EnigmaTek 2.0
quote:
ure that you can rig up a system with 2 canisters whereby if the gas is released into a finite space from both at the same time through a valve, it doubles up the pressure because theres nothing else it can do.
Yes there is, stay in the cannisters. when pressure equalizes over the enitire system gas will stay exactly where it is. 1 gas bottle or 6 gas bottle wont make a bit of difference in pressure.
I blame Blaise Pascal for this. Just like I blame Isaac Newton for inventing gravity.
Motors are not technically a power source, batteries are..
