How Could I Improve...
This topic is closed.
  • How Could I Improve...
    quote:
    To be fair, he has improved quite a bit
    If he has, its not the vapourbot creation area. :P
      At least hes not using fictional materials anymore...now, if we could encourage the use of designs that arent so obviously ripped off from other people, improve his understanding of weight limits and remind him to include motors to power his weaponry, together with somehow erasing everything he did before and making him less of a jerk, we could be on to something here.
        I think wed be onto something by BANNING him for life
          Or that, yes.
            Werewolf
            Shape: Low box
            Weight: 100kg
            Dimensions: 85 x 100 x 20
            Motivation: 6 x vulaklon tyres
            Power: 4 x LEM-130s at 36v, gives 36HP
            Armour: 4mm hardox all over, but 4mm hi-grade aluminium(7075) base, 5mm titanium skirts
            Weaponry: 5mm hardox Bio-Hazard style lifting arm with a 1mm titanium scoop that runs for the full width of the body, powered by an S28-400 magmotor at 24v, geared at 300:1. The scoop can be swapped for 2 hardox tungsten tipped forks
            Top Speed: 20mph
            Ground Clearance: 0 at front due to scoop, 0 at sides due to skirts, 6mm at rear and behind those
            Turning Circle: 0
            Srimech: The arm
            Colour: Platinum with name written vetically in red on arm
            Strengths: Fast, good pusher, interchangeable arm-ends
            Weaknesses: High GC at rear
            Ive redone Werewolf a bit to get it into 100kg
              I wish to know weather or not Cyrilium Jr. and Side Swipe have any problems.
              Well maybe if you went to the Moon, they might be within the weight limit with less gravity, but Cyrilium Jr would be lucky to come over 100kg
                Well, what about Side Swipe?
                Any suggestions for editing it?
                  Yes, go to the Moon. Or something.
                    What Joey said.
                    ffffff>And while youre at it, stay away from here.
                      I mean mechanically.
                      Not by going to the moon.
                        Well, it is possible to go to the moon mechanically. Have you never read Jules Verne?
                          I mean, are there any problems with Side Swipe mechanically? Such as motor problems? Batteries? Armour?
                            Of course there are. Put that brilliant mind of yours to work if you want to find them.
                            Best advice I can give you.
                              Just noticed that the dimensions of Tira IV...are wrong.
                              Will change that when the CAD comes up.
                              (Message edited by kodster on May 15, 200
                                http://strickenone.proboards99.com/index.cgi?action=display&board=teamww&thread=187&p age=1http://strickenone.proboards99.com/i...teamww&thread= 187&page=1
                                Can someone (other than Mark) check this please?
