Virtual Robot Wars
  • #31
    Virtual Robot Wars
    Wow! I must enter this thing!
    Reserve me a place please!
    • #32
      Virtual Robot Wars
      Ok AJ, no reservations, but you can enter automatically.
      • #33
        Virtual Robot Wars
        Sorry, I 4got the weight of Brutalis 1.0. Its 100kg,as its my 1st vapourbot Im really plzd u think its a contender!
        • #34
          Virtual Robot Wars
          k, Ill change my entry than, if Im allowed to use fantasy-parts
          Name - If it looks like a tank...
          Shape - See the link at the bottom of this post
          Weight - 100 Kilogram
          Speed - 15 mph
          Dimensions - 90x80x25 cm
          Ground Clearance - 0 right underneath the tracks, but pretty big everywhere else
          Power - I asked an over-muscular dwarf to power a hamster-wheel. Dwarfs are much cheaper and lighter than LEMs and given the right medicin deliver aLOT more power. Also dwarfs dont get tired.
          Movement - A pair of tracks. The tracks themselves are made of whateverium which has the feature that its indestructible. I sprayed a layer of cantthinkofanameium-spray over the tracks which has the feature that it cant be pushed by other bots.
          Turning Circle - Zero
          Weaponry - A pnuematic spike which comes out horizontally from the upper part of the robot, at about 15 cm from the ground. The spike comes out a large barrel which is mounted on a free moving turret, mounted on top of the machine. The spike is powered by a 2 kg gas tank which contains CO8, 4 times as powerful as CO2, and it has the feature that it goes back into the gas tank after use, AND that it can savely be stored at 15000 PSI, the spike comes out with 4000 kJ.
          Armour - Like the tracks, 1 mm of whateverium, which cant be destroyed by any means, I sprayed the whole machine with onetwothreeium-spray, which has the feature that it cant be flipped by any means.
          Srimech - The onetwothreeium-spray makes sure I wont be flipped.
          Notes - This machine is so dangerous that when not in use, its guarded by 2 dwarfs 24/7, as can be seen in the picture.
          http://upload.wikimedia.org/wikipedia/commons/a/a8/Indian_Army_T-90.jpghttp://upload.wikimedia.org/wikipedi..._Army_T-90.jpg
          • #35
            Virtual Robot Wars
            How does it turn with only one dwarf hamster wheel powering it?
            • #36
              Virtual Robot Wars
              satalite navigation
              • #37
                Virtual Robot Wars
                Right...Ive got to think of something to stop it now...
                • #38
                  Virtual Robot Wars
                  maybe you should call the tank like robot Tank.
                  • #39
                    Virtual Robot Wars
                    Can we enter mor than 1 bot?U might not get 64 otherwise
                    • #40
                      Virtual Robot Wars
                      sure.
                      • #41
                        Virtual Robot Wars
                        Ill enter my other 4 vapours:
                        Death Premonition
                        Henry VIII, King of Roboland
                        System Shock
                        LockJaw
                        The stats can be found on my profile.
                        • #42
                          Virtual Robot Wars
                          just call it Henry VIII, ok? That way I do not have to keep typing it.
                          • #43
                            Virtual Robot Wars
                            Mark&Liam
                            you two clearly arent aware of the drill around here, now nobody can force you to do it our way, but the big ammount of unorganised topics floating around gets annoying very quickly
                            please take a look at this topic, made especially for newcomers like you 2
                            http://www.fightingrobots.co.uk/discus/messages/760/10980.html?1205620349http://www.fightingrobots.co.uk/disc...tml?1205620349
                            please use this topic as the starting point of your fantasy robotic career, thank you very much
                            • #44
                              Virtual Robot Wars
                              Well, at least I do not quit my tournament once I start it, Unlike some people.(not you)
                              • #45
                                Virtual Robot Wars
                                Name - Quantum
                                Shape - Spuare
                                Speed - 30 mph
                                Ground Clearance: 0mm with skirts.
                                Power - 4 LEM130s. thanks to recent advances in quantum mechanics, the LEMs are actually outside the bot, and only the power is inside
                                Movement - Four solid Unobtainium wheels.
                                Weaponry - Quantum Disc. This disc, again thanks to quantum mechanics that are SO ADVANCED you wouldnt begin to understand it, can cause a total existance failure to the bot it impacts with. It also has 100kj power
                                Armour - 2CM Unobtanium. This is an element thats incredibly light to start with as well as stronger than hardox, and Ive atomically altered it to be better.
                                Srimech - invertible
                                Notes - Before anyone says this is impossible, my mothers a socialist and I spent a year in Spain. What do you say to that?
