The Returners Tournament
MeCANNIBAL
€ WEIGHT: 110kg (Shuffler)
€ ARMOUR: 5MM Hardox
€ SHAPE: Invertible low cylinder
€ MOTORS: 2 x Eteks at 46V = 30HP
€ LOCOMOTION: 2 Shuffling pads
€ DIMENSIONS: (L) 80CM (W) 80CM (H) 15CM
€ COLOUR: Black with scary human face with over sized teeth coloured red.
€ WEAPONRY: Ring spinner, made of 15MM Harox, weighing 38KG, spinning at 3500RPM and producing 205KJ per blow. It has 6 bluntened teeth made of Hardox. The teeth are set in a triangular set-up. It also has 5 Inches worth of Titanium shock-proof Foam to stop it self-destructing.
€ SPEED: 22MPH
€ GROUND CLEARANCE: 0MM-8MM. It has a full-bodied skirt running completely along the ground that raises when the shell is spinning, but drops when the shell isn€™t spinning.
€ STRENGTH: Scary name and weapon
€ WEAKNESS: Hard to control
Here are the stats for MeCannibal - make your OWN views on it.
					MeCANNIBAL
€ SPEED: 22MPH
