heavyweight wheel material for best grip
  • heavyweight wheel material for best grip
    having trouble deciding on wheel material (best grip) and centre material, the ally ones have bearings which are great but would the ally crack ? here is the page ive been looking at.
    http://www.castors.org.uk/160mm-c-4.html
    all ideas muchly appriciated
    Re: heavyweight wheel material for best grip
    get the green ones, nobody else has green wheels!
      I can think of one
        Have a look at bearing boys similar site might give you other options though. (just search on google)
          yep they do have a few more, but im stuck as to what material will give best grip,
          polyurethane, elastic rubber etc,
          also im thinking of getting the wheels with 20mm bearings in so its less work
          they mostly have aluminium hubs and im worried they will crack as they look cast ?
          mind you though they are rated up to 800kgs sometimes so prob ok
          this one looks good but not too cheep up too the job but not sure about grip
          there is some more on the page below aswell.
          http://www.rosscastors.co.uk/160mm-heav ... rings.html
            just emailed these chaps as to best traction and centre type
            https://www.technicawheels.co.uk/industrial-wheels
            loads of good ones .
              Have a look at this article, it might help you
              http://www.thombert.com/white_papers/Po ... rTires.pdf
              To be able to compare you have to know the durometer of the wheels you're comparing, as polyurethane hardness can vary over a wide range, but most probably being heavy duty wheels rated at 800kg, they will be of the hard type....
              Hope this helps
                that is a great help thanks, after comparing loads they are all nearly 70a so it dosent really mater which material, you would thing that if someone had listed an elastic rubber it would be grippier but not true, there discriptions are misleading and one of the polyurathane tyres i was looking at was 95a so i wont bother with that !
                  Been looking for some new wheels for bulldog myself so be interesting to see what you go for
                    These are the softest I've found in 6 diameter, at 50 shore A they look fine... but they're from the states so most probably not worth the hassle
                    http://www.castercity.com/eshop/10Expan ... wheels.htm
                    ratings:
                    http://www.castercity.com/caster-wheel- ... -chart.htm
                      Super grippy 50 Shure is what we use
                      http://www.pu-systems.bayermaterialscie ... _vulkollan
                        Any reply on how internal bearings hold up this is an idea I am looking at also, makes doing a 4wd machine much easier
                          these are my ideas
                          http://www.technicawheels.co.uk/sear...rchQuery=P1615
                          http://www.rosscastors.co.uk/200mm-h...er-wheels.html
                            Those are what I'm using in my new 4wd bot Adam
