k, Ill change my entry than, if Im allowed to use fantasy-parts
Name - If it looks like a tank...
Shape - See the link at the bottom of this post
Weight - 100 Kilogram
Speed - 15 mph
Dimensions - 90x80x25 cm
Ground Clearance - 0 right underneath the tracks, but pretty big everywhere else
Power - I asked an over-muscular dwarf to power a hamster-wheel. Dwarfs are much cheaper and lighter than LEMs and given the right medicin deliver aLOT more power. Also dwarfs dont get tired.
Movement - A pair of tracks. The tracks themselves are made of whateverium which has the feature that its indestructible. I sprayed a layer of cantthinkofanameium-spray over the tracks which has the feature that it cant be pushed by other bots.
Turning Circle - Zero
Weaponry - A pnuematic spike which comes out horizontally from the upper part of the robot, at about 15 cm from the ground. The spike comes out a large barrel which is mounted on a free moving turret, mounted on top of the machine. The spike is powered by a 2 kg gas tank which contains CO8, 4 times as powerful as CO2, and it has the feature that it goes back into the gas tank after use, AND that it can savely be stored at 15000 PSI, the spike comes out with 4000 kJ.
Armour - Like the tracks, 1 mm of whateverium, which cant be destroyed by any means, I sprayed the whole machine with onetwothreeium-spray, which has the feature that it cant be flipped by any means.
Srimech - The onetwothreeium-spray makes sure I wont be flipped.
Notes - This machine is so dangerous that when not in use, its guarded by 2 dwarfs 24/7, as can be seen in the picture.
you two clearly arent aware of the drill around here, now nobody can force you to do it our way, but the big ammount of unorganised topics floating around gets annoying very quickly
please take a look at this topic, made especially for newcomers like you 2
Power - 4 LEM130s. thanks to recent advances in quantum mechanics, the LEMs are actually outside the bot, and only the power is inside
Movement - Four solid Unobtainium wheels.
Weaponry - Quantum Disc. This disc, again thanks to quantum mechanics that are SO ADVANCED you wouldnt begin to understand it, can cause a total existance failure to the bot it impacts with. It also has 100kj power
Armour - 2CM Unobtanium. This is an element thats incredibly light to start with as well as stronger than hardox, and Ive atomically altered it to be better.
Srimech - invertible
Notes - Before anyone says this is impossible, my mothers a socialist and I spent a year in Spain. What do you say to that?
