Little Stingray vs Titanium Titan
MIDDLEWEIGHTS
Bonz vs Purer
Killoteeny vs Solstice 2.0
Life vs Spin Cycle
Media Diablo vs With You
HEAVYWEIGHTS
Back To Rock 3 vs Sir Spinalot
E Clawdius Unum vs Static Shock
No Objections vs Supreme Glory Omega
Shadow Zone Returns vs Wedgas Revenge
SUPERHEAVYWEIGHTS
Flick Of The Wrist* vs Sekhmet
Manic Monsoon XL vs Shovearound 2
Mauler vs SLAM!
Revolver vs Tax Cutter
OK, tactics/predictions everyone.
*With Flick Of The Wrist being as it is, Ill specify how the rules work around it. The rule that 50% of a clusterbot has to be knocked out to rule the whole thing out still stands, BUT because this is a HW and a MW, knocking out With You will not satisfy this. Youll have to knock out FOTW to win.
Against vs. RADIOACTIVE:
I reckon I could have better maneuvrability here, and four extra kilos at least. Basically wedge under the side, and shove into the hazards (Im assuming this is the BattleBox arena, seeing as its a Battlebots tournament and all...), particuarly the hammers, and generally try and dominate it.
LIFE vs. Spin Cycle
Uh...dont really think I can do detailed tactice here. Just flip it around, and hope something breaks.
NO OBJECTIONS vs. Supreme Glory Omega
Right, the difficult one, as SGO is really the sort of robot No Objections is weak against. Basically spin around and raise the lifter slightly so that the axe will (hopefully) be deflected before it hits thorugh the armour, and wait for it to charge head on and (again, hopefully) send it flying. One more thing, though; if I get the opportunity, when its inverted Ill go in with the lifter and try and stack it on the spikes. Tough fight though.
Flick Of The Wrist/With You vs. SEKHMET
Go into thwackbot mode from the go, try and immobilise one of them with a hit. If its FOTW, great, if not, go after FOTW with the front forks fully down, break its traction (should be easyish as I have 2WD to its 6WD, giving me in theory better maneuvrability) and slam it around.
I was thinking precisely that... Also, its not actually explained what the teeth on Mauler do, Id assume theyre attached to something that spins, but you never know, it might be a covering for some kind of evil toothbrush weapon.
Im assuming Im fighting Spin Cycle with Anti-Virus in the LWs, so...
Anti Virus 2.0 vs Spin Cycle
Ram it. The armour can hold up well. Nothing further.
Well, my blades are pretty long. I should be able to hit him before he gets in range with the axe. Tactics? DESTROY IT.
Lol, how many times am I gonna get drawn against Wedga? Basically ram him to death with the front scoop, using the rear flipper only to self-right, or to take advantage if he runs out of flips. Should get under his skirts with little difficulty, so attack anywhere.
Charge straight into the disc to prevent it scratching my lovely paint job if it reaches full speed. Hack it to death, aim for the wheels mostly but generally hit anywhere I can. Oh, and do avoid leaving the axe down when his disc comes into play, as quite often axes get ripped off.
