Use the Arena to your Advantage 1 - Bloody Low Walls
  • Use the Arena to your Advantage 1 - Bloody Low Walls
    Do CO2 bottles have to be cylindrical?
      Not necessarily, but most CO2 bottles Ive seen in robot combat are cylindrical.
      Fact remains though: 2 5kg CO2 bottles, whatever possible dimensions, just will not fit into Worcks own dimensions.
        ok, Im bad with pnuematics myself, anyone else has a say in the case Kunz vs Cuomo?
          I plan to avoid an argument, and so Im going to size down my bottles to 2 x 3kg CO2 bottles.
            Tactics: The only robot I didnt want to face...
            We are about the same speed, so for him to get the flipper under me he will have to outmanouver me. I have 2 wheels against Achilles 4, so manouverability is in my favour. I will aim to get behind Achilles and hit the back of it with the drum. The rubber/Ti mix of Achilles armour shouldnt be a problem for the drum. Even if there isnt much damage, the impact should flip Achilles over, allowing me to dominate in this fight.
            **Fingers Crossed**
              Since when does two wheels mean better manouverability? If anything, it is harder to drive something with two wheels because you are essentially making movements around your own axle as an axis and so you have less room for error. Anyway that aside just keep the pressure on, ram it to the sides and flip is the first order of the day, or just flip before I get to the sides... try to keep my new toughened front to the foe.
                Plan and Tactics for Sir Spinalot first battle: Beat the living scrap out of the robot. BLAZE OF GLORY!!!
                  START THE TOURNAMENT! START THE TOURNAMENT! START THE TOURNAMENT!
                    I think Andre wants the tournament started.
                      SHUT UP! DONT SHOUT! DONT DOUBLE POST! DONT DEMAND! GO AWAY! NOBODY LIKES YOU!!
                      (Message edited by Dinowarrior on March 17, 200
                        Andre, Chris, can you both calm down please? Itll be started when its started.
                          Im calm down already!
                            just start it.
                              Just show some patience + some damn respect.
                                Mark, Andre, you dont know the drill around here, easy, please...
                                geez...
