Vapourbot Images...
  • Vapourbot Images...
    The front and back views are the wrong way around :P and I somehow imagined it being quite a bit different (lower for example), but still good.
    (Message edited by joeychevron on May 17, 200
      I always try and make it to scale with the dimensions, and theyre as accurate as the ones you stated, so...yeah. lol
        By the way Kody - hows Knyfe coming along?
          Right...I meant those dimensions to the top of the weaponry, not the top of the machine, and the sloping of the sides is...*goes into MS paint*
            Sorry, Paul, I got backlogged with requests before you asked for that and I still have some to do (another one by Chezza for example), and also including a redesign of my benchmark vapour, Wedginator. When I get those done then I will start on Knyfe, okay?
            Wedginator Devilution, coming to a tournament near you...
              Oh, and Joey, the weaponry doesnt reach up to the top of the machine as far as I can tell. The disc is just a little bit off. :P
                  Kody, check your forum.
                    Heh, Ill redo it.
                    Hence...
                    Okay everybody, when requesting a 3D drawing of your vapourbot/robot, if you want it as accurate as possible, do what Shane Swan did and give more specific dimensions, such as the length of a flipper, or width or a rear panel, or something, so I dont mess up due to inadequate information. :P
                    Thanks to Joey in advance.
                      Yeah...sorry about that, I kind of messed up there :P
                        http://i276.photobucket.com/albums/k....pngWedginator
                          Im scared
                            Looks extremely cool, Kody...kind of like Facet from S3.
                              Thank ye, thank ye...stats for it shall be up soon, and then I will modify Isolations CAD...no, probably redo it since its so far gone. :P
                                *Sees Wedginator Devilution*
                                EEP
                                *Runs away*
                                I really want to know more about this Kody. Are the stats ready yet? Is the flipper all around like 6.0, or more traditional? It looks EVIL
