My first REAL tournament... ROBOBASH!!!!
  • My first REAL tournament... ROBOBASH!!!!
    OK,Ive decided to start a tournament, all because Ive been so bored and all that, so... anyone want to register?
    The rules are standard robot wars rules.
    Theres going to be 16 Heats, and 2 three way melees for the first eliminators, and then one on one from then on...
    So, send me your entries.
    Team 1
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 2
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 3
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 4
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 5
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 6
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 7
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 8
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 9
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 10
    a:
    b:
    c:
    d:
    e:
    f:
    g:
    h:
    Team 11: UK Realies
    a: Terrorhurtz
    b: Dantomkia
    c: Chaos 2
    d: Thermidor 2
    e: Typhoon 2
    f: Wheely Big Cheese
    g: Turbulence
    h: Dominator 2
    Team 12: US Realies
    a: Hexadecimator
    b: Sewer Snake
    c: Revolutionist
    d: Panzer Mk 4
    e: Manta
    f: Biohazard
    g: Nightmare
    h: Tazbot
    Erm...Samuel, maybe you should wait for other people to join in before putting in realie slots?
    Eh, count me in.
    TEAM ZLAYERZ
    1. Wedginator 6.0
    2. Super Gore Evo
    3. Seung Mina III
    4. Tira III
    5. Killobite 5.0
    6. Intrigue
    7. Macduff the 2nd
    8. Aftershock
    http://strickenone.proboards99.com/i...?board=heavies
      Well, Ill enter with my new designs that Ive built and cared about, ONLY FOR THEM TO GET DESTOYED *Bursts into tears* :sad:
      Well, Heres my group for Team Insanity
      1.MeCANNIBAL 2.0
      € WEIGHT: 110kg (Shuffler)
      € ARMOUR: 5MM Titanium on top and bottom.
      € SHAPE: Invertible low cylinder
      € MOTORS: 2 x S28-400 MagMotors at 36V = 12HP
      € LOCOMOTION: 2 x Shuffling pads
      € DIMENSIONS: (L) 80CM (W) 80CM (H) 20CM
      € COLOUR: Black with scary human face with over sized teeth coloured red.
      € WEAPONRY: Ring spinner, made of 8MM Harox, weighing 30KG, powered by 2 x LEM130€™s at 36V to give it spinning speed of 3000RPM and producing 195KJ per blow with a spin-up time of 3.5 seconds. It 2 big teeth made of Hardox that curve out. The teeth are inserted into the body and have rows of Tool Steel spikes on the teeth to dig in. These teeth 5kg each and are designed to send all the spinning energy into one spot rather than small amount into multiple spots. It also has 5 Inches worth of Titanium shock-proof Foam to stop it self-destructing.
      € SPEED: 15MPH
      € GROUND CLEARANCE: 0MM-8MM. It has a full-bodied 5mm Titanium skirt running completely along the ground that rises when the shell is spinning, but drops when the shell isn€™t spinning. This is powered by a simple 750w Bosch 36V motor and runs at the same time as the spinner.
      € STRENGTH: Scary name and weapon
      € WEAKNESS: Hard to control
      2.AUTOISM 2.0
      € WEIGHT: 100kg
      € ARMOUR: 5mm Monocque Hardox on front, rear and top. 4mm Hardox for the Sides and Base.
      € SHAPE: Box with Pointed (Triangular) Sides and Rear to lower spinner Effectiveness.
      € MOTORS: 2 x Lem130 at 36V = 18HP
      € LOCOMOTION: 4 x Vulkaon treaded wheels on top and bottom ala Big Nipper. The wheels are now 85mm in diameter, giving better grip than before.
      € DIMENSIONS: (L) 75CM (W) 70CM (H) 25CM
      € COLOUR: Black for the body, Silver for the crushing weapon. Now, on top, it has the name €˜AUTOISM€™ written in silver.
      € WEAPONRY: The weapon for this is still a Big Nipper style crushing/lifting arm, but instead of claws to lift with, it has a pair of pliars to lift and crush with. The pair of 3.25mm Hardox pliars works on the same system as the lifter as the pliars are part of the lifter to avoid being torn out by spinners. The weapon lifts and crushes with a force of 9 Tonnes, using a Razer-like mechanism for lifting and crushing! The new crushing weapon means that if flipped, the robot doesnt need to self-right. The bottom part of the jaw is wider than before, to allow for more grip on the opponent
      € SPEED: 13MPH
      € GROUND CLEARANCE: 0MM - 8MM. 4MM Hardox sprung skirts on the sides and rear make it a nightmare to get under.
      € STRENGTH: Power and Weapons make it a tough machine
      € WEAKNESS: Weak side armour.
      3.KNOCKING-OUT
      € WEIGHT: 100KG
      € ARMOUR: 5mm Titanium
      € SHAPE: Low box with a speed bump on top to give the axe a place to rest and prevent fast robots speeding over the top of me.
      € LOCOMOTION: 4 x Vulkanised wheels
      € DIMENSIONS: (L) 70CM (H) 26CM (W) 70CM
      € COLOUR: The body is black, and the skirts are silver with flames streaking off
      € WEAPONRY: An 8KG Terrorhurtz sytle axe, all made of Hardox. The head is blunted, and had Hardox spikes on the blades. It€™s powered by an 80MM 750PSI Bore ram. 2.5 tonnes of force at the axe. To protect it against spinners, 3 inches of Titanium foam is put in to protect it.
      € SPEED: 15MPH
      € GROUND CLEARANCE: 0MM-7MM. On the rear and sides are skirts made of 8MM Titanium. They are bolted down the middle with 1CM Titanium bolts. On the front is a fixed skirt, made of 5MM Hardox to get under things.
      € STRENGTH: Deadly to all Invertible robots.
      € WEAKNESS: Easily flipped
      4.NITRO-GENE 4.0
      € WEIGHT: 100kg
      € ARMOUR: 5mm Hardox for the body. 6mm Hardox flipper.
      € SHAPE: Low invertible box with pointed sides and rear. At the front is a Storm 2 style wedge to aid in getting underneath other robots. The scoop is now concave to slow down FBS robots and make them easier to fight.
      € MOTORS: 4 x LEM 130€™s at 36V = 36HP
      € LOCOMOTION: 4 Vulkanised Wheels.
      € DIMENSIONS: (L) 90CM (H) 17CM (W) 70CM
      € COLOUR: Black all over with the flipper coloured red.
      € WEAPONRY: A full pressure Nitrogen powered flipper at 1000psi, using a single 80mm ram at 1000psi. The flipper is mounted in the middle of the robot, and is 20cm wide and runs 30cm up the body. Using a 3cm long Titanium strip underneath the flipper, and a heavy flipping arm, the flipper runs completely along the ground. Running on a ratio 2.8:1, the flipper produces 1800kg of force at the tips, allowing me to launch anyone away! This version has 2 x 3kg Nitrogen bottles, giving me 25 flips!
      € SPEED: 22mph
      € GROUND CLEARANCE: 0MM-2CM. At the front, it is completely 0mm. On the sides/rear, its 2cm. The orginal weakness of Nitro-Gene (its high ground clearance) has been seen to by the skirts on the sides/rear. They are 5mm Titanium skirts and are joined together like BioHazard - at the corners. To avoid them breaking off, they are held in place by Hardox hinges.
      € STRENGTH: Pushing power and weaponry.
      € WEAKNESS: High speed may mean difficult driving
      5.TRI-TAINIUM
      € WEIGHT: 100kg
      € ARMOUR: 4mm Hardox for the back/scoop. The top and bottom panels are 5mm Titanium and the sloped sides are 6mm Hardox to sheild the wheels.
      € SHAPE: Low invertible box with a front scoop (the scoop has a slight dip in it to help get under other robots better) and sloped sides.
      € MOTORS: 2 x LEM 130€™s at 36V = 18HP
      € DIMENSIONS: (L) 60CM (H) 20CM (W) 60CM
      € COLOUR: Unpainted, with the exception of the name on top written in black paint.
      € WEAPONRY: The weaponry consists of 3 x 9kg discs, made out of 1cm of Titanium with 3 Hardox bludgening teeth. The discs are set on the same axle, and amounted deep into the scoop, with the teeth just reaching towards the lip of the scoop, so the uppercut movement of the discs can attack base-panels and the like. The discs are powered by 2 x LEM130s at 36V. Set on a ratio of 1.5:1, it gives off 3600rpm. The discs, combined together make 27kg, so the force given out is 165kj per hit! Large amounts of Rubber amounted behind the scoop stops the risk of self-destruction.
      € SPEED: 18mph
      € GROUND CLEARANCE: 0MM-1CM. At the front, it is completely 0mm. On the sides/rear, its 1cm.
      € STRENGTH: Weaponry.
      € WEAKNESS: Completely new design.
      6.WORCK
      € WEIGHT: 100kg
      € ARMOUR: 5mm Hardox for the body and flipper. 6mm Hardox for the scoop. There are wedges on the sides and rear of Worck made of 3.25mm Hardox.
      € SHAPE: A low wedge shape.
      € DIMENSIONS: (L) 70CM (H) 13CM (W) 70CM
      € COLOUR: Black for the flipper and barbs, white for the body.
      € WEAPONRY: A forward hindged flipper, running on a single 750psi ram running on CO2. The gas is contained in 2 x 5kg bottles, giving me 40 flips per fight, and the gearing on the ram 3:1 means we have 1300kg of flipping force! That should mean on a forward hindged flipper that I can flip almost everything OOTA.
      € SPEED: 13mph
      € GROUND CLEARANCE: The wedges make the ground clearance effectively zero, but underneath the wedges is 5mm of clearance. The wedges are held on
      € STRENGTH: Near impossible to get under.
      € WEAKNESS: Low speeds.
      7.D.V.D (Death Via Drum)
      € WEIGHT: 100kg
      € ARMOUR: 5mm Hardox.
      € SHAPE: An invertible box shape with triangular sides and rear.
      € MOTORS: 2 x LEM130€™s at 36V = 18HP
      € LOCOMOTION: 4 Vulkanised Wheels on top and bottom ala Big Nipper.
      € DIMENSIONS: (L) 70CM (H) 23CM (W) 70CM
      € COLOUR: Black for the drum, white for the body.
      € WEAPONRY: At the front is a 15kg drum, made of Titanium with 3 sharpened tool steel teeth. The drum is powered by 2 x LEM130€™s on a ratio of 1.5:1, giving a spinning speed of 6500rpm! 65kj of energy per hit, and if flipped, the drum can be reversed to help it spin the right way - upwards. Behind the drum, there are massive amounts of shock-proofing to avoid self-destruction.
      € SPEED: 13mph
      € GROUND CLEARANCE: The ground clearance is the same all the way around, due to no skirts or wedge - its 6mm all around.
      € STRENGTH: Good all-rounder.
      8. A.R.R.T.D.S (Annoying Ramming Robot That Doesn€™t Stop)
      € ARMOUR: 7mm Hardox Monocuque.
      € SHAPE: Invertible box with flat front, sides and rear
      € MOTORS: 2 x C42-500 MagMotors at 60V = 60HP
      € LOCOMOTION: 2 x Shuffling Pads
      € DIMENSIONS: (L) 90CM (H) 15CM (W) 90CM
      € COLOUR: Black/White stripes
      € WEAPONRY: None.
      € SPEED: 28MPH
      € GROUND CLEARANCE: 0-5MM - Skirts on all sides made of 6mm Hardox prevent anything underneath any of the sides.
      € STRENGTH: Speed and power
      € WEAKNESS: No damaging weapons
        Samuel, people are gonna be slightly annyoed by the ammount of realies they cant chose this way
        that said
        Axe to Fall
        Flick of the Wrist
        Sheer Heart Attack 2
        Back to Rock III
        Liar 2
        With or Without you
        Another Night at the Bar
        Storm 2
          Dante
          Baldur
          Darkestar
          Slaying Mantis
          Scaramanga 2
          Salamander III
          Archangel of the Abyss
          Black Panther Queen
          All stats on http://www.alexjholt.tkwww.alexjholt.tk
            Team Zlayerz
            1. Wedginator 6.0
            2. Super Gore Evo
            3. Seung Mina III
            4. Tira III
            5. Killobite 5.0
            6. Intrigue
            7. Macduff the 2nd
            8. Aftershock
            Team Doomforall
            1. Dante
            2. Baldur
            3. Darkestar
            4. Slaying Mantis
            5. Scaramanga 2
            6. Salamander III
            7. Archangel of the Abyss
            8. Black Panther Queen
            Team Varying Every Day
            1. Axe to Fall
            2. Flick of the Wrist
            3. Sheer Heart Attack 2
            4. Back to Rock III
            5. Liar 2
            6. With or Without you
            7. Another Night at the Bar
            8. Storm 2
            Team Insanity
            1. DVD
            2. MeCannibal
            3. ARRTDS
            4. Nitro-Gene
            5. WORCK
            6. Tri-Tanium
            7. Autoism
            8. Knocking Out
            Still waiting...
              Count me in...
              TEAM CHEVRON
              Gabriel
              WEIGHT: 100kgs
              DIMENSIONS: 100 x 75 x 50 cm
              SHAPE: Elongated triangular pyramid with steep rear and very shallow front
              COLOUR: Black with yellow and black chevron highlights on the joins and around the weapons.
              DRIVE: 2 S28-400 Magmotors driving 2 wheels running off 4 NiCd packs at 24v
              SPEED: 14mph average, 20mph max
              GROUND CLEARANCE: 0 at front due to spring hinged nose, rising to 7mm at rear
              ARMOUR: 3mm aluminium baseplate, 7mm titanium armour on rest of body (7mm hardox in critical areas and edges).
              WEAPONS: A high pressure pneumatic front hinged flipper, consisting of the front edge of the body, running from 2 2.5kg CO2 tanks and a hydraulic ram giving 35 flips in a match and capable of flipping 100kgs and lifting several times more than that. Also has hardened steel spikes located on either side of the front point, and it can spin in place to try and do damage with these.
              SRIMECH: Via the weapon, which should have enough force to pull it over if it becomes stranded on its back.
              NOTES: Components shock mounted for protection vs. spinners and impacts
              STRENGTHS: Difficult to get a grip on due to the shape
              WEAKNESSES: So-so armour
              Fire And Ice
              WEIGHT: 110kgs
              DIMENSIONS: 80 x 60 x 25 cm
              SHAPE: Invertible box, with a wedge at the front and an inverted wedge at the back.
              COLOUR: Flame red and yellow at front, icy blue and green at back.
              DRIVE: 4 LEM130 motors running off NiCd packs at 36hp (36v) driving steel-reinforced rubber tracks.
              SPEED: 16mph average, 25mph max (rarely used as it is difficult/impossible to turn at this speed)
              GROUND CLEARANCE: 10mm at sides, hinged plating extending below both wedges giving zero clearance on whichever side is down (if that makes sense...), 23cm at rear.
              ARMOUR: Sides ,front and rear are 6mm hardox, with the top and underside being 4mm titanium.
              WEAPONS: Mainly relies on speed and ramming power, but also has two 20cm diameter diamond edged sawblades, one in the centre of each wedge (a la Angel Of Death from S2) powered by S28-150 Magmotors at 24v to around 3500rpm. The saws spin upwards to have some lifting effect as well.
              SRIMECH: None, but runs inverted. Has spike strips on the sides to prevent stranding.
              NOTES: Armour and components shock mounted to reduce impact from all things large and spinny.
              STRENGTHS: Good speed and power, good against spinners
              WEAKNESSES: Tracks vulnerable to axes
              Nidhogg
              WEIGHT: 100kgs
              DIMENSIONS: 100 x 70 x 37 (47 inc weapon) cm
              SHAPE: Elongated triangular pyramid with steep rear and very shallow front, with a flat bit on the front edge and 2 cutouts in each side panel for eyes
              COLOUR: Dark green and brownish roughly chevron patterning, fading to blood red towards the front. Weapons are gold coloured with flame red spines on the arm.
              DRIVE: 2 Leeson M1120046 motors run at 24v from 4 NiCd packs driving 2 wheels, with a ball caster just behind the forks in the nose
              GROUND CLEARANCE: 0 at front due to forks, rising to 10mm at rear
              ARMOUR: 4mm Hardox (7mm in key areas) on front, side and rear panels, 3mm aluminium baseplate
              WEAPONS: Hydraulic crushing arm (constructed of hardened steel and aluminium alloy) at front driven from a Vivoil pump at 3000psi, giving 9 tonnes of force at the ram and 4.5 tonnes of force at the tip. Also has Haardvark-style lifting forks at the very front run from an S28-150 Magmotor and a lead screw capable of lifting 200kgs, generally used to hold opponents in place for the crusher to do damage.
              SRIMECH: Via the weapon, which has decorative spines to assist in self righting. Spikes at the rear prevent the robot getting stranded.
              NOTES: Components and armour shock mounted for protection against large scary spinny things. Eyes in side of robot serve as targeting lasers (they dont actually target, they just look really cool)
              STRENGTHS: Can cause a lot of damage
              WEAKNESSES: Slow at self righting
              147
              WEIGHT: 100kgs
              DIMENSIONS: 105 x 60 x 50 cm
              SHAPE: Wedge with flat back
              COLOUR: Green on the front (thanks to the felt) with brown wood-effect sides and rear
              DRIVE: 2 S28-150 Magmotors running from 4 NiCd packs at 24v driving 2 wheels
              SPEED: 15mph average, 20mph max
              GROUND CLEARANCE: 0 all around due to a hinged plate on the flipper and side and rear skirts, 10mm underneath
              ARMOUR: 4mm Hardox on front, sides and rear (front covered in 2mm green felt, sides and rear covered in 1mm wood-effect fibreglass), 3mm aluminium baseplate and under flipper to deter inquisitive pointy nasty spiky things.
              WEAPONS: High pressure pneumatic rear hinged flipper, consisting of the entire front plate of the robot, running from 2 rams and 2 2kg CO2 tanks, giving about 20 flips per fight. Also has a 50cm long steel pneumatic ram at the rear, running from 1 2kg CO2 tank at low pressure, painted to resemble a snooker cue (complete with chalking) which can punch through thin (2mm) titanium but is primarily there to right the robot if it becomes stranded.
              SRIMECH: Via weapons. Sides have fibreglass moulding and spikes to prevent stranding.
              NOTES: Has several snooker balls (1 cue ball, 4 reds, 1 yellow, 1 blue and 1 black if anyones interested) screwed to the top part of the flipper that not only look good but prevent opponents driving off/over the top. Internal components are shock mounted to reduce damage. Design theme came about as an attempt to differentiate my wedge flipper from everyone elses wedge flipper.
              STRENGTHS: Powerful flipper
              WEAKNESSES: Flammable (oh yes...), no real damaging weaponry
              Quaestor
              WEIGHT: 100kgs
              DIMENSIONS: 95 x 55 x 30 cm
              SHAPE: Box with wedge, only the wedge is in two sections making something of a shallow plow shape.
              COLOUR: Yellow and blue chevrons, with gold trim on the edges and silver weaponry. Has The Quaestor spelled out on the side in anodised aluminium letters.
              DRIVE: 4 S28-400 Magmotors driving 4 wheels running off 4 NiCd packs at 24v.
              SPEED: 15mph average, 25mph under 36v boost
              GROUND CLEARANCE: Wheels can be pneumatically raised/lowered (using a compressed air system seperate from the axe pneumatics) to give a minimum of 0 all around (this grounds it however) with a maximum of 50mm clearance, but normally has 5mm with 0 at the tip of the body.
              ARMOUR: 4mm hardox front, sides and rear with 3mm titanium and 4mm polycarbonate on the top and 3mm aluminium base.
              WEAPONS: Pneumatic axe on the front, running from a rack and pinion system and 2 2.5kg CO2 tanks giving about 40 hits in a match. The axe head is shaped similarly to Shunts but is tungsten tipped, weighs 5kg and can punch through 6mm titanium and dent hardox. Also has a big spike on the back.
              SRIMECH: Via the weapon, which should be powerful enough to pull it over if it gets stranded on its sides.
              NOTES: Base is coated with silicone rubber sheet to make it more difficult to push when in sit down mode. Internal components shock mounted for protection.
              STRENGTHS: Very difficult to push or flip, good weapon
              WEAKNESSES: Armour could be better, raising/lowering system takes a second or so to work
              Dreadnaut XP-1 (S4)
              The Darke Destroyer (S3)
              And for fun, if youll allow it...
              Radioactive
              WEIGHT: 28kgs
              DIMENSIONS: 55 x 55 x 7 cm
              SHAPE: Low invertible wedge, with wheels protruding through the rear of the robot as well as the top and bottom
              COLOUR: Yellow, with black radiation symbol on top, black chevrons on the sides, and a red biohazard symbol on the underside.
              DRIVE: 2 24v DeWalt drill motors and gearboxes driving 2 foam filled wheels running from 4 NiMh packs at 24v
              GROUND CLEARANCE: 0 at front, rising to 4mm at rear
              ARMOUR: 5mm titanium on top, rear and underside, 3mm titanium on sides, every available inside space packed with plywood to help it withstand fighting things a lot bigger than it is.
              WEAPONS: The wedge at the front, and two 5cm hardened steel spikes at the rear of the robot, the primary purpose of which is to hit walls and objects before the wheels do.
              SRIMECH: Invertible
              NOTES: Internal components shock mounted for protection against spinners
              STRENGTHS: Low enough to avoid some weapons, fast, well armoured
              WEAKNESSES: No active weaponry, SEVERE weight disadvantage
                OK, Ill give it a shot...
                ORKA MK4
                Weight: 100 kilos
                Body Shape: Behemoth
                Speed: Some 15mph
                TC: 0
                GC: 2mm, 0mm at front.
                Wheels; 6 inner
                Armour; 7mm titanium
                Power; 3x 12v batteries, powered by a couple of Magmotors
                Colour; Black with white patches
                Weapons; A Behemoth like bucket scoop, powered by pneumatics, made from titanium, and quite capable of lifting 300 kilos. It has a claw like device to grab an oppodent, like the claw on Mantis. The scoop is pnumatically powered, and has about 45 odd flips.
                Srimech: It has a pneumatic dorsal fin piston that self-rights the robot, ala Vlad The Impaler.
                Inspiration; Ive always liked Orcas. Adding the K made it sound more dangerous.
                Strengths; Weapon
                Weaknessess: Hard to turn
                DIE-CERATOPS RE-INVERTUS
                Weight; 100 kilos
                Body Shape: Wheely Big Cheese
                Speed; 15mph
                TC; 0
                GC; 0mm at front, 3mm at sides and back.
                Wheels; 2 inner, sticking out only slightly,
                Armour; 8mm titanium
                Colour; Green, with Killer Carrot style wrinkles, mouth and eyes. One of the eyes has a plaster over it, the other is a black eye. A few bandages are painted on this time.
                Weapons: A huge Wheely Big Cheese style flipper, capable of flipping a tonne or so.
                Srimech; As the name suggests, the robot runs inverted. Bars prevent side strandings, and the back is rounded, so stranding THAT way is outta the question. The flipper works upside down.
                Inspiration; Ive always liked Dinosaurs. This is a pun of Triceratops. The Invertus part is pretty obvious.
                Strengths; The ability to work upside down and still be able to use its weapon, now easier to control.
                Weaknessess: Facing more agile vapourbots
                LEPROSY INFECTION
                Weight; 100 kilos
                Body Shape; Tetanus Booster
                Speed; 18mph
                TC; 0
                GC; 2mm
                Wheels; 4 inner, top sticking out. Wheel flaps are situated either side of the wheel to protect them.
                Colour; A disgusting shade of lime green.
                Weapons; A very large, very dangerous vertical drum, capable of reaching speeds of 4000rpm. The teeth on the drum are curved upwards so they can flip as well as damage and very sharp at the tip. There is a reason for this...
                Srimech; The robot is invertable. Bars along the side and back prevent stranding. The wheel flaps, both on top and bottom, are set so the robot can still run inverted without getting stranded. Once upside down, the teeth of the drum gouge out robot parts.
                Inspiration; Named after the disease which causes the skin to flake and fingers and toes to drop off...namely because the robot does something similar. The basic idea came from an episode of The Simpsons.
                Strengths; Drum, control is pretty good
                Weaknessess; Wheels may be vulnerable to axes
                MEGA MASHER 2
                Weight: 100 kilos
                Body Shape: Minion with skirts.
                Speed: 12mph
                TC: 0
                GC; 0 at front, 1mm at sides due to skirts, 5mm underneath.
                Wheels; 4 inner.
                Armour: A nice 3mm of steel, over which is 5mm titanium. Its a double-layer machine.
                Power: Similar stuff to what Tornado uses.
                Colour: Red and yellow.
                Weapons; The front is a wedge, and the back has a nasty vertical disc, powered by its own LEM130 motor and spinning at 2000 rpm. It can probably flip as well as damage. A side Minion style bar comes out from the side.
                Srimech: The aforementioned bar rights the robot, even though it can run inverted.
                Inspiration; This is probably the only robot I have where I have had no inspiration. It just came as a good name.
                Strengths: Power, weaponary
                Weaknessess: A little bulky, not as heavy as the body would suggest.
                Y4
                Weight: 99 kilos
                Body Shape: T-Minus
                Speed: 16mph
                TC: 0
                GC: 2mm, but the flipper blade reaches 0.
                Wheels: 2 semi outer (that means theyre protected)
                Armour: 5mm titanium
                Power: The usual 3x 12v batteries and couple Magmotors (S28-400s) for power.
                Colour: Grey
                Weapons: An extremely powerful pneumatic CO2 flipper (Try 300 kilos+). Can perform about 30 or so flips before it starts weakening.
                Srimech: The flipper acts as srimech. It can also be used as gymnastics. A light flip will knock the robot back over, but pressing hard on the button will send the robot into a 540 degree spin before landing, or a Matador style bound in mid air. All prperly controlled, of course.
                Inspiration: A quote from a cartoon. Taz-mania, I believe.
                Strengths: Powerful flipper, very entertaining.
                Weaknessess: Semi exposed wheels.
                AXE-O-LOTL
                Weight: 100 kilos
                Body Shape: Comengetorix
                Speed: 20mph
                TC: 0
                GC: 2mm
                Wheels: 4 inner
                Armour: 3mm steel all around.
                Power: Same stuff as Storm 2 and Cyclone Force uses.
                Colour: Has interchangable panels. One set is pure black, the other pure white with pink tinges.
                Weapons: A very nasty axe, with the power of Dominator 2. The head is diamond tipped, and the whole weapon is VERY persistant. It can fire about 40 times in one fight.
                Srimech: The axe rights the robot. The robots body is designed so it cant be side stranded.
                Inspiration: My favourite amphibian, the axolotl.
                Strengths: Powerful weaponary
                Weaknessess: Obviously a limited CO2 supply.
                OBLITERATION
                Weight: 100 kilos
                Body Shape: Revolutionist
                Speed: 10mph
                TC: 0
                GC: 5mm all the way round. It has to be.
                Wheels: 8 inner (4 on top, 4 below)
                Armour: 7mm titanium
                Power: It drives on 3x 12v batteries plus a couple of Magmotors. For the weaponary, the power matches Phrizbee.
                Colour: Dark blue with tinges of black and brown.
                Weapons: This robot is a ring spinner. The teeth are increibally sharp. It spins at about 1000 rpm, and does damage similar to Phrizbee.
                Srimech: This robot runs inverted.
                Inspiration: It sounded cool. It also sounds like a ride at an amusment park, if you ask me.
                Strengths: Body! Need I say more?
                Weaknessess: Unknown Quality.
                SPRING-BOK!
                Weight: 100 kilos
                Body Shape: Firestorm.
                Speed: 12mph
                TC: 0.
                GC: 0 at front, 3mm at sides.
                Wheels: 2 inner.
                Armour: 8mm titanium, covered in 2mm orange fur.
                Power: 3x 12v batteries, powered by a couple of Magmotors.
                Colour: Orange, thanks to the fur.
                Weapons: A launch pad. Heres how it works...basically, the robots drive up the wedge, then the front panel, which is attached to four large car springs, fires outwards. A miniture piston device is attached to the panel to prevent it getting fired off, and also re-sets it. Should that fail, it does have a back-up plan (see notes).
                Srimech: Two arms that extend around the side of the body, a bit like that of Philliper, only bottom hinged rather than top hinged, act as the Srimech.
                Inspiration: Its named after an antelope.
                Notes: This is the re-make of the former comedy yet highly sucessful robot Fluffitor, who won a previous Children In Need special. Has an in-built police siren which it activates if the going gets tough. The idea is that the oppodent will think hes about to be arrested then run off.
                Strengths: Experience, unique weapon.
                Weaknesses: Untested, Flammable, back-up plan probably wont work.
                  Team Zlayerz
                  1. Wedginator 6.0
                  2. Super Gore Evo
                  3. Seung Mina III
                  4. Tira III
                  5. Killobite 5.0
                  6. Intrigue
                  7. Macduff the 2nd
                  8. Aftershock
                  Team Doomforall
                  1. Dante
                  2. Baldur
                  3. Darkestar
                  4. Slaying Mantis
                  5. Scaramanga 2
                  6. Salamander III
                  1. Axe to Fall
                  4. Back to Rock III
                  5. Liar 2
                  8. Storm 2
                  Team Insanity
                  1. DVD
                  2. MeCannibal
                  3. ARRTDS
                  4. Nitro-Gene
                  5. WORCK
                  6. Tri-Tanium
                  7. Autoism
                  8. Knocking Out
                  Team Chevron
                  1. 147
                  2. Radioactive
                  3. Dreadnaut XP-1
                  4. The Darke Destroyer
                  5. Nidhogg
                  6. Fire & Ice
                  7. Gabriel
                  8. Quaseator
                  Team Dinowarrior
                  1. Leprosy Infection
                  2. Axe-O-Lotl
                  3. Y4
                  4. Obliteration
                  5. Mega Masher
                  6. Orka Mk 4
                  7. Die-Ceratops Re-Invertus
                    Ill give this one a go...
                    Team ???
                    1) SOR Hex
                    2) Wedgas Revenge
                    3) Exertion
                    4) Rupture
                    5) Psyclonised
                    6) GeForce 4.0
                    7) Axeon 2.0
                    Yet Another Cut Above The Rest
                    http://teamcode14.proboards24.com/index.cgi?board=Stats
                      Count me in
                      The 6isc
                      Shape: Too complicated, apparently. See picture in the vapourbot images thread.
                      Size: 60X110X60 CM (LWH)
                      Weight: ~100 KGs
                      Speed: 10 MPH.
                      Ground clearance: Under the wheel protectors, it€™s 5 mm.
                      Weapon: 26 KG spinning disc, powered by one LEM 130 Lynch motor and going at 2500 RPM. The disc is shaped with its own teeth rather than needing teeth surgically attached to it, so dentistry is quite impossible. The energy output is 36 KJ€™s which, while modest by vapour €˜bot standards should still be enough to make a mess of things.
                      Wheels: 6 wheels, but four wheel drive. This has three wheels on either side arranged in a triangular fashion, so it only runs on four at a time. The wheels are 1 CM solid Ti with soft compound rubber wrapped around them to provide shock resistance, and a layer of Vulcalon wrapped around that to provide traction.
                      Chassis: The main chassis consists of one solitary 1 CM thick 4 mm box section hardox bar. Slotted over that is a secondary axle, inside which are the batteries. There are also two other triangular chassis€™ supporting the wheels. These are made from 4 MM 1 CM box section Ti bars with weight reducing holes.
                      Armour: The true axle and chassis is a 4 MM hardox bar. The battery axle is 2 mm aluminium. The semi circular wheel protectors and side spikes are 5 mm Hardox. The disc itself is 14 MM of Hardox 500, and the outer axle is 4 mm grade 5 Ti.
                      Srimech: Totally invertible. Controls won€™t even have to be reversed after flipping, meaning it can just go straight back on the attack.
                      Drive: 2 S28-400 Magmotors at 24 volts.
                      Strengths: The newest version of The 6isc does away with as many weaknesses in The Disc 5 as I could find.
                      Weaknesses: Weak armour in places. Can€™t use axe attacks.
                      Tempest Evil-est-oution
                      Shape: Ring spinner.
                      Speed: 12 MPH.
                      Dimensions(dh): 80CM X 25 CM
                      Armour: The spinning ring is 1.8 CMs of Ti. The base and top are 1.5 CMs of polycarb, giving a total armour weight of around 63 KGs.
                      GC: 1 CM.
                      Weapon: Ring spinner powered by two Lem 130s and spinning at 1000 RPM to deliver 83 KJs per hit. The four hardox teeth are 10 CMs long with two being placed near the top and two near the bottom.
                      Drive: 2 wheeled, driven by S28-400 magmotors.
                      Srimech: Invertible.
                      Notes: Has an absolute buttload of shock proofing inside. Everything is firmly bolted down, with layers of rubber between everything. Added to that, the teeth have a backwards curving shape which maximises the distance it will throw itself away from the opponent. The reason is twofold. First is to make ramming and flipping it difficult, but the main reason is to bleed away kinetic energy backlash, by using that backlash to move the robot externally rather than internally.
                      Strengths: Hits hard and is hard to hit. Not much is getting through the armour.
                      Weaknesses: Should the spinner fail, it€™s pretty much screwed.
                      Dead Horse beater
                      Shape: A box with a wedge at the front.
                      Speed: 12 MPH.
                      Dimensions(lwh): 80CM X 50 CM X 25 CM
                      Armour: 5 MM hardox for the top sides, rear. 4 mm Polypropylene for the base.
                      GC: 1 mm at the front 6 mm elsewhere.
                      Weapon: An axe, shaped like a baseball bat with a nail in it. The shaft is made from 5 MM Ti, the nail is hardox. This is pneumatic, powered by two rams at 750 psi.
                      Drive: 2 wheels, powered by two S28-400 magmotors at 24 volts.
                      Srimech: The axe. The sides are rounded so it won€™t rest on them.
                      Strengths: Good armour, axe should be powerful and have a fair amount of hits. Can still push if axe fails. Has a picture of a dead horse on the top.
                      Weaknesses: Base armour isn€™t too good, axes are hard to aim.
                      Door Stops
                      Shape: A two part cluster bot, each part is an invertible wedge. Kinda like a door stop. The backs are rounded to prevent being beached.
                      Speed: 15 MPH.
                      Dimensions(lwh): 40CM X 30 CM X 20 CM
                      Armour: 4 MM hardox for the front 20 CMs, 5 mm grade 5 Ti for the rear 20 CMs
                      GC: 0 at the front tip, raising to 1.5 CM at the rear.
                      Weapon: Static wedges at the front.
                      Drive: 2 large internal wheels towards the end of the robot, powered by LEM 130€™s at 36 volts, which if memory serves should provide 18 HP.
                      Linking method: One part has a clip on the rear, the other has an €œeye€ The two pieces can fight as one when clipped together, and with some good driving, the two can reunite in the middle of battle. Admittedly this would take awesome skills, but admittedly I am awesome.
                      Strengths: Good front armour, designed for taking on spinners, it€™s a cluster €˜bot.
                      Weaknesses: Not so wonderful back armour, could wheelie due to high acceleration, it€™s a cluster €˜bot.
                      Sakura
                      Shape: Shaped like a closed cherry blossom, sort of conical.
                      Speed: 12 MPH
                      Dimensions(dh): 90X30 - diameter taken from the widest part of the machine, it gets narrower as it goes up.
                      Colour: Let€™s just say it€™s a shade Bex would approve of
                      GC: 1 CM
                      Turning circle: 0
                      Weapon: Team Bored€™s first true FBS clocks in with a 50 KG FBS shell, spinning at 1500 RPM and powered by two LEM 130s on 36 volts, which should give a nice fast spin up time. There are four hardox teeth, painted and shaped to look like leaves. These are razor sharp to give a nice slice, and they€™re also barbed to catch and rip opponents. I can only estimate the power output due to the shape not being supported by the energy calculator. This clocks in between 90-100 KJs.
                      Weapon 2: Humiliation. Who wants to admit they just got beat up by a flower?
                      Armour: 8 mm hardox for the spinning shell, 5 mm Polypropylene for the base.
                      Drive: 4 wheel drive, powered by two S28-400 Magmotors on 24 volts.
                      Srimech: There€™s a hole at the very top of the cone, out of which a blunt self righting spike can come up. This is powered by low pressure pneumatics. Due to weight constraints, it can probably only self right about ten times.
                      Features: Near the top of the cone are holes. These aren€™t just for reducing weight, as each hole leads to a small aluminium box which is full of pink confetti. As the shell spins, this should be strewn out, allowing Sakura to fight in a cloud of cherry blossoms.
                      ISDSFA
                      Shape: Similar to Behemoth.
                      Speed: 15 MPH.
                      Dimensions(lwh): 70CM X 60 CM X 40 CM
                      Armour: 3.5 mm hardox, reinforced to 5 mm around the wheels. Scoop is made of 5 mm hardox.
                      GC: 0 mm at front, 1 CM everywhere else covered with 3 mm ti side skirts.
                      Weapon 1: Electric scoop, powered by linear actuators. Should be able to lift around 250 KGs.
                      Weapon 2: Small flywheel, giving around 8 KJs per hit. This is hidden behind the scoop. Once a robot is raised, this is extended to strike the base of the victim, with the aim of attacking wheels.
                      Drive: 4 wheels, driven by Lem 130s.
                      Srimech: The scoop, and Behemoth style side arms.
                      Strengths: Good pushing power and able to attack a robots drive directly.
                      Weaknesses: Spinner pretty much useless against armour.
                      The May Tracks Has You
                      Shape: Like Comengetorix. It has a wedge extender to give it 0 mm at the front.
                      Speed: 20 MPH.
                      Dimensions(lwh A): 85CM X 45 CM X 24 CM
                      Armour: 4.5 MM hardox.
                      GC: 0 mm at the front, 6 mm everywhere else, covered by skirts made of 3 mm Ti.
                      Weapon 1: Rear hinged flipper, powered by two pneumatic rams at 500 psi.
                      Weapon 2: Upward facing spikes on the wedge. A robot can go over them, but if it tries to reverse, say goodbye to your tyres. By wedging a robot then reversing suddenly, TMTHY can impale the tyres, then fire the flipper to do loads of damage. Even a robot with stuffed tyres will be limping after that.
                      Drive: Inner tracks, powered by Lem-130€™s at 24 volts.
                      Srimech: The flipper.
                      Strengths: Weapon synergy. Once The May Tracks Has You, there is no escape.
                      Weaknesses: Axe/flipper combos could take the tracks out.
                      Ill also enter Big Nipper
                        Team BriteSpark
                        1) Supreme Glory Gamma
                        2) Squishiest
                        3) Manic Monsoon
                        4) Dervish V
                        5) Sonic Boom
                        6) Pure Evil: Revenge of the Disc
                        7) Wheely Pure Evil 2
                        Dennis the Menace
                        Name: Supreme Glory Gamma
                        Weight: 100kg
                        Armour: 20mm Lexan and LexiGuard compound
                        Speed: 8mph
                        Shape: Pyramid shaped
                        Weapon 1: An 11kg Aluminium alloy axe powered by a 60v Etek, capable of generating 3Kj of force per hit.
                        Strengths: Strong armour and very manoeuvrable.
                        Weaknesses: Axe only works if something is in front or behind the robot.
                        Ground Clearance: 0mm all around due to skirts.
                        Srimech: The axe self rights the robot.
                        Notes: The robot is powered by 2 x 800watt 36v DC motors giving 8mph top speed. The 2 wheels are made from Ti/V alloy and coated in Vulcalore to aid in traction. The robot is covered in 20mm Lexan and LexiGuard compound. The axe weighs a total of 11kg and is shaped like Excaliburs axe from series 3 of Robot Wars. This shape is designed to focus all the force on a single point, meaning it can pierce through armour easily. The axe can give 3Kj of force per hit, roughly the same as Beta. The tips of the axe are covered in a thin layer of carbon, so if it fights a robot with Titanium armour, it can get through the armour even easier. To stop the robot from hopping about when the axe is fired, the robot incorporates a vacuum system. This can be switched on and off during a battle to allow for manoeuvrability and superior traction when static. The skirts on SGG are made from Grade 5 Titanium and are held in place by hinges.
                        Weight: 100kg
                        Armour: 4mm Grade 5 Titanium
                        Speed: 20mph
                        Shape: Low wedge
                        Weapon 1: A very powerful hydraulic crusher, with 14 tonnes of pressure at the tip.
                        Strengths: Very powerful crusher and strong armour. Good pushing power and good speed.
                        Weaknesses: Slow srimech.
                        Ground Clearance: 0mm at front due to wrinkler device. 5mm at sides and 1cm at back.
                        Srimech: It uses a set of Razer style wings.
                        Notes: The robot is powered by 2 LEM130 Lynch motors running at 36v, giving 20mph top speed and pushing power equivalent to 18HP. The robot has 6 inner Vulcalore wheels, which give tremendous traction. The crusher itself is made from 4mm Hardox, with 300 weight reducing holes. It is powered by an M-Mac M40 Hydraulic Actuator running at 12v, which can give 14 tonnes of pressure. The actuator has already been used in Robotic Combat, so this robot is realistic. The tip of the crusher is coated in carbon, so it can rip through Titanium easily. For the weapon to function properly, the robot contains 12 x 9.6-volt NiMh Radio Controlled Car Batteries, each weighing 12oz.
                        Weight: 100kg
                        Armour: 5mm Hardox all over.
                        Speed: Roughly 28mph
                        Shape: Box wedge with side skirts and rounded back.
                        Weapon 1: A linear actuator powered lifter running by a 4 bar system at 24v. This can lift 200kg easily.
                        Weapon 2: A small strip of Grade 5 Titanium on the front wedge, which gives 0mm ground clearance.
                        Strengths: Powerful drive and good strong weapon
                        Weaknesses: A bit too fast and hard to control when at full speed.
                        Ground Clearance: 0mm on front and sides, 1cm at back.
                        Srimech: Invertible, but can self right using the lifter if wanted to.
                        Notes: The robot is powered by 2 B42-500 MagMotors running at 60v. This gives Monsoon approx 60HP! The robot has a total of 6 wheels, 3 on each side. Each side is linked together by a set of heavy duty belts, giving 0m turning circle and the manoeuvrability of a 2 wheeled bot, and each wheel is coated in Vulcalon. The front wedge is angled at 42.5 degrees, meaning that it is not too steep or too shallow. The lifting arm is powered by a S28-150 MagMotor, and is made from 7075 Aluminium. The lifter itself can lift a total of 200kg, and can self right the robot if needs be. The side skirts are made from 4mm Titanium and are hinged.
                        Weight: 100kg
                        Armour: 10mm Aluminium Boron Carbite, with 5mm Lexiguard inside that to protect electronics.
                        Speed: 14mph
                        Shape: Invertible cylinder, like Barberous
                        Weapon 1: Spinning body which spins upwards, so it can flip its opponents.
                        Strengths: Powerful weaponry and very manoeuvrable
                        Weaknesses: Exposed wheels.
                        Ground Clearance: 7mm all around
                        Srimech: Invertible
                        Notes: The robot is powered by 2 C40-500 MagMotors with 4 36v packs and geared down 20:1, giving the robot a top speed of 14mph. Both wheels are based around Stinger, but have Vulcalore trims to aid in traction. The spinning body is made from 10mm Aluminium Boron Carbite, with 5mm Lexiguard inside that. The spinning body has Carbon tipped blades and Grade 5 Titanium blades attached all over it, so it can destroy all matters of armour. The body itself is powered by 2 LEM 130s running at 36v via 4 packs. This means the drum spins at approx 2500RPM. This should be enough power to destroy a robot in a matter of seconds.
                        Weight: 100kg
                        Armour: 1cm thick Hardox wheel hubs, 5mm Hardox axe head and 5mm thick axe pole. The axle joining the 2 wheels is made from 6mm Titanium and Vanadium alloy.
                        Speed: 28mph.
                        Shape: The robot is an axlebot based around Stinger.
                        Weapon 1: A momentum powered axe, which can come down with 800kgs of force.
                        Strengths: Hard to grab hold off and very tough armour. Great manoeuvrability.
                        Weaknesses: Poor pushing power.
                        Ground Clearance: 10mm.
                        Srimech: The robot is invertible.
                        Notes: The robot is powered by 2 LEM 130s, giving 28mph top speeds. The wheels are made from aircraft grade Aluminium, with Hardox wheel hubs and thick rubber treads. All the electronics, batteries and wiring are hidden inside the wheels. The 1cm thick wheel hubs should mean that nothing can damage the innards of Sonic Boom. To save weight on the robot, the wheels are only 20cm high, but are also 20cm wide, increasing traction on the arena floor. The axe head is modelled on Stingers axe from series 4 of Robot Wars, but is a lot tougher due to the 50cm, 5mm Hardox axe pole and 5mm Hardox axe head. The axe is momentum powered, meaning that when the robot stops moving from a charge, the axe swings over head and hits what ever is in front of it. This method of weaponry is not accurate most of the time, but when it does hit, it can cause a lot of damage. The 10mm ground clearance all over the robot should stop it getting stuck on arena obstacles.
                        Name: Pure Evil: Revenge of the Disc
                        Weight: 100kg
                        Armour: 7mm Hardox ring spinner and 4mm Titanium flipper/wedge.
                        Speed: 8mph
                        Shape: It is a ring spinner with a front wedge.
                        Weapon 1: The main body is a ring spinner made from 7mm Hardox, with Titanium teeth all over it. It is powered by a LEM130 motor at 48v geared down 3:1. This means the body can reach a top speed of 2400RPM. The disc weighs a total of 38kg.
                        Weapon 2: A spinning kinetic powered flipper, based on Team Whyachi€™s €œWarrior SKF€. It uses the kinetic energy from the disc to power the flipper, meaning it can flip with a total of 298KJ of energy.
                        Strengths: Unique and powerful weaponry. Good control.
                        Weaknesses: Takes a long time to self right due to the disc needing to spin up successfully.
                        Ground Clearance: 0mm at front and sides of flipper, 5mm at back due to ring spinner.
                        Srimech: The flipper can successfully self right the robot.
                        Notes: The robot is powered by 2 800w 36v DC motors giving 8mph top speeds. The wheels are made from Vulcalon, and have screws embedded in them to help gain traction on the arena floor. The ring spinner is powered by a LEM130 motor at 48v geared down 3:1. This means the body can reach a top speed of 2400RPM. There are 15 1€ cubed Titanium teeth all over the horizontal spinner, giving it 298KJ of energy on impact. The flipper works because there is an eccentric land on top of the spinning ring. The top link connected to the flipper plate has a groove in it, when fired the top link engages with the spinner land and pulls backward flipping the plate up. At the front of the flipper there is a 4mm Titanium €œnose€ with a sharpened edge designed to get under all skirts and ground clearances. All the electrics are kept within the 1m diameter of the ring spinner.
                        Name: Wheely Pure Evil 2 (Thanks to Aaron for flipper rams and armour)
                        Weight: 100kg
                        Armour: 6mm Aluminium Boron Carbite (slightly heavier than Aluminium, but harder than Tungsten)
                        Speed: 18mph
                        Shape: Low invertible wedge
                        Weapon 1: Top hinged flipper powered by a 80mm pneumatic ram, working at 1000psi fixed on top of the robot. At the bottom of the flipper there is a 5mm Grade 5 Titanium wedge extender, designed to get under any ground clearance.
                        Weapon 2: Top hinged flipper powered by a 80mm pneumatic ram, working at 1000psi fixed on the underside of the robot.
                        Strengths: Powerful weaponry and tough amrour.
                        Weaknesses: Exposed wheels on top and limited CO2 on board.
                        Ground Clearance: 1cm at the back, 0mm on sides due to side skirts and 0mm at front due to flipping plate.
                        Notes: The robot is powered by 2 S28-400 MagMotors running at 24v, which give 18mph top speed. The flippers are made from 4mm Aluminium Boron Carbite, and powered by 80mm pneumatic rams working at 1000psi due to Nitrogen. Each flipper can flip roughly 2500kg each. However, due to the flipper set up, the robot can flip roughly 5000kg! The robot has hinged side skirts, to stop robot getting underneath. The skirts are made from 3mm Aluminium Boron Carbite, and are hinged so they run upside down. The flippers can be fired at the same time, or independantly. This robot works on the same basis as St Agro: a double flipper.
                        Robot Name: Dennis The Menace
                        Length/Width/Height: 100 x 40 x 25 - 35cm (The height of the robot increases as you move from the front to the back).
                        Weight: 100KG
                        Motivation: 2 foam filled go kart wheels made of uber-tough rubber.
                        Speed: About 18mph
                        Weapon: The main weapon is a 20kg spinning drum, powered by 2 Huqsvarna 3120XP chainsaw motors. The weapon is capable of changing gears during a match. Originally, the drum spins at 2400RPM when geared down 10:1, but this can be increased to 2:1 at systematic intervals of 2 gearings (10:1, 8:1, 6:1, 4:1 2:1). The 4mm Titanium drum is fitted with 2 horizontal Hardox bars, welded, screwed and riveted on to avoid them coming off. These are designed not only to flip, but to rip off skirts and armouring. The drum can hit with over 10kJ of force when spinning at 2400RPM, and increases to an astonishing 243kJ when spinning at 2:1 gearing (12000RPM).
                        Drive: 24v Sinclair C5 motors.
                        Power: 4 x 24v NiCad batteries.
                        Armour: 5mm Titanium and Vanadium alloy.
                        Ground Clearance: 4mm all around.
                        Turning Circle: 0M
                        Notes: The robot is invertible, and is completely symmetrical when flipped, meaning the performance isn€™t altered at all. The robot€™s shape is basically a box, but with the height increasing as you move from front to the back. The robot has 2 thick Hardox spikes on each side, which means it can pass the passive weaponry rule, and these also stop the robot resting on its side. To stop it resting on its back, the rear of the robot is slightly curved.
                          Good to see Supreme Glory Gamma back in it. I liked that bot.
                            I wish other people liked it! LOL!
                              We all love it!
