What chargers would people recommend for charging HW 24v NiCad packs? Hopefully getting a loan of one but will look at getting one at some point too. Dont think my cheapo FW charger does them, wouldn't trust it to anyway.
Chargers
Re: Chargers
Originally posted by blazerboticsGet some used Supernova/Mercury chargers off ebay, they are what i use, as do most.
Re: Chargers
Originally posted by maddox10I have a Hobbyking quad charger. 4 batteries at the same time, 6S 50W max , doesn't matter what kind. From SLA to LiFePo4.
Re: Chargers
pro peak constalation charger most commonly used.
http://www.hobbystores.co.uk/default.as ... d=O-IP3000
Re: Chargers
Would you need some sort of PSU with that one too Terry? Doesn't look like it'll be compatible with the LCD screen power supply I have for my iMax one.
Re: Chargers
Originally posted by terryYep you will need a 12v supply a 20 or 40 amp ones are used by most roboteers, you can also use a computer supply and change the wires around they are about 700 watt and very cheap aswell.
EDIT: Looks like it would be a more expensive purchase that I first expected...
