How Could I Improve...
ok Timmy, than what exactly is the spinning at 3222RPM part about?
As Martijn stated, which dimension is which? Your shape could be described a bit better. Here I would give a link to the video and try to describe it in a bit more detail. I see this as some sort of full body spinner, in which case you might want to go for four wheels rather than two. Eteks are heavy things and not worth the bother if you don€™t want to use them for power. As you have a potent weapon, go for something like S28-400 Magmotors at 24v. Your motors section is just odd€¦ you just said 2x Eteks powered the wheels so what are those further 9 motors for? You€™ll also struggle to get 11 motors in any robot, for size and for weight. Also, which 8 Magmotors are you using?
I would suggest researching LEMCO motors and looking them over, as they are very potent, and very light, and with LEMs, you dont need a wimpy 24v, go for 36v
. LEM200 motors are HUGE, though, so Id start off with LEM130s. Research them first though.
Also, when thinking of a better weapon, try to research what you need for it, and see it if is reasonable. Figure out a plausible speed for the motors you have put into your machine.
). Find out what each major part of your bot weighs and calculate it up, then add an estimate of the rest of what makes the bot up (wires, speed controllers, nuts and bolts...
), and see if it is near but not over 100kg. If it is, congratulations!
. The armour doesnt define the shape, no real need to put that there.
TAKE THAT OGRE BOY!
Du ist die dick Hunde!
Kanes really going to notice this isnt he?
