ok ive got 2 rams (thanks simon)and a small air tank what else do i need all help is appreciated
Pnumatics help
Pnumatics help
what sort of air tank, fire ext or buffer (low pressure)? you will need; Valve (maybe two, help speed it up), regulator, 1000psi pressure relief valve, LP pressure relief valve, HP pipe and LP pipe plus fitting. This is assuming your using co2. visit; http://www.blazerbotics.co.ukwww.blazerbotics.co.uk theres a pneutmatics bit in the technical section, with links to other sites.
Pnumatics help
Here has some good info http://www.teamonslaught.fsnet.co.uk/co2_info.htmhttp://www.teamonslaught.fsnet.co.uk/co2_info.htm
Pnumatics help
http://www.teamdavinci.com/understanding_pneumatics.htmhttp://www.teamdavinci.com/understanding_pneumatics.htm
