The Chevron Championship
48v, Mr. Kody, although Im not sure if it particuarly matters...having said that, Im thinking of having custom house robots for the next series.
TUG OF WAR
THE 6ISC
3
2
1
ACTIVATE
And the machines start pulling, The 6isc sporting a rather unnatural extension to the weapon today, so the chain can clip on to something. Its even so far, Dead Metal pulling The 6isc sometimes, and then vice versa. The house robot is pulled backwards by Franks machine, but turns slightly, and floors the power...and The 6iscs rear wheels lift off the ground! Its traction is greatly reduced, and Dead Metal now has no difficulty pulling the axlebot towards the pit...just at the end, The 6isc manages to get four wheels on the floor again, but its too little, too late, and it tips into the smoke!
The 6isc - 18 seconds
DEATH VIA DRUM
3
2
1
ACTIVATE
D.V.D. reverses, as the chain pulls taut, and it jitters forward slightly as Dead Metal pulls on the other end. Paul grits his teeth, and D.V.D. slowly begins moving backwards - but Dead Metal drives forward, and D.V.D jerks towards the pit about three inches before getting grip again. There are more periods of each pulling the other slightly, with Dead Metal perhaps gaining the advantage a bit more often, but D.V.D. isnt going down very fast, and the seconds tick down, both machines seeming to give up as Paul looks relieved.
D.V.D. - SURVIVED
CRASH BANDI-BOT 3
3
2
1
ACTIVATE
Crash begins to pull, the chain tightening as it tries to get a grip on Dead Metal, but it moves back towards the pit instead! Chris holds his transmitter above his head, and Crashs wheels spin, and slowly get traction and reverse the direction of travel. Dead Metal pulls again, and Crash moves back, but getting grip on the floor again, and pulling the house robot briefly. This seems to be repeating itself quite a bit here, both machines pulling, but neither dominating the other. Crash pulls again, and actually manages to pull Dead Metal further...but the opponent digs in, and drags Crash forward...and forward...and forward...and on the edge of the pit! Chris is shaking his head, all it would take is one final pull, and Dead Metal drives down the ramp to oblige and submerge Crash Bandi-Bot.
CRASH BANDI-BOT 3 - 28.75 secs
BACK TO ROCK III
3
2
1
ACTIVATE
Tugging begins, and immediately it would seem Back To Rock has the upper hand here, with its six wheel drive giving it more power, pulling the house robot towards the pit...Dead Metal regains ground, though, briefly pulling Back To Rock back. Martijn digs in, though, and Back To Rock pulls forward again, before Dead Metal moves back, and then more pulling, and the house robot edges towards the pit...Dead Metal turns into the pulling, but one of its wheels is on the edge! Back To Rock reverses near the pit, and then floors the power, pulling the chain taut, and Dead Metal slides into oblivion!
BACK TO ROCK III - WON in 24.5 secs
MACDUFF THE THIRD
3
2
1
ACTIVATE
Macduff begins pulling, and almost immediately it would seem he faces little resistance, pulling Dead Metal along almost effortlessly, almost to the pit, but the house robot finds some traction, and Macduff goes forwards, only slightly though. MacDuff resumes pulling, the tracks scraping the platform surface, as it drags Dead Metal backwards in a cloud of tyre smoke-
BANG! Suddenly, a puff of smoke comes from the right hand side of Macduff, and Dead Metal moves away from the pit a few inches! Kody cranes his neck to see whats going on, looking concerned, but Dead Metal now dragging Macduff towards the pit slowly, amidst wheelspin...Kody tries his controls, and MacDuff turns on one side, then moves slightly forward on its remaining track and slams the corner of the wedge into the wall! Now this presents a problem, as the wedge is digging in to the wall and preventing Dead Metal from being able to pull Macduff further. Theres struggling, but it isnt going anywhere fast, the wedge stabbing deeper into the side and preventing movement before the time runs out.
In the pits, Kody discovered a fuse in the right side speed controller had blown during the pulling, having problems with the high current draw.
Macduff The Third - SURVIVED
LEADERBOARD:
1: Back To Rock III - Victorious
2: D.V.D. - Survived
3: Macduff The Third - Survived
4: Crash Bandi-Bot 3 - 28.75 secs
5: The 6isc - 18 secs (OUT)
Sorry Frank, The 6iscs time is up.
THE SEMI FINALS
Back To Rock III vs. Macduff The Third
D.V.D. vs. Crash Bandi-Bot 3
Tactics, thoughts, comments, predictions, parrots?
TUG OF WAR
THE 6ISC
3
2
1
ACTIVATE
DEATH VIA DRUM
3
2
1
ACTIVATE
D.V.D. - SURVIVED
CRASH BANDI-BOT 3
3
2
1
ACTIVATE
BACK TO ROCK III
3
2
1
ACTIVATE
MACDUFF THE THIRD
3
2
1
ACTIVATE
LEADERBOARD:
THE SEMI FINALS
Ill have to avoid that lifter getting at my sides of course, which shouldnt be that much of a problem either, but with Martijn, who knows? :wink:
Seriously, I think its a great design, it just got drawn in the wrong heat. I could never have come up with something like that...
