Grindhouse Extreme Tournament
  • #46
    Wait a minute. I check your stats and Abyssal Swordsmen is 350 KG. Hes too overweight for this one.
    • #47
      He starts out as a walker, and Alex modified ArchAngel of the Abyss for this tournament so it is 200kg. Combined with the other bots it is 400kg, and starting out as a walker it should be within the weight limit.
      (Message edited by kodster on March 06, 200
      • #48
        I see. Well Im actually going to accept that.
        • #49
          Double Post. My bad
          (Message edited by Bartmanhomer on March 06, 200
          • #50
            Andre, whats your rule on clusterbots, if 1 part is counted out, all the parts are counted out?
            • #51
              Yes. If one part of the clusterbots is counted, all the parts of the robots is eliminated.
              • #52
                I still waiting for the 3 robots.
                • #53
                  Be patient, Andre. They will come eventually.
                  • #54
                    Youre right about that, Kody.
                    • #55
                      Patient.....anytime is just great.
                      • #56
                        Id just get one more entry and make it a series 4 style heat, with two three way melees at the start.
                        • #57
                          Ill enter a clusterbot consisting of 2x Flick of the Wrist please
                          stats in Kody and my boards, you need a link?
                          • #58
                            If I were you, Andre, Id do the draw all over again.
                            And Id also like to change my entry, if you do.
                            • #59
                              Yes. I certainly may need a link for it.
                              • #60
                                Heres my clusterbot, two identical parts
                                2x
                                quote:
                                Name - Flick of the Wrist
                                Shape - 6-wheeled Tornado, including the angled rear to keep in contact with the ground while driving up a wedge
                                Weight - 100 Kilogram
                                Speed - 35 km/h (22mph)
                                Dimensions - 120x80x20 cm
                                Ground Clearance - 10 mm under the main body, variable clearance under the lifting spikes, with 0 mm as a minimum
                                Power - 2 B42-500 Magmotors at 48 volt
                                Movement - 6 wheels for awesome traction
                                Turning Circle - Zero
                                Weaponry - A pair of hardox, diamond tipped electric lifting spikes, a lot like the lifting spatula of American SHW Vladiator. These are 25 cm in length and can be lifted downwards which turns them into an active invertible lifting wedge. They can also be raised parallel to the floor, so they can act as a pair of classic ramming spikes. A 100 kg robot driving around at 22 mph is good for 5 kJ of kinetic energy. When this is brought onto a pair of diamond tipped spikes, this might seriously harm some armours.
                                Armour - 7 mm titanium all around
                                Srimech - It€™s invertible
                                Strenghts - High speed rambot, awesome traction
                                Weakness - Lack of devestating weapons
