EnigmaTek 2.0
    EnigmaTek 2.0
    quote:
    ure that you can rig up a system with 2 canisters whereby if the gas is released into a finite space from both at the same time through a valve, it doubles up the pressure because theres nothing else it can do.
    Yes there is, stay in the cannisters. when pressure equalizes over the enitire system gas will stay exactly where it is. 1 gas bottle or 6 gas bottle wont make a bit of difference in pressure.
    I blame Blaise Pascal for this. Just like I blame Isaac Newton for inventing gravity.
      EnigmaTek 2.0
      So it cant read a book?
      Or sing a song?
      *Exits thread*
        EnigmaTek 2.0
        See Martyn. Nothing wrong.
          EnigmaTek 2.0
          *rolls eyes* He hasnt even acknologed your entry
            EnigmaTek 2.0
            Ohhh. ( Sudenly looks Embarassed)
              EnigmaTek 2.0
              Ohhh. ( Suddenly looks Embarassed)
                EnigmaTek 2.0
                Actually... I post about it, but it hasnt show up :-( Argh.... Ill repost...
                Tim, do some research, and stop slapping crap together... Also Martyn, if I see another entry that has Power: 2 x 24v Magmotors, Ill personally travel overseas to b1tch schlap you back to this thread Motors are not technically a power source, batteries are..
                Follow this template and provide real information, and Ill relook at DJ entering. For now, its just being ignored...
                Weight: Robots Total Weight
                Speed: Robots Maximum Speed (KM/H or MPH)
                GC: The clearance between the arena floor and the robots body. Putting various clearances for the different sides is recommended.
                Drive: The motors used, voltage, gearing, and any general information about your drive
                Weapon: State as much as possible. Weight, Pressures, RPM, Force, Gearing, and anything else that can give me more information about it.
                Chassis: State materials, thicknesses, and method of construction (Monocoque, Sectional chassis with bolt panels, welded).
                Batteries: Very Important. State Chemistry type, Amp/Hour Rating, Voltage and number of cells.
                Special Notes: Anything not stated above, invertibility, colors, characteristics...
                Follow that, do some research and you should be able to provide a quality entry...
                • #23
                  EnigmaTek 2.0
                  Ill give it a go.
                  Weight: 98 kg
                  Speed: 18 Km/hour
                  Lenghth/with/height: 120 cm/65cm/35cm
                  GC: 2mm on the sides, 5 mm on the back and front so it wont run aground on a toothpick sticking out the floor. the slipperarm it pushed flush to the floor with bungee lifting the frontend.
                  Drive: 2x3 Graupner speed 900 BB torque @ 24V Geared down 20:1 on 15cm wheels.
                  Weapon: 100mm bore x100mm (4 tons) stroke ram Gravity style flipper with 2 1/2 bsp burkert inlets and a 3mm hole as outlet. A 2 compartment aluminium buffer of 4 Liters being fed by 2 2kg CO2 bottles. The arm levers it down 3:1 giving 1300kg of force at the tip of the arm.
                  Chassis: Main frame holding the ram and flipperarm is 40x40x4 mm welded box section, the baseplate is 4mm 7075 aluminum and the armour on the sides and top is 40mm HDPE. The flipperscoop is hardox 450 6 mm, the arm itself 40x40x4 box section.
                  Batteries: 60 GP3700 NiMh cells, 20S3P, giving 11.1Ah@24V. weight of the pack is 4 kg.
                  Special Notes: All black, with red markings at the sides.
                  (Message edited by leorcc on July 06, 2007)
                  • #24
                    EnigmaTek 2.0
                    Your in Leo :wink:
                    Good stats too, I can actually gather rough understanding on how well your bot will perform
                    • #25
                      EnigmaTek 2.0
                      Box section for frame and arm 24 kg
                      hardox scoop 1 kg (20cm x 10cm x 0,6cm)
                      Armour 24 kg
                      baseplate 8kg
                      weapon system 20kg (including 2 2kg aluminum bottles at 3kg each empty)
                      drive 11kg including wheels and Sidewinder
                      Batteries 4kg.
                      The rest is for bolts and bungee and cables.
                      • #26
                        EnigmaTek 2.0
                        Name: D-J ( Disc-tructive Jockey.)
                        Weight: 97Kg.
                        Max Speed: 12MPH
                        GC: 20MM all around the robot but you shouldnt touch the front.
                        Drive:Same as Big Nipper I suppose but dont moan at me Im not the technical geezer.
                        Weapon: 24KG discs ( or 2X 12KG discs) It can spin at 2000RPM its basically bigger beefier Shredder discs which takes 3.5 seconds to spin up to top speed.
                        Chassis: A D-J like chassis which is welded on and the 2 discs have Rubber shock proofing in between the discs and the main mechanics.
                        Batteries: Probably 4 Nicads running at 35Vs ( If this isnt alowed then do the nearest which is)
                        Special Notes: Got on the left hand side in Blood Red Make Music Not Murder, right hand side in Black Make Peace Not Pieces and on the bottom when it gets tossed in Sunny Yellow Make News Not Nuclear.
                        Strengths: Powerful Disc
                        Weaknesses: Easily Tossed, Slow Spin up time, slow for a vapourbot.
                        • #27
                          EnigmaTek 2.0
                          Eh, then Ill just pull out then. Im too lazy to do any fix-ups on anything right now.
                          • #28
                            EnigmaTek 2.0
                            Gonna have to cancel this due to lack of interest, and the fact Im now back at work, meaning I dont have sufficient time to do anything.
                            • #29
                              EnigmaTek 2.0
                              Tsk.
                              • #30
                                EnigmaTek 2.0
                                Sorry for not getting an entry in, been having trouble getting online. If people are still interested in this concept I may well do a second version in a week or so.
