The Crash & Burn Tournament: The Dual Duels
  • #76
    Theyre are in E.O.T.R 4.
    • #77
      Paul, let him answer. I know you are trying to be helpful but please let people speak for themselves.
      • #78
        Yeah, I would, Danny. ^_^
        • #79
          Right then. Two more people.
          • #80
            Me and Samuel agreed over email to go with:
            Death Threat/Death Wish
            Axes of Evil/Terrorhurtz
            Cat With Wheels/Turbo Shredder
            Crimson Thunder/Walk Dont Run
            Sithis/Tornado
            Lethal Injection/Paralysation
            Bigger Brother/Shederator
            Wild Thing/Black Death
            Havent thought of a team name, though.
            • #81
              Please enter Sir Spinalot, please.
              • #82
                You need seven more robots, and someone else with eight robots to team up with.
                (Message edited by joeychevron on March 27, 200
                • #83
                  Biohazard, Vlad the impaler, hypno-disc, chaos 2, razer, the matador, war-head. 7 robots
                  • #84
                    Infusion - New version to come
                    Wyfe Beater - To finish design
                    Kingler - To finish design/stats
                    MDU 4.1 - To finish design/stats
                    Attraction - Needs render finished
                    Kinetic Intent - Needs render finished
                    Black & White - Small upgrades
                    Wheel O Misfortune - New version to come
                    • #85
                      All right, Andre, I will let you in only if someone wants to team up with you, but I cant promise anything.
                      Who would like to team up with him?
                      At least 1 more entrant needed. Dave? Tony? Alex MW? Chezza?
                      • #86
                        Stats coming later today
                        • #87
                          Alright.
                          Still one more person needed.
                          • #88
                            Robot Name: Drumroll SR
                            Shape: Box wedge shape (with the wedge pointing to the rear) with killer drum attached to the front. Small wedge-forks are fitted at the front to guide opponent robots up to the drum.
                            Colour: Sides and wedge are a fabby metallic blue, while the drum itself is white with the teeth painted red
                            Speed: 14mph
                            Armour:4mm hardox sides underneath an 8mm layer of HDPE, 4mm hardox rear wedge (sloped at 45*), 6mm aluminium base (with lightening holes) and 12mm HDPE top panel
                            Drive: A pair of PMG 080 Perm motors running at 24V through custom-made 12:1 ratio gearboxes driving 200mm wheels.
                            Power: 2 x 36V 4500mAh Nicad packs connected in parallel. Dual rates on the transmitter ensure that the drive motors receive a maximum of 24V
                            Motivation: A pair of 200mm wheels custom-made from HDPE (like Tough as Nails) with go-kart tyre tread screwed on
                            Ground Clearance: 0mm at the front forks rising to 8mm at the back (Sides slope from 0mm-8mm)
                            Turning Circle: 0
                            Dimensions: 90cm x 80cm x 18cm
                            Weaponry: A front-facing spinning drum weighing in at 14kg with Hardox 650 bar-teeth bolted/welded on. It is powered by two LEM-130 motors running at 36V on a 1.5:1 ratio belt-drive to the drum and is capable of delivering 6 kJ of energy per hit
                            Srimech: None - can run both ways up
                            Notes: A scaled up version of my featherweight robot Drumroll
                            Robot Name: Dr. Acula (yes I€™ve been watching Scrubs recently)
                            Shape: T-shaped robot with all the components (drive, batteries, weapon components) mounted in a long compartment at the back of the robot (i.e. the horizontal line of the T-shape) with two crushing claws connected together therefore moving as one sitting in the middle of the component pod and coming out at right angles to it.
                            Colour: The body is all black but the claws are white with red €˜blood€™ effects on the tips
                            Speed: 20mph max
                            Armour:4mm hardox for the front and back of the component pod again with 8mm HDPE covering it. It has 6mm hardox protecting the wheels, which are located at either end of the pod. The claws are made out of 8mm hardox and have 12mm titanium tips while the wedge for the other robots to ride up to the claw is angled 4mm hardox.
                            Drive: A pair of 12V Bosch 400W motors running at 24V through a 10:1 chain drive reduction onto 254mm (standard 10€) go-kart wheels.
                            Power: 4 x 24V 3000mAh Nicad packs in parallel
                            Motivation: 254mm go-kart wheels, chain driven
                            Ground Clearance: 0mm at the front where the wedge of the claw touches the ground. 10mm everywhere else
                            Turning Circle: 0
                            Dimensions: 125cm x 80cm x 50cm
                            Weaponry: A pair of crushing claws that bite down, powered by two LA36 Linak linear actuator, both rated at 10000N (1 tonne).
                            Srimech: Can run inverted but claw becomes ineffective upside-down
                            Notes: Although this robot may not crush with as much devastation as the likes of Razer, it still has enough power to pierce and deform (more easily) forms of plastic armour such as polycarb or HDPE top panels. 1 tonne of force is also plenty to grip with allowing Dr. Acula to take his victims wherever in the arena he pleases
                            Robot Name: Firefly
                            Shape: Curvy box-shaped rammer with actuated plough/wedge.
                            Colour: Yellow body (black highlighty bits here and there) with natural-material colour for the plough
                            Speed: 22mph
                            Armour: Welded box-section chassis armoured with 8mm titanium covers.
                            Drive: A pair of LEM-130 motors running at 48V through 10:1 ratio gearboxes driving four 254mm go-kart wheels
                            Power: 4 x 24V 3700mAh Nicad packs connected in series and parallel.
                            Motivation: Four wheel drive using 254mm go-kart wheels; gearbox output shaft connected to front wheels with chains taking drive to the rear wheels.
                            Ground Clearance: 8mm all round, but 0mm at the plough when it€™s touching the ground.
                            Turning Circle: 0
                            Dimensions: 90cm x 80cm x 24cm
                            Weaponry: A plough/wedge that runs at the front of the robot (a bit like a snow-plough). It pivots just past the centre of the robot, mounted on a shaft. This shaft is connected via heavy-duty chain to a custom-built gearbox, all driven by a LEM-170 motor. It powers the plough so it can act as a lifter, and travels 90* from horizontal to vertical
                            Srimech: None - can run both ways up, weapon also effective both ways up (ala Big Nipper)
                            Notes: Inspired by a machine from Thunderbirds and adapted to suit robotic combat
                            I will add five real robots to these three (sorry I know its cheating a bit but it always takes me longer than I think to make up vapourbots - will get my own whole team made up one of these days :P)
                            Big Nipper
                            Sewer Snake
                            Tough As Nails
                            Pussycat
                            Kronic
                            (all current versions of real robots)
                            Ill try and get some pics drawn of my vapourbots just to make it easier to visualise them, doubt Ill have them ready before the start of the tourney though.
                            Anything you think I need to change, just let me know
                            • #89
                              Its all fine Jamie.
                              • #90
                                Is there an official list of whos teamed with who and who still needs stats in?
