My first REAL tournament... ROBOBASH!!!!
    Ill reserve judgement until its thrashed me
      Team Zlayerz
      1. Wedginator 6.0
      2. Super Gore Evo
      3. Seung Mina III
      4. Tira III
      5. Killobite 5.0
      6. Intrigue
      7. Macduff the 2nd
      8. Aftershock
      Team Doomforall
      1. Dante
      2. Baldur
      3. Darkestar
      4. Slaying Mantis
      5. Scaramanga 2
      6. Salamander III
      7. Archangel of the Abyss
      8. Black Panther Queen
      Team Varying Every Day
      1. Axe to Fall
      2. Flick of the Wrist
      3. Sheer Heart Attack 2
      4. Back to Rock III
      5. Liar 2
      6. With or Without you
      7. Another Night at the Bar
      8. Storm 2
      Team Insanity
      1. DVD
      2. MeCannibal
      3. ARRTDS
      4. Nitro-Gene
      5. WORCK
      6. Tri-Tanium
      7. Autoism
      8. Knocking Out
      Team Chevron
      1. 147
      2. Radioactive
      3. Dreadnaut XP-1
      4. The Darke Destroyer
      5. Nidhogg
      6. Fire & Ice
      7. Gabriel
      8. Quaseator
      Team Dinowarrior
      1. Leprosy Infection
      2. Axe-O-Lotl
      3. Y4
      4. Obliteration
      5. Mega Masher
      6. Orka Mk 4
      7. Die-Ceratops Re-Invertus
      Team Unknown
      1. SOR Hex
      2. Wedgas Revenge
      3. Exertion
      4. Rupture
      5. Psyclonised
      6. GeForce 4.0
      7. Axeon 2.0
      8. Yet Another Cut Above The Rest
      Team BriteSpark
      1. Supreme Glory Gamma
      2. Squishiest
      3. Manic Monsoon
      4. Dervish V
      5. Sonic Boom
      6. Pure Evil: Revenge of the Disc
      7. Wheely Pure Evil 2
      8. Dennis the Menace
      Team Bored
      1. Tempest Evilestoution
      2. ISDSFA
      3. Sakura
      4. Big Nipper
      5. Doorstops
      6. Dead Horse Beater
      7. The May Tracks has You
      8. The 6isc
        Team Iron Diamond
        NAME- Death Threat 0.2
        SHAPE- Long box with rounded back,
        COLOUR- dull grey all over
        WEIGHT- about 100kg
        DIMENSIONS- L:95cm W:70 cm H:30cm
        SPEED- 13mph
        TURNING CIRCLE- 0m
        GROUND CLEARANCE- 0mm with hinged skirts, 10mm underneath
        ARMOUR- 5mm hardox
        MOVEMENT- Tracks with 2XBosch Motors with 3 Ni-cad battery packs at 24 Volts
        WEAPONS- Horizontal crushing claws at front made out of titanium with 6.25 tons of crushing power
        SRIMECH- Invertible. Side spikes to stop it resting on its side
        NAME: Axes of Evil
        SHAPE: Hexagon, sloping in to a point in the middle.
        COLOUR: dark green.
        WEIGHT: around 100kg
        DIMENSIONS: 60x60x50
        SPEED: 15mph
        TURNING CIRCLE: 0mm
        ARMOUR: 20mm polycarbonate
        GROUND CLEARANCE: 0mm all over with skirts, 15mm with.
        MOVEMENT: 2WD inside robot. powered by two Bosch motors running at 24 volts.
        WEAPONS: Rack and Pinion axe mechanism powered by two CO2 tanks at 160psi. It has two terrorhurtz style heads, one on either side of the shaft, because Axe of Evil doesnt work with the pun, and the name has to be accurate.
        SCRIMECH: the axe has spikes sticking out to aid self righting from any angle.
        NAME: Cat With Wheels
        SHAPE: Wedge with sloped sides.
        COLOUR: Like a Tabby Cats coat
        WEIGHT: Around 100Kg
        DIMENSIONS: L:100cm W:70cm H:50
        cm
        SPEED: 18mph.
        TURNING CIRCLE: Omm
        ARMOUR: 7mm Titanium
        GROUND CLEARANCE: 0mm at front, skirts at sides give 0mm, 15mm at back and underneath skirts.
        MOVEMENT: 2 wheels with Vulkanon tires and aluminium hubs powered by 2 S28-150 Magmotors at 24volts
        WEAPONS: Front hinged high pressure C02 flipper, powered by two rams, running at 500psi.
        SCRIMECH: flipper.
        SHAPE: Box with wedge at front and inverted wedge at back.
        COLOUR: Deep Red.
        WEIGHT: Around 100kg
        DIMENSIONS: L:110cm W:65cm H:23cm
        SPEED: 30mph
        TURNING CIRCLE:0mm
        ARMOUR: 5mm hardox
        GROUND CLEARANCE: 0mm at the front, 0mm with hinged skirts at sides, 20mm at sides under the skirts and at back. (Well, technically 23cm at the very back, thanks to the inverted wedge.
        MOVEMENT: 4 Wheels with Vulkanon tires and aluminium hubs powered by 4 36v LEM130s Powered by 6 NiCad battlepacks.
        WEAPONS: None but the force.
        SCRIMECH: Invertable.
        Shape: Cylinder
        Colour: Black with red teeth
        Weight: 100kgs
        Dimensions: L:90cm W:90cm, H:30cm
        Speed: 15mph
        Turning Circle: 0cm
        Armour: 8mm Titanium all around.
        Ground Clearance: 7mm
        Movement: 4 invertable wheels with Vulkanon treads, powered by a couple of LEM130s at 36V with 3NiCad battlepacks
        Weapons: Ring spinner powered by an etek running at 48volts, which can deal out around 80kjs of power. Two five kilo hardox teeth, curved to rip armour. The whole ring is about 20kg.
        Scrimech: Invertible.
        Name: Lethal Injection
        Shape: Stinger, but with static prongs between the wheels.
        Colour: Unpainted.
        Weight: 100kgs
        Dimensions: L:55cm W:60cm H:45cm
        Speed: 18mph
        Turning Circle: 0cm
        Armour: 9mm titanium on the wheels, 5mm Hardox for the prongs and disc.
        Ground Clearance: Ermm.. Being a stinger style axlebot, it doesnt really have one. The prongs are 0mm however.
        Movement: 2 stinger style wheels with Vulkanon rubber tyres, with 2 LEM130s and 4 NiCad battlepacks at 24volts.
        Weapons: Spinning disc positioned in between the prongs. The idea is that the opponent will be wedged on the prongs then caught by the disc. The disc is powered by a LEM130 at 2000rpm and deals about 60kj.
        Gemini
        Panic Attack
          If theres a space left, count me in! I might make a few mods to my squad.
            Can you replace Darke Destroyer with No Objections, please? Stats are in the improvement thread.
              Steve there is ONE more spot for you!
                Team Zlayerz
                1. Wedginator 6.0
                2. Super Gore Evo.
                3. Seung Mina III
                4. Tira III
                5. Killobite 5.0
                6. Intrigue
                7. Macduff the 2nd
                8. Aftershock
                Team Doomforall
                1. Dante
                2. Baldur
                3. Darkestar
                4. Slaying Mantis
                5. Scaramanga 2
                6. Salamander III
                1. Axe to Fall
                4. Back to Rock III
                5. Liar 2
                8. Storm 2
                Team Insanity
                1. DVD
                2. MeCannibal
                3. ARRTDS
                4. Nitro-Gene
                5. WORCK
                6. Tri-Tanium
                7. Autoism
                8. Knocking Out
                Team Chevron
                1. 147
                2. Radioactive
                3. Dreadnaut XP-1
                4. No Objections
                5. Nidhogg
                6. Fire & Ice
                7. Gabriel
                8. Quaseator
                Team Dinowarrior
                2. Axe-O-Lotl
                3. Y4
                4. Obliteration
                5. Mega Masher
                6. Orka Mk 4
                Team Unknown
                1. SOR Hex
                2. Wedgas Revenge
                3. Exertion
                4. Rupture
                5. Psyclonised
                6. GeForce 4.0
                7. Axeon 2.0
                Team BriteSpark
                2. Squishiest
                3. Manic Monsoon
                4. Dervish V
                5. Sonic Boom
                Team Bored
                2. ISDSFA
                3. Sakura
                4. Big Nipper
                5. Doorstops
                8. The 6isc
                Team Iron Diamond
                1. Death Threat
                2. Axes of Evil
                3. Cat with Wheels
                4. Sithis
                5. Crimson Thunder
                6. Lethal Injection
                7. Gemini
                8. Panic Attack
                Maybe I should erase all the realies, and make 2 more slots.
                • #23
                  Guys,I will start the tourney next week, so send me your entries AFAP! (as fast as possible)
                  • #24
                    The arena is similar to the robot wars arena, except the pit is in the middle. The pit release button is the same position as it was in Robot Wars. There are no house robots, instead, in two corners are 50kg sledgehammers that come down with a force of 1 ton! There are 8000RPM killsaws in the remaining two corners as well.
                    • #25
                      Are the killsaws the come-out-of-the-floor-and-throw-you variety or the arena-angle-grinder variety?
                      And heres the stats for No Objections, taking a couple of changes into account:
                      No Objections
                      WEIGHT: 100kgs
                      DIMENSIONS: 140 x 140 x 15 cm
                      SHAPE: A low dome type shape
                      COLOUR: Yellow, with a yellow and black striped lifter with red forks, and stylised black arrowheads on each side. The spinner rim is metal-coloured.
                      DRIVE: 2 S28-400 Magmotors driving 2 wheels, with a fairly narrow wheelbase to increase rotation speed, running at 24v from 4 NiCd packs.
                      SPEED: About 12mph average when driving normally, can get up to 40mph when spinning
                      GROUND CLEARANCE: 7mm all around, except at the front where the forks make it 0. 1mm in places because of the blades.
                      ARMOUR: 3mm titanium/vanadium alloy on top of 5mm UHMW on the top of the robot, supported by a 4mm Hardox frame underneath with holes drilled to reduce weight. 3mm aluminium baseplate.
                      WEAPONS: Complicated this...it has an electric lifting arm running off a 1 tonne linear actuator, pivoting from the rear of the robot with two front forks to get underneath opponents. The arm can lift 250kgs easily and extends fully (almost vertical) in about 1.5 seconds. Also, the robot has the capability to be a full body spinner (a spin-in-place one as opposed to a Ziggo or Gyrobot) with an outer 1.2cm Hardox ring with two blades/teeth, one on each side, made of hardened tool steel set close to the floor (1-2mm) and capable of delivering (energy)
                      SRIMECH: The lifter
                      NOTES: Internal components shockproofed to protect it from its own and other peoples spinner hits.
                      STRENGTHS: Versatile, can cause some damage, manoeuvrable
                      WEAKNESSES: Large area to attack, top armour not as strong as it could be, cannot translate while spinning
                      • #26
                        • #27
                          Steve, when are you going to post up your robots?
                          • #28
                            He will when he wants to. Remember, some people may be busy with other stuff. Just be patient.
                            • #29
                              Friends, This is how the battles are going to line up. Heats A to H
                              Heat A
                              Wedginator VS Dante VS Axe To Fall
                              DVD VS 147 VS Leprosy Infection
                              Heat B
                              Wedgas Revenge VS Supreme Glory Gamma VS Death Threat
                              (Steve Entry) VS (Another Entry) VS Aftershock
                              Heat C
                              Psyclonised VS Sithis VS Obliteration
                              The 6isc VS Another Night at the Bar VS ArchAngel of The Abyss
                              Heat D
                              Flick of The Wrist VS Y4 VS The May Tracks has You
                              Dreadnaut VS Axes of Evil VS Pure Evil: Revenge of the Disc
                              Heat E
                              Crimson Thunder VS Door Stops VS Gemini
                              ARRTDS VS Squishest VS Tira 3
                              Heat F
                              Seung Mina VS Nitrogene VS Dead Horse Beater
                              Storm 2 VS Big Nipper VS (Steve Entry)
                              Heat G
                              Die-Ceratops Re-Invertus VS Crimson Thunder VS Black Panther Queen
                              Fire & Ice VS Lethal Injection VS Dennis the Menace
                              Heat H
                              Gabriel VS Slaying Mantis VS Exertion
                              Panic Attack VS Manic Monsoon VS MeCannibal
                              Heats 9-16 coming soon...
                              • #30
                                So predictions, comments, tactics, and a cheeseburger from McDonalds, please.
