heavyweight transmitter?
  • heavyweight transmitter?
    just want to check is this type of tx allowed for heavies as i know the old 40mhz are no longer allowed
    Spektrum DX4e DSMX 4-Channel Full Range
    TX is fine, just make sure you can failsafe on all channels on the RX.
      should be ok, on vantec and the flipper has an fs1
        It wont. as the RX will output a valid signal (normally last position), the FS1/Vantec won't know. You need an RX that either stops sending a signal when in failsafe (therefore your vantec/FS1 would kick in) or a RX that will allow you to set the failsafe positions.
          ok good points there,
          as im coming back into this after being out a while could you recommend a few radio sets that would be suitable
          many thanks
            the spektrum transmitters are good you would just have to get a receiver that has failsafes
            http://www.ebay.co.uk/itm/New-Orange...item3cd6801140
            or buy some external failsafes
            http://www.ebay.co.uk/itm/B7044-RC-N...item4d135c27f2
              so basically if i get a spektrum tx and an orange Rx that covers all bases on the fail safe side of things
