Grindhouse Extreme Tournament
  • Grindhouse Extreme Tournament
    Hey everybody. Im Andre better as Bartmanhomer. Well this is my very first fan fiction tournament by the last couple of years. In this tournament you could only entering the robot that are beyond the weight advantage. Only 8 entrants can enter this tournament.
    Here are the rules:
    Wheeled robots are 100 KG to 200 KG
    Walkers robots are 200 KG to 400 KG
    If there any question about anything about this tournament, ask me.
    silly double posts
    (Message edited by MajinB on March 03, 200
      lol Homer, I remember you doing these on the old Panic Attack Boards...
      whats your policy towards reserving spots, and whats your policy towards clusterbots?
      *reserves a spot, still torn between either combining 2 of my heavyweights into 1 clusterbot or making a 400 kg walker*
        Well for clusterbots, hmmm.......clusterbots are allowed in this tournament. And for reserving spots, hmmm........I will allow to reserved for spots, however youll have to show the stats for the robot and see if your robots are qualified.
          the point of reservations is that one cant show stats at a certain time
            Really, well in this case the reservation is allow unless if I decided for a time limit. But I very paitent for reservation. So Ill allowed it.
              Mmmmm...... 400kg walker....
              200000N crushers?
              100000N flipper?
              200kg FBS?
              150kg Vert spinner?
              2000mm Bar spinner?
              I cant make up my mind what to exploit
                Haha! This should be heaps of fun, and I enjoyed your tournaments on the PAC Forums. Reserve a place for me please, and Ill get experimenting.
                  Eh, why not? Ill reserve a spot.
                    OK, Ill enter. Heres Tri-Tainium:
                    TRI-TAINIUM
                    € WEIGHT: 100kg
                    € ARMOUR: 4mm Hardox for the back/scoop. The top and bottom panels are 5mm Titanium and the sloped sides are 6mm Hardox to sheild the wheels.
                    € SHAPE: Low invertible box with a front scoop (the scoop has a slight dip in it to help get under other robots better) and sloped sides.
                    € MOTORS: 2 x LEM 130€™s at 36V = 18HP
                    € LOCOMOTION: 4 Vulkanised Wheels.
                    € DIMENSIONS: (L) 60CM (H) 20CM (W) 60CM
                    € COLOUR: Unpainted, with the exception of the name on top written in black paint.
                    € WEAPONRY: The weaponry consists of 3 x 9kg discs, made out of 1cm of Titanium with 3 Hardox bludgening teeth. The discs are set on the same axle, and amounted deep into the scoop, with the teeth just reaching towards the lip of the scoop, so the uppercut movement of the discs can attack base-panels and the like. The discs are powered by 2 x LEM130s at 36V. Set on a ratio of 5:1, it gives off 3500rpm. The discs, combined together make 27kg, so the force given out is 165kj per hit! Large amounts of Rubber amounted behind the scoop stops the risk of self-destruction.
                    € SPEED: 18mph
                    € GROUND CLEARANCE: 0MM-1CM. At the front, it is completely 0mm. On the sides/rear, its 1cm.
                    € STRENGTH: Weaponry.
                    € WEAKNESS: Completely new design.
                      Reserve spot:
                      1. Martijin M Benschop
                      2. Knightrous Oxide
                      3. AJ
                      4. Kody Kunz
                      5. Tri-Tainium
                      6. Joey
                      7. David
                      8.
                      One more spot left for this extreme tourney.
                      (Message edited by Bartmanhomer on March 04, 200
                        Reserve me a spot Andre
                          I already did. Wow this is going to be one butt-whooping tournament.
                            *Reserves spot*
                              Oh my god! I cant believe the entry will be that quick. One more to go.
