Pnumatics help
  • Pnumatics help
    ok ive got 2 rams (thanks simon)and a small air tank what else do i need all help is appreciated
    Pnumatics help
    what sort of air tank, fire ext or buffer (low pressure)? you will need; Valve (maybe two, help speed it up), regulator, 1000psi pressure relief valve, LP pressure relief valve, HP pipe and LP pipe plus fitting. This is assuming your using co2. visit; http://www.blazerbotics.co.ukwww.blazerbotics.co.uk theres a pneutmatics bit in the technical section, with links to other sites.
      Pnumatics help
      thanks its a paint ball tank
        Pnumatics help
        Fred, Im in a similar boat to you. I think that we will have to pick Alans brains as much as possible on this. Keep an eye on Ebay for pneumatics bits.
          Pnumatics help
          either you got msn?
            Pnumatics help
            Here has some good info http://www.teamonslaught.fsnet.co.uk/co2_info.htmhttp://www.teamonslaught.fsnet.co.uk/co2_info.htm
              Pnumatics help
              http://www.teamdavinci.com/understanding_pneumatics.htmhttp://www.teamdavinci.com/understanding_pneumatics.htm
                Pnumatics help
                no msn sorry but my team mate has its smelvin296@aol.com but his computer has gone in for repair
